求救:IPC的安规电容和桥堆怎么测,急!!!!
明天客户就要来检查,作为IPC,连 安规电容和桥堆不会测,请大虾帮忙^^急!!谢谢
全部回复(3)
@liuzhuangx
请问X电容的耐压怎么测??
X电容的规格是这样:
GENERAL TECHNICAL DATA
Dielectric:
Polypropylene film.
Plates:
Meal layer deposited by evaporation under vacuum.
Winding:
Non-inductive type.
Leads:
Tinned wire.
Protection:
Plastic case, epoxy resin filled.
Box materials is solbent resistant and flame retardant according to UL94V-0.
Marking:
Manufacturer’s logo, series, capacitance, tolerance, Related documents: IEC 384-14 2nd Edition 1993
Operating temperature range:
-40 to +100oC
ELECTRICAL CHARACTERISTICS
Rated voltage (Vr):
275Vac; 50/60Hz
Capacitance range:
4700pF to 1.0uF
Capacitance values:
E12 series (IEC 63 Norm).
Capacitance tolerances (measured at 1kHz)
±5%(J);±10%(K);±20%(M)
Dissipation factor(DF):
≤0.1% at 1KHZ/200C
≤0.3% at 10KHZ/20oC
Withstand voltage:
Applied 1,200 Vac for 60 sec or 2,100 Vdc for 1 sec
Insulation resistance:
Test conditions
Temperature: 20±5oC
Voltage charge time:1 min
Voltage charge: 100Vdc
Performance
≥3×104MΩ for C≤0.33μF
≥1×104MΩ for C>0.33μF
TEST METHOD AND PERFORMANCE
Test conditions
Temperature: 40±2oC
Relative humidity (RH): 90-95%
Test duration: 500 hours
Performance
0.66×rated withstand voltage 60sec.
Capacitance change (△C/C):≤5%
Dissipation Factor (△DF):≤200% of initial specified value
Insulation resistance: ≥50% of initial limit
Endurance:
Test conditions
Temperature: 100±3oC
Test duration: 1008h
Voltage applied: 440Vac
Dissipation Factor (△DF):≥0.06% of increased value
Soldering heat resistance:
Test conditions
Solder bath temperature: 260±5oC
Solder time: 5±1 sec
Performance
Capacitance change (△C/C):≤3%
请问是按哪一种测:1200VDC 60S 或 2100VDC 1S
还是 : 0.66*1200VDC 60S 或 0.66*2100VDC 1S
还有漏电流应该不能大于多少算正常?上面都没提到
Dielectric:
Polypropylene film.
Plates:
Winding:
Non-inductive type.
Leads:
Tinned wire.
Protection:
Marking:
-40 to +100oC
Rated voltage (Vr):
275Vac; 50/60Hz
Capacitance range:
4700pF to 1.0uF
Capacitance values:
≤0.1% at 1KHZ/200C
≤0.3% at 10KHZ/20oC
Withstand voltage:
Test conditions
Temperature: 20±5oC
Performance
Test conditions
Temperature: 40±2oC
Performance
Endurance:
Test conditions
Test conditions
Performance
@liuzhuangx
X电容的规格是这样:GENERALTECHNICALDATADielectric: Polypropylenefilm.Plates: Meallayerdepositedbyevaporationundervacuum.Winding: Non-inductivetype.Leads: Tinnedwire.Protection: Plasticcase,epoxyresinfilled. BoxmaterialsissolbentresistantandflameretardantaccordingtoUL94V-0.Marking: Manufacturer’slogo,series,capacitance,tolerance,Relateddocuments:IEC384-142ndEdition1993 Operatingtemperaturerange: -40to+100oCELECTRICALCHARACTERISTICSRatedvoltage(Vr):275Vac;50/60HzCapacitancerange:4700pFto1.0uFCapacitancevalues:E12series(IEC63Norm).Capacitancetolerances(measuredat1kHz)±5%(J);±10%(K);±20%(M)Dissipationfactor(DF):≤0.1%at1KHZ/200C≤0.3%at10KHZ/20oCWithstandvoltage:Applied1,200Vacfor60secor2,100Vdcfor1secInsulationresistance:TestconditionsTemperature:20±5oCVoltagechargetime:1minVoltagecharge:100VdcPerformance≥3×104MΩforC≤0.33μF≥1×104MΩforC>0.33μFTESTMETHODANDPERFORMANCETestconditionsTemperature:40±2oCRelativehumidity(RH):90-95%Testduration:500hoursPerformance0.66×ratedwithstandvoltage60sec.Capacitancechange(△C/C):≤5%DissipationFactor(△DF):≤200%ofinitialspecifiedvalueInsulationresistance:≥50%ofinitiallimitEndurance:Testconditions Temperature:100±3oC Testduration:1008hVoltageapplied: 440VacCapacitancechange (△C/C):≤5% DissipationFactor(△DF):≥0.06%ofincreasedvalueInsulationresistance:≥50%ofinitiallimitSolderingheatresistance:TestconditionsSolderbathtemperature:260±5oCSoldertime:5±1secPerformanceCapacitancechange (△C/C):≤3%请问是按哪一种测:1200VDC60S 或 2100VDC 1S 还是:0.66*1200VDC60S 或 0.66*2100VDC1S 还有漏电流应该不能大于多少算正常?上面都没提到
怎么没人进来,只好自己顶一下了
