关于开关电源高压测试的问题求救,请各位大侠赐教
我的一款欧洲样机,客户要求高压4.5kV,3S,真是头疼,老是打死IC,我用的是sg6848,TL431,有时甚至光耦和次级整流管也打死.火牛没有问题,单独试过.该款IC比较脆弱,我的pcb 板又比较小.我知道主要的问题在布线上,但有没有一个理论上的支持,布线跳来跳去但改善不大.现在想找一个理论上的支持,或要注意那些事项,再有ESD测试和高压测试的原理的异同点.虽然看书看了一些,懂一些,但是我发现论坛中关于高压测试的例子很少,希望能够做一些深入了解,也希望大家都从中获益.
全部回复(38)
Normally, apply 1.5kv to primary and protection ground,and apply 3kv AC (or 4242VDC) to primary and secondary.You need check the clearance or creepage between primary ( L&N short) and protection ground should be more than 3mm,and the clearance or creepage betrween primary (L &N short) and secondary (all output short) should be more than 6mm.
4.5Kv is AC or DC?
4.5Kv is AC or DC?
@ahtchw
Normally,apply1.5kvtoprimaryandprotectionground,andapply3kvAC(or4242VDC)toprimaryandsecondary.Youneedchecktheclearanceorcreepagebetweenprimary(L&Nshort)andprotectiongroundshouldbemorethan3mm,andtheclearanceorcreepagebetrweenprimary(L&Nshort)andsecondary(alloutputshort)shouldbemorethan6mm.4.5KvisACorDC?
ac4.5kV,3mins,thanks!
