inverter 煮鸡蛋了,怎么办?
各位大虾,
    小弟在做一个4lamp inverter, 采用的是半桥拓扑结构,1推2的形式,变压器为EFD20,匝数比为19:2350.5, MOS-FET 为30v@9a dual的形式. 2pcs, 现在发现变压器的温度很可怕,在敞开的环境下面,温度磁芯达到了50度,线圈的温度要比铁心高,mos的日子也不好过,快进入中年45了,不知道那位高手愿意帮小弟一把,把温度给降低一点,那怕5度也是一个很伟大的进步,先谢谢各位!
全部回复(34)
What is the output power, Ilamp,Vlamp? Working frequency? Input Vdc,Iac, transformer primary volt ac?
momentum
Whatistheoutputpower,Ilamp,Vlamp?Workingfrequency?InputVdc,Iac,transformerprimaryvoltac?
the output current is 6 mA, voltage: 650Vrms, fs:50Khz, input voltage is 10.8--13.2Vdc
@momentum
theoutputcurrentis6mA,voltage:650Vrms,fs:50Khz,inputvoltageis10.8--13.2Vdc
EFD20L should be enough,EEL19 also OK. The surface temperature should be below 40 degree. I think your transformer turn ratio is too high. If your CCFL lamp is in parallel connection,75 turn ratio is enough.
momentum
EFD20Lshouldbeenough,EEL19alsoOK.Thesurfacetemperatureshouldbebelow40degree.Ithinkyourtransformerturnratioistoohigh.IfyourCCFLlampisinparallelconnection,75turnratioisenough.
The panel's spec is attached, but i think the transformer ratio is not very high, if I change the ratio from 120 to 100, the inverter does not work, otherwise, would you tell me how to calculate the half-bridge topology transformer?
By the way, would you have an MSN address?
thanks!
1124792517.pdf
@momentum
Thepanel'sspecisattached,butithinkthetransformerratioisnotveryhigh,ifIchangetheratiofrom120to100,theinverterdoesnotwork,otherwise,wouldyoutellmehowtocalculatethehalf-bridgetopologytransformer?Bytheway,wouldyouhaveanMSNaddress?thanks!1124792517.pdf
guolonghong@163.com
guolonghong@163.com
I will have look about the panel datasheet.
zxxlove
Iwillhavelookaboutthepaneldatasheet.
我认为可以减少匝比,增大线径
@momentum
Whic IC do you use?
momentum
WhicICdoyouuse?
bit3193,single ch half bridge topology. You think the IC will affect the unit?
momentum
thanks, if you have some suggestion, please send me a message or email to the address: inverter2000@163.com thanks a lot
momentum
@zxxlove
我认为可以减少匝比,增大线径
I think you are right, but which ratio and how many turns of the primary and the secondary? And how to set the gap?
zxxlove
@momentum
bit3193,singlechhalfbridgetopology.YouthinktheICwillaffecttheunit?
PRI:双线并绕0.4 绕11圈,SEC:0.06 绕1400
xuxuemin
@momentum
我现在使用的也是BIT3193,如果有好的发现共同分享好吗?
my e-mail :xuxuemin2003@eyou.com
momentum
@zxxlove
PRI:双线并绕0.4绕11圈,SEC:0.06绕1400
这样电感谐振起来会好一些吗???
顺便问问,初级线圈如果饶制11T,会不会电感量太小???因为我对变压器不是很熟悉!还有在这个时候,变压器要不要gap?
momentum
@xuxuemin
我现在使用的也是BIT3193,如果有好的发现共同分享好吗?mye-mail:xuxuemin2003@eyou.com
好的,等我作好了,一定把我的成功给分享出来给您一份,顺便问问,您现在进展的怎么样?还是已经做好了?
momentum
各位大虾,问题还存在啊,大家能不能继续给点意见或者是建议!
条件是控制IC和拓扑结构不能更改!其他的都好说啊!
先谢了!
@momentum
各位大虾,问题还存在啊,大家能不能继续给点意见或者是建议!条件是控制IC和拓扑结构不能更改!其他的都好说啊!先谢了!
Can you send BIT3193 datasheet to me, I do not have the datasheet. I think I can solve your transformer problem.
e-mail:guolonghong@163.com
zxxlove
CanyousendBIT3193datasheettome,Idonothavethedatasheet.IthinkIcansolveyourtransformerproblem.e-mail:guolonghong@163.com
MENTOR 兄:
      问题解决了吗?我也很想知道你是怎么解决的?
momentum
@zxxlove
MENTOR兄:      问题解决了吗?我也很想知道你是怎么解决的?
还没有呢,现在正在考虑阶段,您有什么好建议吗?
repol
像你说的这种情况,我也遇到了.不过我感觉是我pcb板排的有问题.单纯的改transformer解决不了问题.不知道你的pcb排的有没有问题.
momentum
@repol
PCB已经做了调整,但是变压器的发热确实有点恐怖!
szkingli
我们可提供成本很低的四灯管方案。
momentum
@szkingli
我们可提供成本很低的四灯管方案。
你要是方便,麻烦把资料给我
amin_zou
效率有测过吗,如果变压器原边和MOS温升没超过35度是可以接受的,另外以你的工作频率,T的漏感最好控制在200-250左右,按你的圈数大约要0.3左右的gap,另外half-bridge里的电容也很重要,不能太小.
momentum
@amin_zou
我的桥臂电容为47uF,两个串联,变压器目前没有gap,我不知道大侠您做inverter时一般加不加gap,效率的话,我大概看了一下,超过80%!
momentum
自己顶一下!
首先感谢各位回帖的高手们,现在我正式告诉各位一个好消息,现在我已经把温度偏高的问题解决了,整个扳子的温度都在50度以下.
50 度是煮不了鸡蛋的!
最多是把鸡蛋给煮坏!
哈哈!
再次感谢各位!
alb5939
@momentum
自己顶一下!首先感谢各位回帖的高手们,现在我正式告诉各位一个好消息,现在我已经把温度偏高的问题解决了,整个扳子的温度都在50度以下.50度是煮不了鸡蛋的!最多是把鸡蛋给煮坏!哈哈!再次感谢各位!
請教一下,主要是改哪裡才降溫度的
@momentum
恭喜你啊,呵呵~~我是敖玉强.
你什么时候送样啊?你那个6灯的现在怎么样拉?
momentum
2005-09-23 13:47
恭喜你啊,呵呵~~我是敖玉强.你什么时候送样啊?你那个6灯的现在怎么样拉?
马上要开始了,上面已经顶不住了!
momentum
2005-09-23 13:52
@alb5939
請教一下,主要是改哪裡才降溫度的
主要是改电路的反馈参数,让变压器的波形漂亮一点就可以!
