IR2110的仿真文件
可不知用在PSPICE9.2版本以上,哪位高手给处理以下,可以用于9.2,10.和10.5的版本?1125114064.zip
全部回复(11)
@天边边
谢谢, 我想只能继续看PSpice®User’sGuide文档+N次TEST了.
* Copyright (c) International Rectifier
* IR2110: High and Low Side Driver
* Ports
* VDD: Logic Supply
* HIN: Logic Input for High Side Gate Driver Output (HO), in phase
* SD: Logic Input for Shutdown
* LIN: Logic Input for Low Side Gate Driver Output (LO), in phase
* VSS: Logic Ground
* VB: High Side Floating Supply
* HO: High Side Gate Diver Output
* VS: High Side Floating Supply Return
* VCC: Low Side Supply
* LO: Low Side Gate Driver Output
* COM: Low Side Return
* Created by Pspice Version 8
* Date Created: 03/25/2003
* This behavioral model was developed in compliance with Data Sheet
* No. PD60147-R except noted below:
* (1) There is no frequency effect on temperature.
* (2) The power dissipation is different.
* (3) The values of output high/low short circuit current are adjusted
* for the proper modeling of turn-on rise/turn-off fall time.
* (4) The "Low side return (COM)" pin must be grounded.
.SUBCKT IR2110 VDD HIN SD LIN VSS HO VB VS VCC COM LO
+PARAMS:
+ T1=-40 T2=25 T3=125
+ V1=10 V2=15 V3=20
+ tonT1=90n tonT2=120n tonT3=170n
+ tonV1=140n tonV2=120n tonV3=100n
+ toffT1=77n toffT2=94n toffT3=130n
+ toffV1=115n toffV2=94n toffV3=75n
+ tonVdd1=125n tonVdd2=120n tonVdd3=115n
+ toffVdd1=113n toffVdd2=94n toffVdd3=72n
.MODEL diode25 d
+IS=1.0e-14 RS=0.01 N=1 EG=1.11
+XTI=3 BV=25 IBV=0.0001 CJO=0
+VJ=0.75 M=0.333 FC=0.5 TT=0
+KF=0 AF=1
.MODEL diode525 d
+XTI=3 BV=525 IBV=0.0001 CJO=0
+KF=0 AF=1
C_MD1_C2 VSS MD2_Nor3b_2 10p
C_MD1_C3 VSS MD2_Inv2_1 10p
C_MD1_C1 VSS MD2_Inv1_1 1n
D_MD1_D2 VSS HIN diode25
D_MD1_D3 SD VDD diode25
D_MD1_D4 VSS SD diode25
D_MD1_D5 LIN VDD diode25
D_MD1_D6 VSS LIN diode25
D_MD1_D7 VSS VDD diode25
D_MD1_D1 HIN VDD diode25
C_MD1_Trig3_CTrig VSS MD2_Inv2_1 10p
R_MD1_Trig3_R1Trig MD1_Trig3_3 VDD 100Meg
R_MD1_Trig3_R2Trig MD1_Trig3_4 MD1_Trig3_3 66.7Meg
R_MD1_Trig3_R3Trig VSS MD1_Trig3_4 106.1Meg
X_MD1_Trig3_Comp LIN MD1_Trig3_3 MD2_Inv2_1 com COMP
S_MD1_Trig3_PTrig MD1_Trig3_4 VSS MD2_Inv2_1 VSS _MD1_Trig3_PTrig
RS_MD1_Trig3_PTrig MD2_Inv2_1 VSS 1G
.MODEL _MD1_Trig3_PTrig VSWITCH Roff=1e9 Ron=1 Voff=0.01 Von=4.99
R_MD1_R1 VSS HIN 750k TC=-0.00783811, 0.0000372046
R_MD1_R2 VSS SD 750k TC=-0.00783811, 0.0000372046
C_MD1_Trig1_CTrig VSS MD2_Inv1_1 10p
R_MD1_Trig1_R1Trig MD1_Trig1_3 VDD 100Meg
R_MD1_Trig1_R2Trig MD1_Trig1_4 MD1_Trig1_3 66.7Meg
R_MD1_Trig1_R3Trig VSS MD1_Trig1_4 106.1Meg
X_MD1_Trig1_Comp HIN MD1_Trig1_3 MD2_Inv1_1 com COMP
S_MD1_Trig1_PTrig MD1_Trig1_4 VSS MD2_Inv1_1 VSS _MD1_Trig1_PTrig
RS_MD1_Trig1_PTrig MD2_Inv1_1 VSS 1G
.MODEL _MD1_Trig1_PTrig VSWITCH Roff=1e9 Ron=1 Voff=0.01 Von=4.99
C_MD1_Trig2_CTrig VSS MD2_Nor3b_2 10p
R_MD1_Trig2_R1Trig MD1_Trig2_3 VDD 100Meg
R_MD1_Trig2_R2Trig MD1_Trig2_4 MD1_Trig2_3 66.7Meg
R_MD1_Trig2_R3Trig VSS MD1_Trig2_4 106.1Meg
X_MD1_Trig2_Comp SD MD1_Trig2_3 MD2_Nor3b_2 com COMP
S_MD1_Trig2_PTrig MD1_Trig2_4 VSS MD2_Nor3b_2 VSS _MD1_Trig2_PTrig
RS_MD1_Trig2_PTrig MD2_Nor3b_2 VSS 1G
.MODEL _MD1_Trig2_PTrig VSWITCH Roff=1e9 Ron=1 Voff=0.01 Von=4.99
R_MD1_R3 VSS LIN 750k TC=-0.00783811, 0.0000372046
R_MD1_R4 VSS VDD 7.5Meg TC=-0.00505291, 0.0000236999
C_MD2_C1 VSS MD3_DlyHS_2 10p IC=0
C_MD2_C2 VSS MD3_DlyLS_2 10p IC=0
V_MD2_Inv1_V MD2_Inv1_2 VSS 5V
C_MD2_Inv1_C VSS MD2_Nor3a_3 1p
S_MD2_Inv1_P MD2_Inv1_2 MD2_Nor3a_3 MD2_Inv1_1 VSS _MD2_Inv1_P
RS_MD2_Inv1_P MD2_Inv1_1 VSS 1G
.MODEL _MD2_Inv1_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD2_Inv1_N MD2_Nor3a_3 VSS MD2_Inv1_1 VSS _MD2_Inv1_N
RS_MD2_Inv1_N MD2_Inv1_1 VSS 1G
.MODEL _MD2_Inv1_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
V_MD2_Inv2_V MD2_Inv2_2 VSS 5V
C_MD2_Inv2_C VSS MD2_Nor3b_1 1p
S_MD2_Inv2_P MD2_Inv2_2 MD2_Nor3b_1 MD2_Inv2_1 VSS _MD2_Inv2_P
RS_MD2_Inv2_P MD2_Inv2_1 VSS 1G
.MODEL _MD2_Inv2_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD2_Inv2_N MD2_Nor3b_1 VSS MD2_Inv2_1 VSS _MD2_Inv2_N
RS_MD2_Inv2_N MD2_Inv2_1 VSS 1G
.MODEL _MD2_Inv2_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
C_MD2_RS1_C7 MD2_RS1_6 MD2_RS1_5 10p
C_MD2_RS1_C2 VSS MD2_Nor3a_3 10p IC=0
C_MD2_RS1_C3 VSS MD2_Nor3b_2 10p IC=0
C_MD2_RS1_C10 MD2_RS1_7 MD2_RS1_5 10p
C_MD2_RS1_C11 MD2_RS1_3 MD2_RS1_7 10p
C_MD2_RS1_C12 VSS MD2_RS1_3 10p
C_MD2_RS1_C9 VSS MD2_Nor3a_1 10p
C_MD2_RS1_C8 MD2_Nor3a_1 MD2_RS1_6 10p
C_MD2_RS1_C1 VSS MD2_Nor3a_1 10p IC=0
S_MD2_RS1_P1 MD2_RS1_5 MD2_RS1_6 MD2_Nor3a_3 VSS _MD2_RS1_P1
RS_MD2_RS1_P1 MD2_Nor3a_3 VSS 1G
.MODEL _MD2_RS1_P1 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V
S_MD2_RS1_P2 MD2_RS1_6 MD2_Nor3a_1 MD2_RS1_3 VSS _MD2_RS1_P2
RS_MD2_RS1_P2 MD2_RS1_3 VSS 1G
.MODEL _MD2_RS1_P2 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V
S_MD2_RS1_N1 MD2_Nor3a_1 VSS MD2_RS1_3 VSS _MD2_RS1_N1
RS_MD2_RS1_N1 MD2_RS1_3 VSS 1G
.MODEL _MD2_RS1_N1 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V
S_MD2_RS1_P3 MD2_RS1_5 MD2_RS1_7 MD2_Nor3b_2 VSS _MD2_RS1_P3
RS_MD2_RS1_P3 MD2_Nor3b_2 VSS 1G
.MODEL _MD2_RS1_P3 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V
S_MD2_RS1_P4 MD2_RS1_7 MD2_RS1_3 MD2_Nor3a_1 VSS _MD2_RS1_P4
RS_MD2_RS1_P4 MD2_Nor3a_1 VSS 1G
.MODEL _MD2_RS1_P4 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V
S_MD2_RS1_N3 MD2_RS1_3 VSS MD2_Nor3b_2 VSS _MD2_RS1_N3
RS_MD2_RS1_N3 MD2_Nor3b_2 VSS 1G
.MODEL _MD2_RS1_N3 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V
V_MD2_RS1_V1 MD2_RS1_5 VSS 5V
S_MD2_RS1_N4 MD2_RS1_3 VSS MD2_Nor3a_1 VSS _MD2_RS1_N4
RS_MD2_RS1_N4 MD2_Nor3a_1 VSS 1G
.MODEL _MD2_RS1_N4 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V
S_MD2_RS1_N2 MD2_Nor3a_1 VSS MD2_Nor3a_3 VSS _MD2_RS1_N2
RS_MD2_RS1_N2 MD2_Nor3a_3 VSS 1G
.MODEL _MD2_RS1_N2 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V
C_MD2_RS2_C7 MD2_RS2_6 MD2_RS2_5 10p
C_MD2_RS2_C2 VSS MD2_Nor3b_1 10p IC=0
C_MD2_RS2_C3 VSS MD2_Nor3b_2 10p IC=0
C_MD2_RS2_C10 MD2_RS2_7 MD2_RS2_5 10p
C_MD2_RS2_C11 MD2_RS2_3 MD2_RS2_7 10p
C_MD2_RS2_C12 VSS MD2_RS2_3 10p
C_MD2_RS2_C9 VSS MD2_Nor3b_3 10p
C_MD2_RS2_C8 MD2_Nor3b_3 MD2_RS2_6 10p
C_MD2_RS2_C1 VSS MD2_Nor3b_3 10p IC=0
S_MD2_RS2_P1 MD2_RS2_5 MD2_RS2_6 MD2_Nor3b_1 VSS _MD2_RS2_P1
RS_MD2_RS2_P1 MD2_Nor3b_1 VSS 1G
.MODEL _MD2_RS2_P1 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V
S_MD2_RS2_P2 MD2_RS2_6 MD2_Nor3b_3 MD2_RS2_3 VSS _MD2_RS2_P2
RS_MD2_RS2_P2 MD2_RS2_3 VSS 1G
.MODEL _MD2_RS2_P2 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V
S_MD2_RS2_N1 MD2_Nor3b_3 VSS MD2_RS2_3 VSS _MD2_RS2_N1
RS_MD2_RS2_N1 MD2_RS2_3 VSS 1G
.MODEL _MD2_RS2_N1 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V
S_MD2_RS2_P3 MD2_RS2_5 MD2_RS2_7 MD2_Nor3b_2 VSS _MD2_RS2_P3
RS_MD2_RS2_P3 MD2_Nor3b_2 VSS 1G
.MODEL _MD2_RS2_P3 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V
S_MD2_RS2_P4 MD2_RS2_7 MD2_RS2_3 MD2_Nor3b_3 VSS _MD2_RS2_P4
RS_MD2_RS2_P4 MD2_Nor3b_3 VSS 1G
.MODEL _MD2_RS2_P4 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V
S_MD2_RS2_N3 MD2_RS2_3 VSS MD2_Nor3b_2 VSS _MD2_RS2_N3
RS_MD2_RS2_N3 MD2_Nor3b_2 VSS 1G
.MODEL _MD2_RS2_N3 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V
V_MD2_RS2_V1 MD2_RS2_5 VSS 5V
S_MD2_RS2_N4 MD2_RS2_3 VSS MD2_Nor3b_3 VSS _MD2_RS2_N4
RS_MD2_RS2_N4 MD2_Nor3b_3 VSS 1G
.MODEL _MD2_RS2_N4 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V
S_MD2_RS2_N2 MD2_Nor3b_3 VSS MD2_Nor3b_1 VSS _MD2_RS2_N2
RS_MD2_RS2_N2 MD2_Nor3b_1 VSS 1G
.MODEL _MD2_RS2_N2 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V
S_MD2_Nor3a_P1 MD2_Nor3a_4 MD2_Nor3a_5 MD2_Nor3a_1 VSS _MD2_Nor3a_P1
RS_MD2_Nor3a_P1 MD2_Nor3a_1 VSS 1G
.MODEL _MD2_Nor3a_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD2_Nor3a_P2 MD2_Nor3a_5 MD2_Nor3a_6 MD2_Nor3b_2 VSS _MD2_Nor3a_P2
RS_MD2_Nor3a_P2 MD2_Nor3b_2 VSS 1G
.MODEL _MD2_Nor3a_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD2_Nor3a_P3 MD2_Nor3a_6 MD3_DlyHS_2 MD2_Nor3a_3 VSS _MD2_Nor3a_P3
RS_MD2_Nor3a_P3 MD2_Nor3a_3 VSS 1G
.MODEL _MD2_Nor3a_P3 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD2_Nor3a_N1 MD3_DlyHS_2 VSS MD2_Nor3b_2 VSS _MD2_Nor3a_N1
RS_MD2_Nor3a_N1 MD2_Nor3b_2 VSS 1G
.MODEL _MD2_Nor3a_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
V_MD2_Nor3a_V MD2_Nor3a_4 VSS 5V
S_MD2_Nor3a_N2 MD3_DlyHS_2 VSS MD2_Nor3a_1 VSS _MD2_Nor3a_N2
RS_MD2_Nor3a_N2 MD2_Nor3a_1 VSS 1G
.MODEL _MD2_Nor3a_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
S_MD2_Nor3a_N3 MD3_DlyHS_2 VSS MD2_Nor3a_3 VSS _MD2_Nor3a_N3
RS_MD2_Nor3a_N3 MD2_Nor3a_3 VSS 1G
.MODEL _MD2_Nor3a_N3 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
S_MD2_Nor3b_P1 MD2_Nor3b_4 MD2_Nor3b_5 MD2_Nor3b_1 VSS _MD2_Nor3b_P1
RS_MD2_Nor3b_P1 MD2_Nor3b_1 VSS 1G
.MODEL _MD2_Nor3b_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD2_Nor3b_P2 MD2_Nor3b_5 MD2_Nor3b_6 MD2_Nor3b_2 VSS _MD2_Nor3b_P2
RS_MD2_Nor3b_P2 MD2_Nor3b_2 VSS 1G
.MODEL _MD2_Nor3b_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD2_Nor3b_P3 MD2_Nor3b_6 MD3_DlyLS_2 MD2_Nor3b_3 VSS _MD2_Nor3b_P3
RS_MD2_Nor3b_P3 MD2_Nor3b_3 VSS 1G
.MODEL _MD2_Nor3b_P3 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD2_Nor3b_N1 MD3_DlyLS_2 VSS MD2_Nor3b_2 VSS _MD2_Nor3b_N1
RS_MD2_Nor3b_N1 MD2_Nor3b_2 VSS 1G
.MODEL _MD2_Nor3b_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
V_MD2_Nor3b_V MD2_Nor3b_4 VSS 5V
S_MD2_Nor3b_N2 MD3_DlyLS_2 VSS MD2_Nor3b_1 VSS _MD2_Nor3b_N2
RS_MD2_Nor3b_N2 MD2_Nor3b_1 VSS 1G
.MODEL _MD2_Nor3b_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
S_MD2_Nor3b_N3 MD3_DlyLS_2 VSS MD2_Nor3b_3 VSS _MD2_Nor3b_N3
RS_MD2_Nor3b_N3 MD2_Nor3b_3 VSS 1G
.MODEL _MD2_Nor3b_N3 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
D_MD5_D2 com LO diode25
D_MD5_D1 LO VCC diode25
C_MD5_C com LO 10p
C_MD5_Uvcc_c1 MD5_Uvcc_2 MD5_Uvcc_3 10n
C_MD5_Uvcc_c2 MD5_Uvcc_4 MD5_Uvcc_2 10n
C_MD5_Uvcc_c3 com MD4_Inv5_1 10p
E_MD5_Uvcc_ABM2 MD5_Uvcc_3 com VALUE { 8.3+(8.8-8.3)/(125+40)*(TEMP+40)
E_MD5_Uvcc_ABM3 MD5_Uvcc_4 com VALUE { 8.0+(8.5-8.0)/(125+40)*(TEMP+40)
X_MD5_Uvcc_Comp VCC MD5_Uvcc_2 MD4_Inv5_1 com COMP
S_MD5_Uvcc_P MD5_Uvcc_3 MD5_Uvcc_2 MD4_Inv5_1 com _MD5_Uvcc_P
RS_MD5_Uvcc_P MD4_Inv5_1 com 1G
.MODEL _MD5_Uvcc_P VSWITCH Roff=1e6 Ron=1 Voff=4.99 Von=0.01
S_MD5_Uvcc_N MD5_Uvcc_2 MD5_Uvcc_4 MD4_Inv5_1 com _MD5_Uvcc_N
RS_MD5_Uvcc_N MD4_Inv5_1 com 1G
.MODEL _MD5_Uvcc_N VSWITCH Roff=1e6 Ron=1 Voff=0.01 Von=4.99
S_MD5_Nand_P1 MD5_Nand_5 MD5_OLS_1 MD4_Inv5_1 VSS _MD5_Nand_P1
RS_MD5_Nand_P1 MD4_Inv5_1 VSS 1G
.MODEL _MD5_Nand_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1
S_MD5_Nand_N1 MD5_OLS_1 MD5_Nand_4 MD3_DlyLS_8 VSS _MD5_Nand_N1
RS_MD5_Nand_N1 MD3_DlyLS_8 VSS 1G
.MODEL _MD5_Nand_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9
S_MD5_Nand_P2 MD5_Nand_5 MD5_OLS_1 MD3_DlyLS_8 VSS _MD5_Nand_P2
RS_MD5_Nand_P2 MD3_DlyLS_8 VSS 1G
.MODEL _MD5_Nand_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1
V_MD5_Nand_V MD5_Nand_5 VSS 5V
S_MD5_Nand_N2 MD5_Nand_4 VSS MD4_Inv5_1 VSS _MD5_Nand_N2
RS_MD5_Nand_N2 MD4_Inv5_1 VSS 1G
.MODEL _MD5_Nand_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9
S_MD5_OLS_P VCC MD5_OLS_2 MD5_OLS_1 com _MD5_OLS_P
RS_MD5_OLS_P MD5_OLS_1 com 1G
.MODEL _MD5_OLS_P VSWITCH Roff=1e9 Ron=1m Voff=4.9 Von=0.1
S_MD5_OLS_N MD5_OLS_3 com MD5_OLS_1 com _MD5_OLS_N
RS_MD5_OLS_N MD5_OLS_1 com 1G
.MODEL _MD5_OLS_N VSWITCH Roff=1e9 Ron=1m Voff=0.1 Von=4.9
R_MD5_OLS_R6 LO MD5_OLS_2 11.4 TC=0.00190676, 9.3240e-07
R_MD5_OLS_R7 MD5_OLS_3 LO 7.76 TC=0.00241396, 2.331e-06
R_MD5_R com VCC 83.3k TC=-0.00358599, 0.0000124556
D_MD5_D3 com VCC diode25
D_MD4_D2 HO VB diode25
D_MD4_D1 VS VB diode25
D_MD4_D4 com VB diode525
D_MD4_D5 com VS diode525
D_MD4_D3 VS HO diode25
C_MD4_C3 VS HO 10p IC=0
C_MD4_Uvbs_c1 MD4_Uvbs_2 MD4_Uvbs_4 10n
C_MD4_Uvbs_c2 MD4_Uvbs_5 MD4_Uvbs_2 10n
C_MD4_Uvbs_c3 com MD4_Inv4_1 10p
E_MD4_Uvbs_ABM18 MD4_Uvbs_4 com VALUE {
+ V(VS)+8.4+(8.9-8.4)/(125+40)*(TEMP+40) }
E_MD4_Uvbs_ABM19 MD4_Uvbs_5 com VALUE {
+ V(VS)+8.0+(8.45-8.0)/(125+40)*(TEMP+40) }
X_MD4_Uvbs_Comp VB MD4_Uvbs_2 MD4_Inv4_1 com COMP
S_MD4_Uvbs_P MD4_Uvbs_4 MD4_Uvbs_2 MD4_Inv4_1 com _MD4_Uvbs_P
RS_MD4_Uvbs_P MD4_Inv4_1 com 1G
.MODEL _MD4_Uvbs_P VSWITCH Roff=1e6 Ron=1 Voff=4.99 Von=0.01
S_MD4_Uvbs_N MD4_Uvbs_2 MD4_Uvbs_5 MD4_Inv4_1 com _MD4_Uvbs_N
RS_MD4_Uvbs_N MD4_Inv4_1 com 1G
.MODEL _MD4_Uvbs_N VSWITCH Roff=1e6 Ron=1 Voff=0.01 Von=4.99
V_MD4_Inv3_V MD4_Inv3_2 VSS 5V
C_MD4_Inv3_C VSS MD4_OHS_1 1p
S_MD4_Inv3_P MD4_Inv3_2 MD4_OHS_1 MD4_RS_4 VSS _MD4_Inv3_P
RS_MD4_Inv3_P MD4_RS_4 VSS 1G
.MODEL _MD4_Inv3_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD4_Inv3_N MD4_OHS_1 VSS MD4_RS_4 VSS _MD4_Inv3_N
RS_MD4_Inv3_N MD4_RS_4 VSS 1G
.MODEL _MD4_Inv3_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
C_MD4_RS_C7 MD4_RS_6 MD4_RS_5 10p
C_MD4_RS_C2 VSS MD4_Inv2_3 10p IC=0
C_MD4_RS_C3 VSS MD3_DlyHS_8 10p IC=0
C_MD4_RS_C10 MD4_RS_7 MD4_RS_5 10p
C_MD4_RS_C11 MD4_RS_3 MD4_RS_7 10p
C_MD4_RS_C12 VSS MD4_RS_3 10p
C_MD4_RS_C9 VSS MD4_RS_4 10p
C_MD4_RS_C8 MD4_RS_4 MD4_RS_6 10p
C_MD4_RS_C1 VSS MD4_RS_4 10p IC=0
S_MD4_RS_P1 MD4_RS_5 MD4_RS_6 MD4_Inv2_3 VSS _MD4_RS_P1
RS_MD4_RS_P1 MD4_Inv2_3 VSS 1G
.MODEL _MD4_RS_P1 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V
S_MD4_RS_P2 MD4_RS_6 MD4_RS_4 MD4_RS_3 VSS _MD4_RS_P2
RS_MD4_RS_P2 MD4_RS_3 VSS 1G
.MODEL _MD4_RS_P2 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V
S_MD4_RS_N1 MD4_RS_4 VSS MD4_RS_3 VSS _MD4_RS_N1
RS_MD4_RS_N1 MD4_RS_3 VSS 1G
.MODEL _MD4_RS_N1 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V
S_MD4_RS_P3 MD4_RS_5 MD4_RS_7 MD3_DlyHS_8 VSS _MD4_RS_P3
RS_MD4_RS_P3 MD3_DlyHS_8 VSS 1G
.MODEL _MD4_RS_P3 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V
S_MD4_RS_P4 MD4_RS_7 MD4_RS_3 MD4_RS_4 VSS _MD4_RS_P4
RS_MD4_RS_P4 MD4_RS_4 VSS 1G
.MODEL _MD4_RS_P4 VSWITCH Roff=1e6 Ron=1m Voff=4.9V Von=0.1V
S_MD4_RS_N3 MD4_RS_3 VSS MD3_DlyHS_8 VSS _MD4_RS_N3
RS_MD4_RS_N3 MD3_DlyHS_8 VSS 1G
.MODEL _MD4_RS_N3 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V
V_MD4_RS_V1 MD4_RS_5 VSS 5V
S_MD4_RS_N4 MD4_RS_3 VSS MD4_RS_4 VSS _MD4_RS_N4
RS_MD4_RS_N4 MD4_RS_4 VSS 1G
.MODEL _MD4_RS_N4 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V
S_MD4_RS_N2 MD4_RS_4 VSS MD4_Inv2_3 VSS _MD4_RS_N2
RS_MD4_RS_N2 MD4_Inv2_3 VSS 1G
.MODEL _MD4_RS_N2 VSWITCH Roff=1e8 Ron=1m Voff=0.1V Von=4.9V
V_MD4_Inv2_V MD4_Inv2_2 VSS 5V
C_MD4_Inv2_C VSS MD4_Inv2_3 1p
S_MD4_Inv2_P MD4_Inv2_2 MD4_Inv2_3 MD4_Nor1_5 VSS _MD4_Inv2_P
RS_MD4_Inv2_P MD4_Nor1_5 VSS 1G
.MODEL _MD4_Inv2_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD4_Inv2_N MD4_Inv2_3 VSS MD4_Nor1_5 VSS _MD4_Inv2_N
RS_MD4_Inv2_N MD4_Nor1_5 VSS 1G
.MODEL _MD4_Inv2_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
V_MD4_Inv1_V MD4_Inv1_2 VSS 5V
C_MD4_Inv1_C VSS MD4_Nor1_1 1p
S_MD4_Inv1_P MD4_Inv1_2 MD4_Nor1_1 MD3_DlyHS_8 VSS _MD4_Inv1_P
RS_MD4_Inv1_P MD3_DlyHS_8 VSS 1G
.MODEL _MD4_Inv1_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD4_Inv1_N MD4_Nor1_1 VSS MD3_DlyHS_8 VSS _MD4_Inv1_N
RS_MD4_Inv1_N MD3_DlyHS_8 VSS 1G
.MODEL _MD4_Inv1_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
V_MD4_Inv4_V MD4_Inv4_2 VSS 5V
C_MD4_Inv4_C VSS MD4_Nor2_2 1p
S_MD4_Inv4_P MD4_Inv4_2 MD4_Nor2_2 MD4_Inv4_1 VSS _MD4_Inv4_P
RS_MD4_Inv4_P MD4_Inv4_1 VSS 1G
.MODEL _MD4_Inv4_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD4_Inv4_N MD4_Nor2_2 VSS MD4_Inv4_1 VSS _MD4_Inv4_N
RS_MD4_Inv4_N MD4_Inv4_1 VSS 1G
.MODEL _MD4_Inv4_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
V_MD4_Nor1_V MD4_Nor1_3 VSS 5V
S_MD4_Nor1_P1 MD4_Nor1_3 MD4_Nor1_4 MD4_Nor1_1 VSS _MD4_Nor1_P1
RS_MD4_Nor1_P1 MD4_Nor1_1 VSS 1G
.MODEL _MD4_Nor1_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1
S_MD4_Nor1_P2 MD4_Nor1_4 MD4_Nor1_5 MD4_Inv6_3 VSS _MD4_Nor1_P2
RS_MD4_Nor1_P2 MD4_Inv6_3 VSS 1G
.MODEL _MD4_Nor1_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1
S_MD4_Nor1_N1 MD4_Nor1_5 VSS MD4_Inv6_3 VSS _MD4_Nor1_N1
RS_MD4_Nor1_N1 MD4_Inv6_3 VSS 1G
.MODEL _MD4_Nor1_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9
S_MD4_Nor1_N2 MD4_Nor1_5 VSS MD4_Nor1_1 VSS _MD4_Nor1_N2
RS_MD4_Nor1_N2 MD4_Nor1_1 VSS 1G
.MODEL _MD4_Nor1_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9
V_MD4_Inv5_V MD4_Inv5_2 VSS 5V
C_MD4_Inv5_C VSS MD4_Nor2_1 1p
S_MD4_Inv5_P MD4_Inv5_2 MD4_Nor2_1 MD4_Inv5_1 VSS _MD4_Inv5_P
RS_MD4_Inv5_P MD4_Inv5_1 VSS 1G
.MODEL _MD4_Inv5_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD4_Inv5_N MD4_Nor2_1 VSS MD4_Inv5_1 VSS _MD4_Inv5_N
RS_MD4_Inv5_N MD4_Inv5_1 VSS 1G
.MODEL _MD4_Inv5_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
V_MD4_Nor2_V MD4_Nor2_3 VSS 5V
S_MD4_Nor2_P1 MD4_Nor2_3 MD4_Nor2_4 MD4_Nor2_1 VSS _MD4_Nor2_P1
RS_MD4_Nor2_P1 MD4_Nor2_1 VSS 1G
.MODEL _MD4_Nor2_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1
S_MD4_Nor2_P2 MD4_Nor2_4 MD4_Inv6_1 MD4_Nor2_2 VSS _MD4_Nor2_P2
RS_MD4_Nor2_P2 MD4_Nor2_2 VSS 1G
.MODEL _MD4_Nor2_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1
S_MD4_Nor2_N1 MD4_Inv6_1 VSS MD4_Nor2_2 VSS _MD4_Nor2_N1
RS_MD4_Nor2_N1 MD4_Nor2_2 VSS 1G
.MODEL _MD4_Nor2_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9
S_MD4_Nor2_N2 MD4_Inv6_1 VSS MD4_Nor2_1 VSS _MD4_Nor2_N2
RS_MD4_Nor2_N2 MD4_Nor2_1 VSS 1G
.MODEL _MD4_Nor2_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9
V_MD4_Inv6_V MD4_Inv6_2 VSS 5V
C_MD4_Inv6_C VSS MD4_Inv6_3 1p
S_MD4_Inv6_P MD4_Inv6_2 MD4_Inv6_3 MD4_Inv6_1 VSS _MD4_Inv6_P
RS_MD4_Inv6_P MD4_Inv6_1 VSS 1G
.MODEL _MD4_Inv6_P VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD4_Inv6_N MD4_Inv6_3 VSS MD4_Inv6_1 VSS _MD4_Inv6_N
RS_MD4_Inv6_N MD4_Inv6_1 VSS 1G
.MODEL _MD4_Inv6_N VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
R_MD4_R1 VS VB 120k TC=-0.00135415, -2.516e-7
S_MD4_OHS_P VB MD4_OHS_2 MD4_OHS_1 com _MD4_OHS_P
RS_MD4_OHS_P MD4_OHS_1 com 1G
.MODEL _MD4_OHS_P VSWITCH Roff=1e9 Ron=1m Voff=4.9 Von=0.1
S_MD4_OHS_N MD4_OHS_3 VS MD4_OHS_1 com _MD4_OHS_N
RS_MD4_OHS_N MD4_OHS_1 com 1G
.MODEL _MD4_OHS_N VSWITCH Roff=1e9 Ron=1m Voff=0.1 Von=4.9
R_MD4_OHS_R6 HO MD4_OHS_2 11.4 TC=0.00190676, 9.3240e-07
R_MD4_OHS_R7 MD4_OHS_3 HO 7.76 TC=0.00241396, 2.331e-06
C_MD3_C1 com MD3_DlyHS_8 10p
C_MD3_C2 com MD3_DlyLS_8 10p
E_MD3_ABM21 MD3_DlyHS_1 com VALUE { ( V(VB)
+ -V(VS) ) }
C_MD3_DlyHS_C VSS MD3_DlyHS_5 10n
S_MD3_DlyHS_delay_P MD3_DlyHS_20 MD3_DlyHS_5 MD3_DlyHS_2 VSS
+ _MD3_DlyHS_delay_P
RS_MD3_DlyHS_delay_P MD3_DlyHS_2 VSS 1G
.MODEL _MD3_DlyHS_delay_P VSWITCH Roff=1e6 Ron=10 Voff=4.99V Von=0.01V
S_MD3_DlyHS_delay_N MD3_DlyHS_5 VSS MD3_DlyHS_2 VSS _MD3_DlyHS_delay_N
RS_MD3_DlyHS_delay_N MD3_DlyHS_2 VSS 1G
.MODEL _MD3_DlyHS_delay_N VSWITCH Roff=1e6 Ron=10 Voff=0.01V Von=4.99V
S_MD3_DlyHS_P1 MD3_DlyHS_10 MD3_DlyHS_11 MD3_DlyHS_6 VSS _MD3_DlyHS_P1
RS_MD3_DlyHS_P1 MD3_DlyHS_6 VSS 1G
.MODEL _MD3_DlyHS_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD3_DlyHS_P2 MD3_DlyHS_11 MD3_DlyHS_9 MD3_DlyHS_8 VSS _MD3_DlyHS_P2
RS_MD3_DlyHS_P2 MD3_DlyHS_8 VSS 1G
.MODEL _MD3_DlyHS_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD3_DlyHS_N1 MD3_DlyHS_9 VSS MD3_DlyHS_8 VSS _MD3_DlyHS_N1
RS_MD3_DlyHS_N1 MD3_DlyHS_8 VSS 1G
.MODEL _MD3_DlyHS_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
S_MD3_DlyHS_MP1 MD3_DlyHS_12 MD3_DlyHS_13 MD3_DlyHS_9 VSS
+ _MD3_DlyHS_MP1
RS_MD3_DlyHS_MP1 MD3_DlyHS_9 VSS 1G
.MODEL _MD3_DlyHS_MP1 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD3_DlyHS_MP2 MD3_DlyHS_13 MD3_DlyHS_8 MD3_DlyHS_7 VSS _MD3_DlyHS_MP2
RS_MD3_DlyHS_MP2 MD3_DlyHS_7 VSS 1G
.MODEL _MD3_DlyHS_MP2 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1
S_MD3_DlyHS_MN1 MD3_DlyHS_8 VSS MD3_DlyHS_7 VSS _MD3_DlyHS_MN1
RS_MD3_DlyHS_MN1 MD3_DlyHS_7 VSS 1G
.MODEL _MD3_DlyHS_MN1 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9
S_MD3_DlyHS_MN2 MD3_DlyHS_8 VSS MD3_DlyHS_9 VSS _MD3_DlyHS_MN2
RS_MD3_DlyHS_MN2 MD3_DlyHS_9 VSS 1G
.MODEL _MD3_DlyHS_MN2 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9
X_MD3_DlyHS_Comp1 MD3_DlyHS_5 MD3_DlyHS_18 MD3_DlyHS_7 com COMP
X_MD3_DlyHS_Comp2 MD3_DlyHS_3 MD3_DlyHS_5 MD3_DlyHS_6 com COMP
E_MD3_DlyHS_ABM5 MD3_DlyHS_21 com VALUE { (5-5*EXP(-{toffT2}/10/10n))
+ *(5-5* EXP(-( {toffT1}+({toffT3}-{toffT1})/({T3}-{T1})*(TEMP-{T1}))/10/10n))
+ /(5-5* EXP(-( {toffT1}+({toffT3}-{toffT1})/({T3}-{T1})*({T2}-{T1}))/10/10n))
E_MD3_DlyHS_ABM14 MD3_DlyHS_19 com VALUE { (1-EXP(-( {toffVdd1}+(
+ {toffVdd3}-{toffVdd1})/({V3}-{V1})*(V(VDD)-{V1}))/10/ 10n))/
+ (1-EXP(-( {toffVdd1}+({toffVdd3}-{toffVdd1})/({V3}-{V1})*({V2} -{V1}))/10/
+ 10n)) }
E_MD3_DlyHS_ABM31 MD3_DlyHS_18 com VALUE { ( V(MD3_DlyHS_21)
+ *V(MD3_DlyHS_17)
+ *V(MD3_DlyHS_19) ) }
E_MD3_DlyHS_ABM24 MD3_DlyHS_3 com VALUE { (EXP(-({tonVdd1}+({tonVdd3}-
+ {tonVdd1})/({V3}-{V1})*(V(VDD)-{V1}))/10/10n))/((EXP(-({tonVdd1}+({tonVdd3}-
+ {tonVdd1})/({V3}-{V1})*({V2}- {V1}))/10/10n)))
+ *(5* EXP(-( {tonT1}+({tonT3}-{tonT1})/({T3}-{T1})*(TEMP-{T1})) /10/
+ 10n))/(5* EXP(-( {tonT1}+({tonT3}-{tonT1})/({T3}-{T1})*({T2}-{T1})) /10/
+ 10n))*5*EXP(-{tonT2}/10/10n)* (EXP(-({tonV1}+({tonV3}-{tonV1})/({V3}-
+ {V1})*(V(MD3_DlyHS_1)-{V1}))/10/10n))/((EXP(-( {tonV1}+({tonV3}-{tonV1})/({V3}-
+ {V1})*({V2}-{V1}))/10/10n))) }
V_MD3_DlyHS_V_delay MD3_DlyHS_20 VSS 5V
C_MD3_DlyHS_C3 VSS MD3_DlyHS_6 10p
V_MD3_DlyHS_VCC1 MD3_DlyHS_10 VSS 5V
C_MD3_DlyHS_C6 VSS MD3_DlyHS_9 10p IC=-5V
C_MD3_DlyHS_C5 VSS MD3_DlyHS_8 10p IC=0V
V_MD3_DlyHS_VCC2 MD3_DlyHS_12 VSS 5V
S_MD3_DlyHS_N2 MD3_DlyHS_9 VSS MD3_DlyHS_6 VSS _MD3_DlyHS_N2
RS_MD3_DlyHS_N2 MD3_DlyHS_6 VSS 1G
.MODEL _MD3_DlyHS_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
C_MD3_DlyHS_C4 VSS MD3_DlyHS_7 10p
E_MD3_DlyHS_ABM13 MD3_DlyHS_17 com VALUE { (1-EXP(-( {toffV1}+({toffV3}-
+ {toffV1})/({V3}-{V1})*((V(MD3_DlyHS_1))-{V1}))/10/ 10n))/
+ (1-EXP(-( {toffV1}+({toffV3}-{toffV1})/({V3}-{V1})*({V2} -{V1}))/10/ 10n))
C_MD3_DlyLS_C VSS MD3_DlyLS_5 10n
S_MD3_DlyLS_delay_P MD3_DlyLS_20 MD3_DlyLS_5 MD3_DlyLS_2 VSS
+ _MD3_DlyLS_delay_P
RS_MD3_DlyLS_delay_P MD3_DlyLS_2 VSS 1G
.MODEL _MD3_DlyLS_delay_P VSWITCH Roff=1e6 Ron=10 Voff=4.99V Von=0.01V
S_MD3_DlyLS_delay_N MD3_DlyLS_5 VSS MD3_DlyLS_2 VSS _MD3_DlyLS_delay_N
RS_MD3_DlyLS_delay_N MD3_DlyLS_2 VSS 1G
.MODEL _MD3_DlyLS_delay_N VSWITCH Roff=1e6 Ron=10 Voff=0.01V Von=4.99V
S_MD3_DlyLS_P1 MD3_DlyLS_10 MD3_DlyLS_11 MD3_DlyLS_6 VSS _MD3_DlyLS_P1
RS_MD3_DlyLS_P1 MD3_DlyLS_6 VSS 1G
.MODEL _MD3_DlyLS_P1 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD3_DlyLS_P2 MD3_DlyLS_11 MD3_DlyLS_9 MD3_DlyLS_8 VSS _MD3_DlyLS_P2
RS_MD3_DlyLS_P2 MD3_DlyLS_8 VSS 1G
.MODEL _MD3_DlyLS_P2 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD3_DlyLS_N1 MD3_DlyLS_9 VSS MD3_DlyLS_8 VSS _MD3_DlyLS_N1
RS_MD3_DlyLS_N1 MD3_DlyLS_8 VSS 1G
.MODEL _MD3_DlyLS_N1 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
S_MD3_DlyLS_MP1 MD3_DlyLS_12 MD3_DlyLS_13 MD3_DlyLS_9 VSS
+ _MD3_DlyLS_MP1
RS_MD3_DlyLS_MP1 MD3_DlyLS_9 VSS 1G
.MODEL _MD3_DlyLS_MP1 VSWITCH Roff=1e6 Ron=1 Voff=4.9V Von=0.1V
S_MD3_DlyLS_MP2 MD3_DlyLS_13 MD3_DlyLS_8 MD3_DlyLS_7 VSS _MD3_DlyLS_MP2
RS_MD3_DlyLS_MP2 MD3_DlyLS_7 VSS 1G
.MODEL _MD3_DlyLS_MP2 VSWITCH Roff=1e6 Ron=1 Voff=4.9 Von=0.1
S_MD3_DlyLS_MN1 MD3_DlyLS_8 VSS MD3_DlyLS_7 VSS _MD3_DlyLS_MN1
RS_MD3_DlyLS_MN1 MD3_DlyLS_7 VSS 1G
.MODEL _MD3_DlyLS_MN1 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9
S_MD3_DlyLS_MN2 MD3_DlyLS_8 VSS MD3_DlyLS_9 VSS _MD3_DlyLS_MN2
RS_MD3_DlyLS_MN2 MD3_DlyLS_9 VSS 1G
.MODEL _MD3_DlyLS_MN2 VSWITCH Roff=1e6 Ron=1 Voff=0.1 Von=4.9
X_MD3_DlyLS_Comp1 MD3_DlyLS_5 MD3_DlyLS_18 MD3_DlyLS_7 com COMP
X_MD3_DlyLS_Comp2 MD3_DlyLS_3 MD3_DlyLS_5 MD3_DlyLS_6 com COMP
E_MD3_DlyLS_ABM5 MD3_DlyLS_21 com VALUE { (5-5*EXP(-{toffT2}/10/10n))
E_MD3_DlyLS_ABM14 MD3_DlyLS_19 com VALUE { (1-EXP(-( {toffVdd1}+(
+ 10n)) }
E_MD3_DlyLS_ABM31 MD3_DlyLS_18 com VALUE { ( V(MD3_DlyLS_21)
+ *V(MD3_DlyLS_17)
+ *V(MD3_DlyLS_19) ) }
E_MD3_DlyLS_ABM24 MD3_DlyLS_3 com VALUE { (EXP(-({tonVdd1}+({tonVdd3}-
+ {V1})*(V(VCC)-{V1}))/10/10n))/((EXP(-( {tonV1}+({tonV3}-{tonV1})/({V3}-{V1})*(
+ {V2}-{V1}))/10/10n))) }
V_MD3_DlyLS_V_delay MD3_DlyLS_20 VSS 5V
C_MD3_DlyLS_C3 VSS MD3_DlyLS_6 10p
V_MD3_DlyLS_VCC1 MD3_DlyLS_10 VSS 5V
C_MD3_DlyLS_C6 VSS MD3_DlyLS_9 10p IC=-5V
C_MD3_DlyLS_C5 VSS MD3_DlyLS_8 10p IC=0V
V_MD3_DlyLS_VCC2 MD3_DlyLS_12 VSS 5V
S_MD3_DlyLS_N2 MD3_DlyLS_9 VSS MD3_DlyLS_6 VSS _MD3_DlyLS_N2
RS_MD3_DlyLS_N2 MD3_DlyLS_6 VSS 1G
.MODEL _MD3_DlyLS_N2 VSWITCH Roff=1e6 Ron=1 Voff=0.1V Von=4.9V
C_MD3_DlyLS_C4 VSS MD3_DlyLS_7 10p
E_MD3_DlyLS_ABM13 MD3_DlyLS_17 com VALUE { (1-EXP(-( {toffV1}+({toffV3}-
+ {toffV1})/({V3}-{V1})*((V(VCC))-{V1}))/10/ 10n))/
.ENDS IR2110
.SUBCKT COMP 1 2 3 4
E1 5 4 VALUE={IF((V(1)>V(2)), V(4)+5V, V(4))}
R1 5 3 1
C1 3 4 10P
.ENDS
* Ports
* VDD: Logic Supply
* VSS: Logic Ground
+PARAMS:
+ V1=10 V2=15 V3=20
.MODEL diode25 d
+KF=0 AF=1
.MODEL diode525 d
+KF=0 AF=1
C_MD5_C com LO 10p
+ -V(VS) ) }
+ _MD3_DlyHS_MP1
+ 10n)) }
+ *V(MD3_DlyHS_17)
+ _MD3_DlyLS_MP1
+ 10n)) }
+ *V(MD3_DlyLS_17)
.ENDS IR2110
R1 5 3 1
C1 3 4 10P
.ENDS
*********************************************************************** Copyright(c)InternationalRectifier** IR2110:HighandLowSideDriver* * Ports* VDD:LogicSupply* HIN:LogicInputforHighSideGateDriverOutput(HO),inphase* SD: LogicInputforShutdown* LIN:LogicInputforLowSideGateDriverOutput(LO),inphase* VSS:LogicGround* VB: HighSideFloatingSupply* HO: HighSideGateDiverOutput* VS: HighSideFloatingSupplyReturn* VCC:LowSideSupply* LO: LowSideGateDriverOutput* COM:LowSideReturn** CreatedbyPspiceVersion8** DateCreated:03/25/2003************************************************************************** ThisbehavioralmodelwasdevelopedincompliancewithDataSheet* No.PD60147-Rexceptnotedbelow:* (1)Thereisnofrequencyeffectontemperature.* (2)Thepowerdissipationisdifferent.* (3)Thevaluesofoutputhigh/lowshortcircuitcurrentareadjusted* forthepropermodelingofturn-onrise/turn-offfalltime.* (4)The"Lowsidereturn(COM)"pinmustbegrounded.***********************************************************************.SUBCKTIR2110VDDHINSDLINVSSHOVBVSVCCCOMLO+PARAMS: + T1=-40T2=25T3=125+ V1=10V2=15V3=20+ tonT1=90ntonT2=120ntonT3=170n+ tonV1=140ntonV2=120ntonV3=100n+ toffT1=77ntoffT2=94ntoffT3=130n+ toffV1=115ntoffV2=94ntoffV3=75n+ tonVdd1=125ntonVdd2=120ntonVdd3=115n+ toffVdd1=113ntoffVdd2=94ntoffVdd3=72n.MODELdiode25d+IS=1.0e-14RS=0.01N=1EG=1.11+XTI=3BV=25IBV=0.0001CJO=0+VJ=0.75M=0.333FC=0.5TT=0+KF=0AF=1.MODELdiode525d+IS=1.0e-14RS=0.01N=1EG=1.11+XTI=3BV=525IBV=0.0001CJO=0+VJ=0.75M=0.333FC=0.5TT=0+KF=0AF=1C_MD1_C2 VSSMD2_Nor3b_2 10p C_MD1_C3 VSSMD2_Inv2_1 10p C_MD1_C1 VSSMD2_Inv1_1 1n D_MD1_D2 VSSHINdiode25D_MD1_D3 SDVDDdiode25D_MD1_D4 VSSSDdiode25D_MD1_D5 LINVDDdiode25D_MD1_D6 VSSLINdiode25D_MD1_D7 VSSVDDdiode25D_MD1_D1 HINVDDdiode25C_MD1_Trig3_CTrig VSSMD2_Inv2_1 10p R_MD1_Trig3_R1Trig MD1_Trig3_3VDD 100Meg R_MD1_Trig3_R2Trig MD1_Trig3_4MD1_Trig3_3 66.7Meg R_MD1_Trig3_R3Trig VSSMD1_Trig3_4 106.1Meg X_MD1_Trig3_Comp LINMD1_Trig3_3MD2_Inv2_1comCOMPS_MD1_Trig3_PTrig MD1_Trig3_4VSSMD2_Inv2_1VSS_MD1_Trig3_PTrigRS_MD1_Trig3_PTrig MD2_Inv2_1VSS1G.MODEL _MD1_Trig3_PTrigVSWITCHRoff=1e9Ron=1Voff=0.01Von=4.99R_MD1_R1 VSSHIN750kTC=-0.00783811,0.0000372046R_MD1_R2 VSSSD750kTC=-0.00783811,0.0000372046C_MD1_Trig1_CTrig VSSMD2_Inv1_1 10p R_MD1_Trig1_R1Trig MD1_Trig1_3VDD 100Meg R_MD1_Trig1_R2Trig MD1_Trig1_4MD1_Trig1_3 66.7Meg R_MD1_Trig1_R3Trig VSSMD1_Trig1_4 106.1Meg X_MD1_Trig1_Comp HINMD1_Trig1_3MD2_Inv1_1comCOMPS_MD1_Trig1_PTrig MD1_Trig1_4VSSMD2_Inv1_1VSS_MD1_Trig1_PTrigRS_MD1_Trig1_PTrig MD2_Inv1_1VSS1G.MODEL _MD1_Trig1_PTrigVSWITCHRoff=1e9Ron=1Voff=0.01Von=4.99C_MD1_Trig2_CTrig VSSMD2_Nor3b_2 10p R_MD1_Trig2_R1Trig MD1_Trig2_3VDD 100Meg R_MD1_Trig2_R2Trig MD1_Trig2_4MD1_Trig2_3 66.7Meg R_MD1_Trig2_R3Trig VSSMD1_Trig2_4 106.1Meg X_MD1_Trig2_Comp SDMD1_Trig2_3MD2_Nor3b_2comCOMPS_MD1_Trig2_PTrig MD1_Trig2_4VSSMD2_Nor3b_2VSS_MD1_Trig2_PTrigRS_MD1_Trig2_PTrig MD2_Nor3b_2VSS1G.MODEL _MD1_Trig2_PTrigVSWITCHRoff=1e9Ron=1Voff=0.01Von=4.99R_MD1_R3 VSSLIN750kTC=-0.00783811,0.0000372046R_MD1_R4 VSSVDD7.5MegTC=-0.00505291,0.0000236999C_MD2_C1 VSSMD3_DlyHS_2 10pIC=0C_MD2_C2 VSSMD3_DlyLS_2 10pIC=0V_MD2_Inv1_V MD2_Inv1_2VSS5VC_MD2_Inv1_C VSSMD2_Nor3a_3 1p S_MD2_Inv1_P MD2_Inv1_2MD2_Nor3a_3MD2_Inv1_1VSS_MD2_Inv1_PRS_MD2_Inv1_P MD2_Inv1_1VSS1G.MODEL _MD2_Inv1_PVSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD2_Inv1_N MD2_Nor3a_3VSSMD2_Inv1_1VSS_MD2_Inv1_NRS_MD2_Inv1_N MD2_Inv1_1VSS1G.MODEL _MD2_Inv1_NVSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VV_MD2_Inv2_V MD2_Inv2_2VSS5VC_MD2_Inv2_C VSSMD2_Nor3b_1 1p S_MD2_Inv2_P MD2_Inv2_2MD2_Nor3b_1MD2_Inv2_1VSS_MD2_Inv2_PRS_MD2_Inv2_P MD2_Inv2_1VSS1G.MODEL _MD2_Inv2_PVSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD2_Inv2_N MD2_Nor3b_1VSSMD2_Inv2_1VSS_MD2_Inv2_NRS_MD2_Inv2_N MD2_Inv2_1VSS1G.MODEL _MD2_Inv2_NVSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VC_MD2_RS1_C7 MD2_RS1_6MD2_RS1_5 10p C_MD2_RS1_C2 VSSMD2_Nor3a_3 10pIC=0C_MD2_RS1_C3 VSSMD2_Nor3b_2 10pIC=0C_MD2_RS1_C10 MD2_RS1_7MD2_RS1_5 10p C_MD2_RS1_C11 MD2_RS1_3MD2_RS1_7 10p C_MD2_RS1_C12 VSSMD2_RS1_3 10p C_MD2_RS1_C9 VSSMD2_Nor3a_1 10p C_MD2_RS1_C8 MD2_Nor3a_1MD2_RS1_6 10p C_MD2_RS1_C1 VSSMD2_Nor3a_1 10pIC=0S_MD2_RS1_P1 MD2_RS1_5MD2_RS1_6MD2_Nor3a_3VSS_MD2_RS1_P1RS_MD2_RS1_P1 MD2_Nor3a_3VSS1G.MODEL _MD2_RS1_P1VSWITCHRoff=1e6Ron=1mVoff=4.9VVon=0.1VS_MD2_RS1_P2 MD2_RS1_6MD2_Nor3a_1MD2_RS1_3VSS_MD2_RS1_P2RS_MD2_RS1_P2 MD2_RS1_3VSS1G.MODEL _MD2_RS1_P2VSWITCHRoff=1e6Ron=1mVoff=4.9VVon=0.1VS_MD2_RS1_N1 MD2_Nor3a_1VSSMD2_RS1_3VSS_MD2_RS1_N1RS_MD2_RS1_N1 MD2_RS1_3VSS1G.MODEL _MD2_RS1_N1VSWITCHRoff=1e8Ron=1mVoff=0.1VVon=4.9VS_MD2_RS1_P3 MD2_RS1_5MD2_RS1_7MD2_Nor3b_2VSS_MD2_RS1_P3RS_MD2_RS1_P3 MD2_Nor3b_2VSS1G.MODEL _MD2_RS1_P3VSWITCHRoff=1e6Ron=1mVoff=4.9VVon=0.1VS_MD2_RS1_P4 MD2_RS1_7MD2_RS1_3MD2_Nor3a_1VSS_MD2_RS1_P4RS_MD2_RS1_P4 MD2_Nor3a_1VSS1G.MODEL _MD2_RS1_P4VSWITCHRoff=1e6Ron=1mVoff=4.9VVon=0.1VS_MD2_RS1_N3 MD2_RS1_3VSSMD2_Nor3b_2VSS_MD2_RS1_N3RS_MD2_RS1_N3 MD2_Nor3b_2VSS1G.MODEL _MD2_RS1_N3VSWITCHRoff=1e8Ron=1mVoff=0.1VVon=4.9VV_MD2_RS1_V1 MD2_RS1_5VSS5VS_MD2_RS1_N4 MD2_RS1_3VSSMD2_Nor3a_1VSS_MD2_RS1_N4RS_MD2_RS1_N4 MD2_Nor3a_1VSS1G.MODEL _MD2_RS1_N4VSWITCHRoff=1e8Ron=1mVoff=0.1VVon=4.9VS_MD2_RS1_N2 MD2_Nor3a_1VSSMD2_Nor3a_3VSS_MD2_RS1_N2RS_MD2_RS1_N2 MD2_Nor3a_3VSS1G.MODEL _MD2_RS1_N2VSWITCHRoff=1e8Ron=1mVoff=0.1VVon=4.9VC_MD2_RS2_C7 MD2_RS2_6MD2_RS2_5 10p C_MD2_RS2_C2 VSSMD2_Nor3b_1 10pIC=0C_MD2_RS2_C3 VSSMD2_Nor3b_2 10pIC=0C_MD2_RS2_C10 MD2_RS2_7MD2_RS2_5 10p C_MD2_RS2_C11 MD2_RS2_3MD2_RS2_7 10p C_MD2_RS2_C12 VSSMD2_RS2_3 10p C_MD2_RS2_C9 VSSMD2_Nor3b_3 10p C_MD2_RS2_C8 MD2_Nor3b_3MD2_RS2_6 10p C_MD2_RS2_C1 VSSMD2_Nor3b_3 10pIC=0S_MD2_RS2_P1 MD2_RS2_5MD2_RS2_6MD2_Nor3b_1VSS_MD2_RS2_P1RS_MD2_RS2_P1 MD2_Nor3b_1VSS1G.MODEL _MD2_RS2_P1VSWITCHRoff=1e6Ron=1mVoff=4.9VVon=0.1VS_MD2_RS2_P2 MD2_RS2_6MD2_Nor3b_3MD2_RS2_3VSS_MD2_RS2_P2RS_MD2_RS2_P2 MD2_RS2_3VSS1G.MODEL _MD2_RS2_P2VSWITCHRoff=1e6Ron=1mVoff=4.9VVon=0.1VS_MD2_RS2_N1 MD2_Nor3b_3VSSMD2_RS2_3VSS_MD2_RS2_N1RS_MD2_RS2_N1 MD2_RS2_3VSS1G.MODEL _MD2_RS2_N1VSWITCHRoff=1e8Ron=1mVoff=0.1VVon=4.9VS_MD2_RS2_P3 MD2_RS2_5MD2_RS2_7MD2_Nor3b_2VSS_MD2_RS2_P3RS_MD2_RS2_P3 MD2_Nor3b_2VSS1G.MODEL _MD2_RS2_P3VSWITCHRoff=1e6Ron=1mVoff=4.9VVon=0.1VS_MD2_RS2_P4 MD2_RS2_7MD2_RS2_3MD2_Nor3b_3VSS_MD2_RS2_P4RS_MD2_RS2_P4 MD2_Nor3b_3VSS1G.MODEL _MD2_RS2_P4VSWITCHRoff=1e6Ron=1mVoff=4.9VVon=0.1VS_MD2_RS2_N3 MD2_RS2_3VSSMD2_Nor3b_2VSS_MD2_RS2_N3RS_MD2_RS2_N3 MD2_Nor3b_2VSS1G.MODEL _MD2_RS2_N3VSWITCHRoff=1e8Ron=1mVoff=0.1VVon=4.9VV_MD2_RS2_V1 MD2_RS2_5VSS5VS_MD2_RS2_N4 MD2_RS2_3VSSMD2_Nor3b_3VSS_MD2_RS2_N4RS_MD2_RS2_N4 MD2_Nor3b_3VSS1G.MODEL _MD2_RS2_N4VSWITCHRoff=1e8Ron=1mVoff=0.1VVon=4.9VS_MD2_RS2_N2 MD2_Nor3b_3VSSMD2_Nor3b_1VSS_MD2_RS2_N2RS_MD2_RS2_N2 MD2_Nor3b_1VSS1G.MODEL _MD2_RS2_N2VSWITCHRoff=1e8Ron=1mVoff=0.1VVon=4.9VS_MD2_Nor3a_P1 MD2_Nor3a_4MD2_Nor3a_5MD2_Nor3a_1VSS_MD2_Nor3a_P1RS_MD2_Nor3a_P1 MD2_Nor3a_1VSS1G.MODEL _MD2_Nor3a_P1VSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD2_Nor3a_P2 MD2_Nor3a_5MD2_Nor3a_6MD2_Nor3b_2VSS_MD2_Nor3a_P2RS_MD2_Nor3a_P2 MD2_Nor3b_2VSS1G.MODEL _MD2_Nor3a_P2VSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD2_Nor3a_P3 MD2_Nor3a_6MD3_DlyHS_2MD2_Nor3a_3VSS_MD2_Nor3a_P3RS_MD2_Nor3a_P3 MD2_Nor3a_3VSS1G.MODEL _MD2_Nor3a_P3VSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD2_Nor3a_N1 MD3_DlyHS_2VSSMD2_Nor3b_2VSS_MD2_Nor3a_N1RS_MD2_Nor3a_N1 MD2_Nor3b_2VSS1G.MODEL _MD2_Nor3a_N1VSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VV_MD2_Nor3a_V MD2_Nor3a_4VSS5VS_MD2_Nor3a_N2 MD3_DlyHS_2VSSMD2_Nor3a_1VSS_MD2_Nor3a_N2RS_MD2_Nor3a_N2 MD2_Nor3a_1VSS1G.MODEL _MD2_Nor3a_N2VSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VS_MD2_Nor3a_N3 MD3_DlyHS_2VSSMD2_Nor3a_3VSS_MD2_Nor3a_N3RS_MD2_Nor3a_N3 MD2_Nor3a_3VSS1G.MODEL _MD2_Nor3a_N3VSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VS_MD2_Nor3b_P1 MD2_Nor3b_4MD2_Nor3b_5MD2_Nor3b_1VSS_MD2_Nor3b_P1RS_MD2_Nor3b_P1 MD2_Nor3b_1VSS1G.MODEL _MD2_Nor3b_P1VSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD2_Nor3b_P2 MD2_Nor3b_5MD2_Nor3b_6MD2_Nor3b_2VSS_MD2_Nor3b_P2RS_MD2_Nor3b_P2 MD2_Nor3b_2VSS1G.MODEL _MD2_Nor3b_P2VSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD2_Nor3b_P3 MD2_Nor3b_6MD3_DlyLS_2MD2_Nor3b_3VSS_MD2_Nor3b_P3RS_MD2_Nor3b_P3 MD2_Nor3b_3VSS1G.MODEL _MD2_Nor3b_P3VSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD2_Nor3b_N1 MD3_DlyLS_2VSSMD2_Nor3b_2VSS_MD2_Nor3b_N1RS_MD2_Nor3b_N1 MD2_Nor3b_2VSS1G.MODEL _MD2_Nor3b_N1VSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VV_MD2_Nor3b_V MD2_Nor3b_4VSS5VS_MD2_Nor3b_N2 MD3_DlyLS_2VSSMD2_Nor3b_1VSS_MD2_Nor3b_N2RS_MD2_Nor3b_N2 MD2_Nor3b_1VSS1G.MODEL _MD2_Nor3b_N2VSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VS_MD2_Nor3b_N3 MD3_DlyLS_2VSSMD2_Nor3b_3VSS_MD2_Nor3b_N3RS_MD2_Nor3b_N3 MD2_Nor3b_3VSS1G.MODEL _MD2_Nor3b_N3VSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VD_MD5_D2 comLOdiode25D_MD5_D1 LOVCCdiode25C_MD5_C comLO 10p C_MD5_Uvcc_c1 MD5_Uvcc_2MD5_Uvcc_3 10n C_MD5_Uvcc_c2 MD5_Uvcc_4MD5_Uvcc_2 10n C_MD5_Uvcc_c3 comMD4_Inv5_1 10p E_MD5_Uvcc_ABM2 MD5_Uvcc_3com VALUE{8.3+(8.8-8.3)/(125+40)*(TEMP+40) + }E_MD5_Uvcc_ABM3 MD5_Uvcc_4com VALUE{8.0+(8.5-8.0)/(125+40)*(TEMP+40) + }X_MD5_Uvcc_Comp VCCMD5_Uvcc_2MD4_Inv5_1comCOMPS_MD5_Uvcc_P MD5_Uvcc_3MD5_Uvcc_2MD4_Inv5_1com_MD5_Uvcc_PRS_MD5_Uvcc_P MD4_Inv5_1com1G.MODEL _MD5_Uvcc_PVSWITCHRoff=1e6Ron=1Voff=4.99Von=0.01S_MD5_Uvcc_N MD5_Uvcc_2MD5_Uvcc_4MD4_Inv5_1com_MD5_Uvcc_NRS_MD5_Uvcc_N MD4_Inv5_1com1G.MODEL _MD5_Uvcc_NVSWITCHRoff=1e6Ron=1Voff=0.01Von=4.99S_MD5_Nand_P1 MD5_Nand_5MD5_OLS_1MD4_Inv5_1VSS_MD5_Nand_P1RS_MD5_Nand_P1 MD4_Inv5_1VSS1G.MODEL _MD5_Nand_P1VSWITCHRoff=1e6Ron=1Voff=4.9Von=0.1S_MD5_Nand_N1 MD5_OLS_1MD5_Nand_4MD3_DlyLS_8VSS_MD5_Nand_N1RS_MD5_Nand_N1 MD3_DlyLS_8VSS1G.MODEL _MD5_Nand_N1VSWITCHRoff=1e6Ron=1Voff=0.1Von=4.9S_MD5_Nand_P2 MD5_Nand_5MD5_OLS_1MD3_DlyLS_8VSS_MD5_Nand_P2RS_MD5_Nand_P2 MD3_DlyLS_8VSS1G.MODEL _MD5_Nand_P2VSWITCHRoff=1e6Ron=1Voff=4.9Von=0.1V_MD5_Nand_V MD5_Nand_5VSS5VS_MD5_Nand_N2 MD5_Nand_4VSSMD4_Inv5_1VSS_MD5_Nand_N2RS_MD5_Nand_N2 MD4_Inv5_1VSS1G.MODEL _MD5_Nand_N2VSWITCHRoff=1e6Ron=1Voff=0.1Von=4.9S_MD5_OLS_P VCCMD5_OLS_2MD5_OLS_1com_MD5_OLS_PRS_MD5_OLS_P MD5_OLS_1com1G.MODEL _MD5_OLS_PVSWITCHRoff=1e9Ron=1mVoff=4.9Von=0.1S_MD5_OLS_N MD5_OLS_3comMD5_OLS_1com_MD5_OLS_NRS_MD5_OLS_N MD5_OLS_1com1G.MODEL _MD5_OLS_NVSWITCHRoff=1e9Ron=1mVoff=0.1Von=4.9R_MD5_OLS_R6 LOMD5_OLS_211.4TC=0.00190676,9.3240e-07R_MD5_OLS_R7 MD5_OLS_3LO7.76TC=0.00241396,2.331e-06R_MD5_R comVCC83.3kTC=-0.00358599,0.0000124556D_MD5_D3 comVCCdiode25D_MD4_D2 HOVBdiode25D_MD4_D1 VSVBdiode25D_MD4_D4 comVBdiode525D_MD4_D5 comVSdiode525D_MD4_D3 VSHOdiode25C_MD4_C3 VSHO 10pIC=0C_MD4_Uvbs_c1 MD4_Uvbs_2MD4_Uvbs_4 10n C_MD4_Uvbs_c2 MD4_Uvbs_5MD4_Uvbs_2 10n C_MD4_Uvbs_c3 comMD4_Inv4_1 10p E_MD4_Uvbs_ABM18 MD4_Uvbs_4com VALUE{+ V(VS)+8.4+(8.9-8.4)/(125+40)*(TEMP+40) }E_MD4_Uvbs_ABM19 MD4_Uvbs_5com VALUE{+ V(VS)+8.0+(8.45-8.0)/(125+40)*(TEMP+40) }X_MD4_Uvbs_Comp VBMD4_Uvbs_2MD4_Inv4_1comCOMPS_MD4_Uvbs_P MD4_Uvbs_4MD4_Uvbs_2MD4_Inv4_1com_MD4_Uvbs_PRS_MD4_Uvbs_P MD4_Inv4_1com1G.MODEL _MD4_Uvbs_PVSWITCHRoff=1e6Ron=1Voff=4.99Von=0.01S_MD4_Uvbs_N MD4_Uvbs_2MD4_Uvbs_5MD4_Inv4_1com_MD4_Uvbs_NRS_MD4_Uvbs_N MD4_Inv4_1com1G.MODEL _MD4_Uvbs_NVSWITCHRoff=1e6Ron=1Voff=0.01Von=4.99V_MD4_Inv3_V MD4_Inv3_2VSS5VC_MD4_Inv3_C VSSMD4_OHS_1 1p S_MD4_Inv3_P MD4_Inv3_2MD4_OHS_1MD4_RS_4VSS_MD4_Inv3_PRS_MD4_Inv3_P MD4_RS_4VSS1G.MODEL _MD4_Inv3_PVSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD4_Inv3_N MD4_OHS_1VSSMD4_RS_4VSS_MD4_Inv3_NRS_MD4_Inv3_N MD4_RS_4VSS1G.MODEL _MD4_Inv3_NVSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VC_MD4_RS_C7 MD4_RS_6MD4_RS_5 10p C_MD4_RS_C2 VSSMD4_Inv2_3 10pIC=0C_MD4_RS_C3 VSSMD3_DlyHS_8 10pIC=0C_MD4_RS_C10 MD4_RS_7MD4_RS_5 10p C_MD4_RS_C11 MD4_RS_3MD4_RS_7 10p C_MD4_RS_C12 VSSMD4_RS_3 10p C_MD4_RS_C9 VSSMD4_RS_4 10p C_MD4_RS_C8 MD4_RS_4MD4_RS_6 10p C_MD4_RS_C1 VSSMD4_RS_4 10pIC=0S_MD4_RS_P1 MD4_RS_5MD4_RS_6MD4_Inv2_3VSS_MD4_RS_P1RS_MD4_RS_P1 MD4_Inv2_3VSS1G.MODEL _MD4_RS_P1VSWITCHRoff=1e6Ron=1mVoff=4.9VVon=0.1VS_MD4_RS_P2 MD4_RS_6MD4_RS_4MD4_RS_3VSS_MD4_RS_P2RS_MD4_RS_P2 MD4_RS_3VSS1G.MODEL _MD4_RS_P2VSWITCHRoff=1e6Ron=1mVoff=4.9VVon=0.1VS_MD4_RS_N1 MD4_RS_4VSSMD4_RS_3VSS_MD4_RS_N1RS_MD4_RS_N1 MD4_RS_3VSS1G.MODEL _MD4_RS_N1VSWITCHRoff=1e8Ron=1mVoff=0.1VVon=4.9VS_MD4_RS_P3 MD4_RS_5MD4_RS_7MD3_DlyHS_8VSS_MD4_RS_P3RS_MD4_RS_P3 MD3_DlyHS_8VSS1G.MODEL _MD4_RS_P3VSWITCHRoff=1e6Ron=1mVoff=4.9VVon=0.1VS_MD4_RS_P4 MD4_RS_7MD4_RS_3MD4_RS_4VSS_MD4_RS_P4RS_MD4_RS_P4 MD4_RS_4VSS1G.MODEL _MD4_RS_P4VSWITCHRoff=1e6Ron=1mVoff=4.9VVon=0.1VS_MD4_RS_N3 MD4_RS_3VSSMD3_DlyHS_8VSS_MD4_RS_N3RS_MD4_RS_N3 MD3_DlyHS_8VSS1G.MODEL _MD4_RS_N3VSWITCHRoff=1e8Ron=1mVoff=0.1VVon=4.9VV_MD4_RS_V1 MD4_RS_5VSS5VS_MD4_RS_N4 MD4_RS_3VSSMD4_RS_4VSS_MD4_RS_N4RS_MD4_RS_N4 MD4_RS_4VSS1G.MODEL _MD4_RS_N4VSWITCHRoff=1e8Ron=1mVoff=0.1VVon=4.9VS_MD4_RS_N2 MD4_RS_4VSSMD4_Inv2_3VSS_MD4_RS_N2RS_MD4_RS_N2 MD4_Inv2_3VSS1G.MODEL _MD4_RS_N2VSWITCHRoff=1e8Ron=1mVoff=0.1VVon=4.9VV_MD4_Inv2_V MD4_Inv2_2VSS5VC_MD4_Inv2_C VSSMD4_Inv2_3 1p S_MD4_Inv2_P MD4_Inv2_2MD4_Inv2_3MD4_Nor1_5VSS_MD4_Inv2_PRS_MD4_Inv2_P MD4_Nor1_5VSS1G.MODEL _MD4_Inv2_PVSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD4_Inv2_N MD4_Inv2_3VSSMD4_Nor1_5VSS_MD4_Inv2_NRS_MD4_Inv2_N MD4_Nor1_5VSS1G.MODEL _MD4_Inv2_NVSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VV_MD4_Inv1_V MD4_Inv1_2VSS5VC_MD4_Inv1_C VSSMD4_Nor1_1 1p S_MD4_Inv1_P MD4_Inv1_2MD4_Nor1_1MD3_DlyHS_8VSS_MD4_Inv1_PRS_MD4_Inv1_P MD3_DlyHS_8VSS1G.MODEL _MD4_Inv1_PVSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD4_Inv1_N MD4_Nor1_1VSSMD3_DlyHS_8VSS_MD4_Inv1_NRS_MD4_Inv1_N MD3_DlyHS_8VSS1G.MODEL _MD4_Inv1_NVSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VV_MD4_Inv4_V MD4_Inv4_2VSS5VC_MD4_Inv4_C VSSMD4_Nor2_2 1p S_MD4_Inv4_P MD4_Inv4_2MD4_Nor2_2MD4_Inv4_1VSS_MD4_Inv4_PRS_MD4_Inv4_P MD4_Inv4_1VSS1G.MODEL _MD4_Inv4_PVSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD4_Inv4_N MD4_Nor2_2VSSMD4_Inv4_1VSS_MD4_Inv4_NRS_MD4_Inv4_N MD4_Inv4_1VSS1G.MODEL _MD4_Inv4_NVSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VV_MD4_Nor1_V MD4_Nor1_3VSS5VS_MD4_Nor1_P1 MD4_Nor1_3MD4_Nor1_4MD4_Nor1_1VSS_MD4_Nor1_P1RS_MD4_Nor1_P1 MD4_Nor1_1VSS1G.MODEL _MD4_Nor1_P1VSWITCHRoff=1e6Ron=1Voff=4.9Von=0.1S_MD4_Nor1_P2 MD4_Nor1_4MD4_Nor1_5MD4_Inv6_3VSS_MD4_Nor1_P2RS_MD4_Nor1_P2 MD4_Inv6_3VSS1G.MODEL _MD4_Nor1_P2VSWITCHRoff=1e6Ron=1Voff=4.9Von=0.1S_MD4_Nor1_N1 MD4_Nor1_5VSSMD4_Inv6_3VSS_MD4_Nor1_N1RS_MD4_Nor1_N1 MD4_Inv6_3VSS1G.MODEL _MD4_Nor1_N1VSWITCHRoff=1e6Ron=1Voff=0.1Von=4.9S_MD4_Nor1_N2 MD4_Nor1_5VSSMD4_Nor1_1VSS_MD4_Nor1_N2RS_MD4_Nor1_N2 MD4_Nor1_1VSS1G.MODEL _MD4_Nor1_N2VSWITCHRoff=1e6Ron=1Voff=0.1Von=4.9V_MD4_Inv5_V MD4_Inv5_2VSS5VC_MD4_Inv5_C VSSMD4_Nor2_1 1p S_MD4_Inv5_P MD4_Inv5_2MD4_Nor2_1MD4_Inv5_1VSS_MD4_Inv5_PRS_MD4_Inv5_P MD4_Inv5_1VSS1G.MODEL _MD4_Inv5_PVSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD4_Inv5_N MD4_Nor2_1VSSMD4_Inv5_1VSS_MD4_Inv5_NRS_MD4_Inv5_N MD4_Inv5_1VSS1G.MODEL _MD4_Inv5_NVSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VV_MD4_Nor2_V MD4_Nor2_3VSS5VS_MD4_Nor2_P1 MD4_Nor2_3MD4_Nor2_4MD4_Nor2_1VSS_MD4_Nor2_P1RS_MD4_Nor2_P1 MD4_Nor2_1VSS1G.MODEL _MD4_Nor2_P1VSWITCHRoff=1e6Ron=1Voff=4.9Von=0.1S_MD4_Nor2_P2 MD4_Nor2_4MD4_Inv6_1MD4_Nor2_2VSS_MD4_Nor2_P2RS_MD4_Nor2_P2 MD4_Nor2_2VSS1G.MODEL _MD4_Nor2_P2VSWITCHRoff=1e6Ron=1Voff=4.9Von=0.1S_MD4_Nor2_N1 MD4_Inv6_1VSSMD4_Nor2_2VSS_MD4_Nor2_N1RS_MD4_Nor2_N1 MD4_Nor2_2VSS1G.MODEL _MD4_Nor2_N1VSWITCHRoff=1e6Ron=1Voff=0.1Von=4.9S_MD4_Nor2_N2 MD4_Inv6_1VSSMD4_Nor2_1VSS_MD4_Nor2_N2RS_MD4_Nor2_N2 MD4_Nor2_1VSS1G.MODEL _MD4_Nor2_N2VSWITCHRoff=1e6Ron=1Voff=0.1Von=4.9V_MD4_Inv6_V MD4_Inv6_2VSS5VC_MD4_Inv6_C VSSMD4_Inv6_3 1p S_MD4_Inv6_P MD4_Inv6_2MD4_Inv6_3MD4_Inv6_1VSS_MD4_Inv6_PRS_MD4_Inv6_P MD4_Inv6_1VSS1G.MODEL _MD4_Inv6_PVSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD4_Inv6_N MD4_Inv6_3VSSMD4_Inv6_1VSS_MD4_Inv6_NRS_MD4_Inv6_N MD4_Inv6_1VSS1G.MODEL _MD4_Inv6_NVSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VR_MD4_R1 VSVB120kTC=-0.00135415,-2.516e-7S_MD4_OHS_P VBMD4_OHS_2MD4_OHS_1com_MD4_OHS_PRS_MD4_OHS_P MD4_OHS_1com1G.MODEL _MD4_OHS_PVSWITCHRoff=1e9Ron=1mVoff=4.9Von=0.1S_MD4_OHS_N MD4_OHS_3VSMD4_OHS_1com_MD4_OHS_NRS_MD4_OHS_N MD4_OHS_1com1G.MODEL _MD4_OHS_NVSWITCHRoff=1e9Ron=1mVoff=0.1Von=4.9R_MD4_OHS_R6 HOMD4_OHS_211.4TC=0.00190676,9.3240e-07R_MD4_OHS_R7 MD4_OHS_3HO7.76TC=0.00241396,2.331e-06C_MD3_C1 comMD3_DlyHS_8 10p C_MD3_C2 comMD3_DlyLS_8 10p E_MD3_ABM21 MD3_DlyHS_1com VALUE{(V(VB) +-V(VS)) }C_MD3_DlyHS_C VSSMD3_DlyHS_5 10n S_MD3_DlyHS_delay_P MD3_DlyHS_20MD3_DlyHS_5MD3_DlyHS_2VSS+ _MD3_DlyHS_delay_PRS_MD3_DlyHS_delay_P MD3_DlyHS_2VSS1G.MODEL _MD3_DlyHS_delay_PVSWITCHRoff=1e6Ron=10Voff=4.99VVon=0.01VS_MD3_DlyHS_delay_N MD3_DlyHS_5VSSMD3_DlyHS_2VSS_MD3_DlyHS_delay_NRS_MD3_DlyHS_delay_N MD3_DlyHS_2VSS1G.MODEL _MD3_DlyHS_delay_NVSWITCHRoff=1e6Ron=10Voff=0.01VVon=4.99VS_MD3_DlyHS_P1 MD3_DlyHS_10MD3_DlyHS_11MD3_DlyHS_6VSS_MD3_DlyHS_P1RS_MD3_DlyHS_P1 MD3_DlyHS_6VSS1G.MODEL _MD3_DlyHS_P1VSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD3_DlyHS_P2 MD3_DlyHS_11MD3_DlyHS_9MD3_DlyHS_8VSS_MD3_DlyHS_P2RS_MD3_DlyHS_P2 MD3_DlyHS_8VSS1G.MODEL _MD3_DlyHS_P2VSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD3_DlyHS_N1 MD3_DlyHS_9VSSMD3_DlyHS_8VSS_MD3_DlyHS_N1RS_MD3_DlyHS_N1 MD3_DlyHS_8VSS1G.MODEL _MD3_DlyHS_N1VSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VS_MD3_DlyHS_MP1 MD3_DlyHS_12MD3_DlyHS_13MD3_DlyHS_9VSS+ _MD3_DlyHS_MP1RS_MD3_DlyHS_MP1 MD3_DlyHS_9VSS1G.MODEL _MD3_DlyHS_MP1VSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD3_DlyHS_MP2 MD3_DlyHS_13MD3_DlyHS_8MD3_DlyHS_7VSS_MD3_DlyHS_MP2RS_MD3_DlyHS_MP2 MD3_DlyHS_7VSS1G.MODEL _MD3_DlyHS_MP2VSWITCHRoff=1e6Ron=1Voff=4.9Von=0.1S_MD3_DlyHS_MN1 MD3_DlyHS_8VSSMD3_DlyHS_7VSS_MD3_DlyHS_MN1RS_MD3_DlyHS_MN1 MD3_DlyHS_7VSS1G.MODEL _MD3_DlyHS_MN1VSWITCHRoff=1e6Ron=1Voff=0.1Von=4.9S_MD3_DlyHS_MN2 MD3_DlyHS_8VSSMD3_DlyHS_9VSS_MD3_DlyHS_MN2RS_MD3_DlyHS_MN2 MD3_DlyHS_9VSS1G.MODEL _MD3_DlyHS_MN2VSWITCHRoff=1e6Ron=1Voff=0.1Von=4.9X_MD3_DlyHS_Comp1 MD3_DlyHS_5MD3_DlyHS_18MD3_DlyHS_7comCOMPX_MD3_DlyHS_Comp2 MD3_DlyHS_3MD3_DlyHS_5MD3_DlyHS_6comCOMPE_MD3_DlyHS_ABM5 MD3_DlyHS_21com VALUE{(5-5*EXP(-{toffT2}/10/10n)) +*(5-5*EXP(-({toffT1}+({toffT3}-{toffT1})/({T3}-{T1})*(TEMP-{T1}))/10/10n))+ +/(5-5*EXP(-({toffT1}+({toffT3}-{toffT1})/({T3}-{T1})*({T2}-{T1}))/10/10n))+ }E_MD3_DlyHS_ABM14 MD3_DlyHS_19com VALUE{(1-EXP(-({toffVdd1}+(+{toffVdd3}-{toffVdd1})/({V3}-{V1})*(V(VDD)-{V1}))/10/10n))/ +(1-EXP(-({toffVdd1}+({toffVdd3}-{toffVdd1})/({V3}-{V1})*({V2} -{V1}))/10/+ 10n)) }E_MD3_DlyHS_ABM31 MD3_DlyHS_18com VALUE{(V(MD3_DlyHS_21) +*V(MD3_DlyHS_17) +*V(MD3_DlyHS_19)) }E_MD3_DlyHS_ABM24 MD3_DlyHS_3com VALUE{(EXP(-({tonVdd1}+({tonVdd3}-+{tonVdd1})/({V3}-{V1})*(V(VDD)-{V1}))/10/10n))/((EXP(-({tonVdd1}+({tonVdd3}-+{tonVdd1})/({V3}-{V1})*({V2}- {V1}))/10/10n))) +*(5*EXP(-({tonT1}+({tonT3}-{tonT1})/({T3}-{T1})*(TEMP-{T1}))/10/+ 10n))/(5*EXP(-({tonT1}+({tonT3}-{tonT1})/({T3}-{T1})*({T2}-{T1}))/10/+ 10n))*5*EXP(-{tonT2}/10/10n)*(EXP(-({tonV1}+({tonV3}-{tonV1})/({V3}-+{V1})*(V(MD3_DlyHS_1)-{V1}))/10/10n))/((EXP(-({tonV1}+({tonV3}-{tonV1})/({V3}-+{V1})*({V2}-{V1}))/10/10n))) }V_MD3_DlyHS_V_delay MD3_DlyHS_20VSS5VC_MD3_DlyHS_C3 VSSMD3_DlyHS_6 10p V_MD3_DlyHS_VCC1 MD3_DlyHS_10VSS5VC_MD3_DlyHS_C6 VSSMD3_DlyHS_9 10pIC=-5VC_MD3_DlyHS_C5 VSSMD3_DlyHS_8 10pIC=0VV_MD3_DlyHS_VCC2 MD3_DlyHS_12VSS5VS_MD3_DlyHS_N2 MD3_DlyHS_9VSSMD3_DlyHS_6VSS_MD3_DlyHS_N2RS_MD3_DlyHS_N2 MD3_DlyHS_6VSS1G.MODEL _MD3_DlyHS_N2VSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VC_MD3_DlyHS_C4 VSSMD3_DlyHS_7 10p E_MD3_DlyHS_ABM13 MD3_DlyHS_17com VALUE{(1-EXP(-({toffV1}+({toffV3}-+{toffV1})/({V3}-{V1})*((V(MD3_DlyHS_1))-{V1}))/10/10n))/ +(1-EXP(-({toffV1}+({toffV3}-{toffV1})/({V3}-{V1})*({V2} -{V1}))/10/10n))+ }C_MD3_DlyLS_C VSSMD3_DlyLS_5 10n S_MD3_DlyLS_delay_P MD3_DlyLS_20MD3_DlyLS_5MD3_DlyLS_2VSS+ _MD3_DlyLS_delay_PRS_MD3_DlyLS_delay_P MD3_DlyLS_2VSS1G.MODEL _MD3_DlyLS_delay_PVSWITCHRoff=1e6Ron=10Voff=4.99VVon=0.01VS_MD3_DlyLS_delay_N MD3_DlyLS_5VSSMD3_DlyLS_2VSS_MD3_DlyLS_delay_NRS_MD3_DlyLS_delay_N MD3_DlyLS_2VSS1G.MODEL _MD3_DlyLS_delay_NVSWITCHRoff=1e6Ron=10Voff=0.01VVon=4.99VS_MD3_DlyLS_P1 MD3_DlyLS_10MD3_DlyLS_11MD3_DlyLS_6VSS_MD3_DlyLS_P1RS_MD3_DlyLS_P1 MD3_DlyLS_6VSS1G.MODEL _MD3_DlyLS_P1VSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD3_DlyLS_P2 MD3_DlyLS_11MD3_DlyLS_9MD3_DlyLS_8VSS_MD3_DlyLS_P2RS_MD3_DlyLS_P2 MD3_DlyLS_8VSS1G.MODEL _MD3_DlyLS_P2VSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD3_DlyLS_N1 MD3_DlyLS_9VSSMD3_DlyLS_8VSS_MD3_DlyLS_N1RS_MD3_DlyLS_N1 MD3_DlyLS_8VSS1G.MODEL _MD3_DlyLS_N1VSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VS_MD3_DlyLS_MP1 MD3_DlyLS_12MD3_DlyLS_13MD3_DlyLS_9VSS+ _MD3_DlyLS_MP1RS_MD3_DlyLS_MP1 MD3_DlyLS_9VSS1G.MODEL _MD3_DlyLS_MP1VSWITCHRoff=1e6Ron=1Voff=4.9VVon=0.1VS_MD3_DlyLS_MP2 MD3_DlyLS_13MD3_DlyLS_8MD3_DlyLS_7VSS_MD3_DlyLS_MP2RS_MD3_DlyLS_MP2 MD3_DlyLS_7VSS1G.MODEL _MD3_DlyLS_MP2VSWITCHRoff=1e6Ron=1Voff=4.9Von=0.1S_MD3_DlyLS_MN1 MD3_DlyLS_8VSSMD3_DlyLS_7VSS_MD3_DlyLS_MN1RS_MD3_DlyLS_MN1 MD3_DlyLS_7VSS1G.MODEL _MD3_DlyLS_MN1VSWITCHRoff=1e6Ron=1Voff=0.1Von=4.9S_MD3_DlyLS_MN2 MD3_DlyLS_8VSSMD3_DlyLS_9VSS_MD3_DlyLS_MN2RS_MD3_DlyLS_MN2 MD3_DlyLS_9VSS1G.MODEL _MD3_DlyLS_MN2VSWITCHRoff=1e6Ron=1Voff=0.1Von=4.9X_MD3_DlyLS_Comp1 MD3_DlyLS_5MD3_DlyLS_18MD3_DlyLS_7comCOMPX_MD3_DlyLS_Comp2 MD3_DlyLS_3MD3_DlyLS_5MD3_DlyLS_6comCOMPE_MD3_DlyLS_ABM5 MD3_DlyLS_21com VALUE{(5-5*EXP(-{toffT2}/10/10n)) +*(5-5*EXP(-({toffT1}+({toffT3}-{toffT1})/({T3}-{T1})*(TEMP-{T1}))/10/10n))+ +/(5-5*EXP(-({toffT1}+({toffT3}-{toffT1})/({T3}-{T1})*({T2}-{T1}))/10/10n))+ }E_MD3_DlyLS_ABM14 MD3_DlyLS_19com VALUE{(1-EXP(-({toffVdd1}+(+{toffVdd3}-{toffVdd1})/({V3}-{V1})*(V(VDD)-{V1}))/10/10n))/ +(1-EXP(-({toffVdd1}+({toffVdd3}-{toffVdd1})/({V3}-{V1})*({V2} -{V1}))/10/+ 10n)) }E_MD3_DlyLS_ABM31 MD3_DlyLS_18com VALUE{(V(MD3_DlyLS_21) +*V(MD3_DlyLS_17) +*V(MD3_DlyLS_19)) }E_MD3_DlyLS_ABM24 MD3_DlyLS_3com VALUE{(EXP(-({tonVdd1}+({tonVdd3}-+{tonVdd1})/({V3}-{V1})*(V(VDD)-{V1}))/10/10n))/((EXP(-({tonVdd1}+({tonVdd3}-+{tonVdd1})/({V3}-{V1})*({V2}- {V1}))/10/10n))) +*(5*EXP(-({tonT1}+({tonT3}-{tonT1})/({T3}-{T1})*(TEMP-{T1}))/10/+ 10n))/(5*EXP(-({tonT1}+({tonT3}-{tonT1})/({T3}-{T1})*({T2}-{T1}))/10/+ 10n))*5*EXP(-{tonT2}/10/10n)*(EXP(-({tonV1}+({tonV3}-{tonV1})/({V3}-+{V1})*(V(VCC)-{V1}))/10/10n))/((EXP(-({tonV1}+({tonV3}-{tonV1})/({V3}-{V1})*(+{V2}-{V1}))/10/10n))) }V_MD3_DlyLS_V_delay MD3_DlyLS_20VSS5VC_MD3_DlyLS_C3 VSSMD3_DlyLS_6 10p V_MD3_DlyLS_VCC1 MD3_DlyLS_10VSS5VC_MD3_DlyLS_C6 VSSMD3_DlyLS_9 10pIC=-5VC_MD3_DlyLS_C5 VSSMD3_DlyLS_8 10pIC=0VV_MD3_DlyLS_VCC2 MD3_DlyLS_12VSS5VS_MD3_DlyLS_N2 MD3_DlyLS_9VSSMD3_DlyLS_6VSS_MD3_DlyLS_N2RS_MD3_DlyLS_N2 MD3_DlyLS_6VSS1G.MODEL _MD3_DlyLS_N2VSWITCHRoff=1e6Ron=1Voff=0.1VVon=4.9VC_MD3_DlyLS_C4 VSSMD3_DlyLS_7 10p E_MD3_DlyLS_ABM13 MD3_DlyLS_17com VALUE{(1-EXP(-({toffV1}+({toffV3}-+{toffV1})/({V3}-{V1})*((V(VCC))-{V1}))/10/10n))/ +(1-EXP(-({toffV1}+({toffV3}-{toffV1})/({V3}-{V1})*({V2} -{V1}))/10/10n))+ }.ENDS IR2110.SUBCKTCOMP1234E154VALUE={IF((V(1)>V(2)),V(4)+5V,V(4))}R1531C13410P.ENDS
R1 5 3 1
C1 3 4 10P
R1 5 3 1
C1 3 4 10P
.ENDS
这几行是什么意思啊?菜鸟求指教
为什么仿真会出现
------ Checking SPICE netlist for Circuit1 - 2013-10-11 16:06:09 ------
SPICE Netlist Error in schematic RefDes u1, element xu1: Invalid subckt definition name 5
======= SPICE Netlist check completed, 2 error(s), 0 warning(s) =======
这一问题啊??
@158112510
为什么仿真会出现------CheckingSPICEnetlistforCircuit1-2013-10-1116:06:09------ SPICENetlistErrorinschematicRefDesu1,elementxu1: Invalidsubcktdefinitionname5SPICENetlistErrorinschematicRefDesu1,element: Duetoerrors,thesubcktinstancexu1hasbeenomittedfromthesimulation=======SPICENetlistcheckcompleted,2error(s),0warning(s)======= 这一问题啊??
跪求解答啊
