Cadence OrCAD 10 Instalation Notes
1- Run MakeLic to make a node locked license or MakeFloatLic for a floating one...
I really recomend using the nodelocked, so you will not have to set services.
Or you may just use the attached ones.
2- It will create the required license.dat file to enable ALL cadence products
and open it on notepad. Save it to a place you will remember. If you already
use the c:\flexlm folder save it there as ORCAD.DAT or other folder you normally
save your licenses. You may also append to your current LICENSE.DAT, but remember
to strip out the server and daemon lines, you dont need them, just for setup.
3- A copy of this license will be also saved as C:\INSTALLINFO.TXT
4- Now run the setup.exe from the Orcad CD.
5- Skip step 1 and go straight to install software.
6- When asked about the INSTALLINFO.TXT, point to the one saved in your c:\
Leave port and server info as they are for now...
7- Install the products you need/want.
8- After installing, go to the folder you installed Orcad and open the compnts.dat file
Now, replace the SERVER1=27001@yorservername by the full path to the saved license
file, example:SERVER1=C:\CAD\SECURITY\LICENSES\OrCAD.DAT
9- Enjoy
我按上面的方法一步一步来的,但每次打开Orcad都会出现要验证licenses.而且,我从www.Orcad.com网站上下载的pspice的Schematics也不能用,每次都说打不开pspice AD.
求助Orcad 10.0 安装
全部回复(5)
1164622110.rar
我想这个附件应该是比较好的orCAD 的安装指南了.如果你不能down这个附件请联系我.
QQ: 39369274
Mail :joison-zhang@163.com
(欢迎技术交流 谢绝广告)
QQ: 39369274
(欢迎技术交流 谢绝广告)
