条件:同一块电源板,不同的变压器.变压器的每组线圈感抗一样,只有原边漏感不一样,其中一种是另外一种的1.8倍左右.拆离两种变压器分析,除了原边线圈绝缘胶带不一样外(原边为2层线圈,其中一种变压器在中间加了一层绝缘胶带隔离,漏感大;另外一种两层直接叠在一起,没加隔离,漏感小.),其他线圈绕向和每层线圈间绝缘胶带都一样.
2844输出波形如下:
![](http://u.dianyuan.com/bbs/u/80/145181249180489.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/145181249180489.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">图1
![](http://u.dianyuan.com/bbs/u/80/145181249180554.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/145181249180554.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">图2
![](http://u.dianyuan.com/bbs/u/80/145181249180626.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/145181249180626.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">图3
![](http://u.dianyuan.com/bbs/u/80/145181249180640.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/80/145181249180640.png?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">图4
图1黄色是2844的6脚输出,绿色是MOS管栅极输入,是漏感大的那种变压器;
图2黄色是2844的6脚输出,绿色是MOS管栅极输入,是漏感小的那种变压器;
图3是图2的展开波形,紫色是原边线圈波形,对应幅值高的那个脉冲;
图4是图2的展开波形,紫色是原边线圈波形,对应幅值低的那个脉冲.
想请教下图2,图3,图4的波形为什么会如此?因为两种变压器除了漏感之外,其他不同之处我没有找到,但是漏感会引起这样的变化么?我又不敢确定.
图4的波形似乎是MOS管没有开通完全,就突然关闭了.
测试时都没加负载,如果在主反馈上加0.1A负载,漏感小的那种变压器电压上升的幅值很大,±15V会升到17V左右.
有朋友能帮我讲解下这种波形的产生原因么?谢谢
