薄膜高精密度貼片電阻--介绍
薄膜高精密度貼片電阻 Thin Film Low Ohm Chip Resistor
阻值範圍 Resistance Range: 10R ohm – 1M ohm
Tolerance : +/-1% TCR. +/- 50ppm.
+/-0.1% TCR. +/- 25ppm
Type Size: 0402, 0603, 0805, 1206, 1210, 1218, 1812, 2010, 2512.
Thin Film Precision Chip Resistor (薄膜貼片電阻)
Size 規格: (0402),(0603), (0805), (1206), (1210),(2010), (2512).
Resistance Range 低阻值範圍: 10R ohm ~ 1M ohm
Tolerance 高度誤差率: ±0.1% , ±0.25%, ±0.5%, ±1%
Tighter tolerance 高精密度誤差率: ±0.05%, ±0.01%.
Thin Film TaN & Ni/Cr Conductor (材料)
TCR From 低溫度系数 ±25ppm ~ 50ppm for thin film chip resistor
Lower TCR 超低溫度系数 : 5ppm/ °C, 10ppm/°C, 15ppm / °C.
全部回复(0)
