1. Rated Voltage: 100V to 270V, AC
2. Rated Frequency (Tolarable variation) : 50Hz (48.5 Hz - 51.5 Hz)
3. Minimum Starting temperature : 4oC
4. Starting Time: 1.0 sec being switched on
5. Run up time: 2 mintues
6. Life time 10000 hrs
7. Total Harmonic Distortion: 50%
8. Power Factor: 0.95
9. Correlated color temperature:
10. Lumen: 60/watt
11. Mercury content: The mercury content in CFLs shall be less than 5 (Five) milligrams (mg) per unit.
12. Base: E27/B22
13. Watt: 9W, 15W & 23W
14. Tube: Spiral & Semi-spiral.
