求助:电批扭力规定
各位:谁有关于电批扭力相关规定,请提供.比如五金件用多大扭力?五金与塑料件之间需用多大扭力?本人不胜感受激!Email:czluo163@163.com或princeluo@scas.cn
求助:电批扭力规定
全部回复(5)
@zaiyi
有一個國際標准電批扭力標准的,請知道的仁兄給我一份.謝謝了E-mail:chen2720065@126.com
這是我們客戶的標准,供參考.
This Workmanship Standard.
ANSI/IPC-A-610 Class 2 Standard.
3.4.0 Notes:
Torque:
All devices, components and assemblies mounted with metal hardware (screws, nuts & bolts, etc) on PCB抯, including any devices or components mounted to heatsinks, will be tightened within the required torque ranges specified in Tables 1 to 3. The torque ranges are based on the material type and size of the hardware.
All Nylon 6/6 hardware used in PCB applications will be tightened within the required torque range specified in Table 4. The torque ranges are based on the size of the hardware.
In cases where metal and nylon hardware combinations are used, torque values will be based on the ratings for nylon ( Ref. Table 4 ).
TABLE 1 (Steel hardware, machine screws)
Screw size
in/lbf torque value range
Kgf-cm torque value range
#2-56
1-2.5 in-lbf
1.15-2.88 Kgf-cm
#4-40
3-5 in-lbf
3.45-5.76 Kgf-cm
#6-32
7-9 in-lbf
8.06-10.36 Kgf-cm
#8-32
15-18 in-lbf
17.28-20.73 Kgf-cm
#10-32
27-30 in-lbf
31.10-34.56 Kgf-cm
1/4-20
62-65 in-lbf
71.43-74.88 Kgf-cm
還有一些,不過都是英制螺絲.
3.4.0 Notes:
Torque:
Screw size
#2-56
1-2.5 in-lbf
1.15-2.88 Kgf-cm
#4-40
3-5 in-lbf
3.45-5.76 Kgf-cm
#6-32
7-9 in-lbf
8.06-10.36 Kgf-cm
#8-32
15-18 in-lbf
17.28-20.73 Kgf-cm
#10-32
27-30 in-lbf
31.10-34.56 Kgf-cm
1/4-20
62-65 in-lbf
71.43-74.88 Kgf-cm
還有一些,不過都是英制螺絲.
@webtianxia
這是我們客戶的標准,供參考.ThisWorkmanshipStandard.ANSI/IPC-A-610Class2Standard.3.4.0Notes:Torque:Alldevices,componentsandassembliesmountedwithmetalhardware(screws,nuts&bolts,etc)onPCB抯,includinganydevicesorcomponentsmountedtoheatsinks,willbetightenedwithintherequiredtorquerangesspecifiedinTables1to3.Thetorquerangesarebasedonthematerialtypeandsizeofthehardware.AllNylon6/6hardwareusedinPCBapplicationswillbetightenedwithintherequiredtorquerangespecifiedinTable4.Thetorquerangesarebasedonthesizeofthehardware.Incaseswheremetalandnylonhardwarecombinationsareused,torquevalueswillbebasedontheratingsfornylon(Ref.Table4).TABLE1(Steelhardware,machinescrews)Screwsizein/lbftorquevaluerangeKgf-cmtorquevaluerange#2-561-2.5in-lbf1.15-2.88Kgf-cm#4-403-5in-lbf3.45-5.76Kgf-cm#6-327-9in-lbf8.06-10.36Kgf-cm#8-3215-18in-lbf17.28-20.73Kgf-cm#10-3227-30in-lbf31.10-34.56Kgf-cm1/4-2062-65in-lbf71.43-74.88Kgf-cm還有一些,不過都是英制螺絲.
謝謝了!如果是英制螺絲也可以,給我好嗎?能發郵件最好.
