进口焊机故障,帮忙分析一下
林肯V350-PRO机
故障情况:
显示正常,烧三根焊条电压显示33V-70V不稳定,NO红灯不停闪烁;停焊20分钟后又可以焊2-3跟焊条
全部回复(16)
guofulin
可控硅有一个发热短路了,刚开机的时候空载是正常了,但焊了两三跟焊条后空载会下降,
@guofulin
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/1470091258943164.jpg');}" onmousewheel="return imgzoom(this);">500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/1470091258943197.jpg');}" onmousewheel="return imgzoom(this);">
@老焊工zx5
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/1470091258943164.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/1470091258943197.jpg');}"onmousewheel="returnimgzoom(this);">
真搞不清楚是开关板坏还是控制板坏还是其它什么原因
@老焊工zx5
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/1470091258944381.jpg');}" onmousewheel="return imgzoom(this);">
@老焊工zx5
@老焊工zx5
检查
@guofulin
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/1470091259036430.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/1470091259036517.jpg');}" onmousewheel="return imgzoom(this);">
正面
@老焊工zx5
[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/1470091259036430.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/1470091259036517.jpg');}"onmousewheel="returnimgzoom(this);">正面
那东西不好弄了,都是硅胶
焊联
@老焊工zx5
**此帖已被管理员删除**
焊联
@焊联
**此帖已被管理员删除**
**此帖已被管理员删除**
@焊联
**此帖已被管理员删除**
焊机有些年头了,说明书不见了,
电压正常,整流后550V,应该不是电源问题在另外场合问题是一样的.
焊联
@老焊工zx5
焊机有些年头了,说明书不见了,电压正常,整流后550V,应该不是电源问题在另外场合问题是一样的.
**此帖已被管理员删除**
南国
@焊联
**此帖已被管理员删除**
206和203=824欧
207和203=823欧
是在线放电后测量不知对不对
焊联
@南国
206和203=824欧207和203=823欧是在线放电后测量不知对不对
**此帖已被管理员删除**
@焊联
**此帖已被管理员删除**
不是信号线坏了就是开关板坏了 开关板的可能性大 自己修不好调试
33是两个电容电压不平衡故障,一个负载大一个负载小
