CROWBAR(in DC-DC CONVERTER)
An overvoltage protection circuit which monitors the
output voltage of a power supply and rapidly creates
a low resistance path across the output when a
predetermined voltage is exceeded.过压保护电路,监测输出电压,当输出电压超过标称值的时候迅速在输出端产生一个低阻抗通路;
