求助:一台杂牌LGK8-63等离子切割机起弧不良
一台杂牌LGK8-63等离子切割机,上海星翔有限公司育英分公司生产,故障是起弧不良,按下手把开关通气正常,放电器上有火花,火花强度比氩弧焊机的强多了,放电器间隙约0.5毫米,空载电压263V,偶尔能起弧,起弧后工作正常,小弟平时修氩弧焊机较多,头一次修等离子切割机,还望各位大虾多多指导!
全部回复(12)
上点照片吧
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2991791258957760.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2991791258957805.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2991791258957830.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2991791258957865.jpg');}" onmousewheel="return imgzoom(this);">
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2991791258958013.jpg');}" onmousewheel="return imgzoom(this);">
@爱华79
上点照片吧[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/2991791258957760.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/2991791258957805.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/2991791258957830.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/2991791258957865.jpg');}"onmousewheel="returnimgzoom(this);">[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/83/2991791258958013.jpg');}"onmousewheel="returnimgzoom(this);">
这是台州星火的机器吧
看 商标 应该 没错 焊丝星火的
本人不懂电路 提供星火的网站
WWW.SIHIO.COM 希望对LZ有所帮助
看 商标 应该 没错 焊丝星火的
本人不懂电路 提供星火的网站
应该是2.4K100W的电阻坏了把
您好,昨天在观察时发现在输出上正极至高频电感前端并了两个串起来的电阻,一个100W10欧一个100W2.4K,在2.4K的电阻上还并了一个450V330uf的电容,该电容没有固定,只用电线接在了电阻的引线端子上,甩在机壳里,电容身上用绝缘纸包了一层,上面又缠了些做变压器的那种胶带,在胶带上看到像磨破一样的痕迹,但又像是放电造成的,索性拆了胶带,发现胶带每一层都被击穿了,绝缘纸上也有打火的痕迹,在拆胶带时稍微牵动了引线结果就把2.4K电阻的一个引线端子给掉下来了,现在已经把电阻处理好了,电容也套了热缩管,明天接空压机试试,应该没问题了,现在就是不能确定那个2.4K的电阻原来是坏的,还是被我弄坏的,要是原来是好的的话,可能还有别的原因,先谢谢各位热心的帮助,小弟无以为报,只能把修机时的过程尽可能详细的写下来,希望对大家有帮助!
@小看
高频弱或放电间隙太小或气压高...
机子的高频很好,只是这台机子引弧部分与其他机子略有不同,将我收集的图纸和自己画的本机图纸对比,我觉得此机调大放电间隙会使引弧变差,上图请大家分析一下!
这是我收集的图纸引弧部分
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2991791259251289.jpg');}" onmousewheel="return imgzoom(this);">
这张也是收集的图纸引弧部分
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2991791259251400.jpg');}" onmousewheel="return imgzoom(this);">
这是我修的机子照实物画的
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/83/2991791259252838.jpg');}" onmousewheel="return imgzoom(this);">
这是我收集的图纸引弧部分
这张也是收集的图纸引弧部分
这是我修的机子照实物画的
@爱华79
这个商标是台州星火焊机的
