Microchip makes many families of 8, 16 and 32-bit MCU and 16-bit DSC solutions which can be used in various intelligent power applications, enabling a designer to support the level of digital integration and performance required for the application. Microchip offers a broad spectrum of analog products with a focus on power management, thermal management, linear and mixed-signal solutions. |
Microcontrollers for Level 1 Integration (On/Off Control)
PIC10F Microcontroller Product Family |
Features:
PIC10F Product Table |
Product | Pins | Flash KB | Ram Bytes | EE Bytes | Timer 8/16 Bit | Comparator | CCP/ECCP | Analog or HS PWM | ADC 8-bit | UART | SPI | I2C |
6 | 0.75 | 24 | - | 1/0 | 1 | - | - | - | - | - | - | |
6 | 0.75 | 23 | - | 1/0 | - | - | - | 2ch | - | - | - |
Microcontrollers for Level 2 Integration ( Proportional Control)
PIC12F and PIC16F Microcontroller Product Family The PIC12F family in available in small 8-pin packages, while PIC16F variants are offered in 14-pin through 64-pin packages. These family devices are suitable for proportion control (Level 2 integration). Some variants in the PIC16F family have one or more enhanced capture compare PWM (ECCP) modules that can be used to generate references for analog control loops. Built-in ADCs can be used to monitor input/output voltage and current and temperature. Comparators can be used to monitor fault inputs. Communication peripherals like UART, SPI and I2C™ can be used for remote monitoring and control. | |
Features:
PIC12F and PIC16F Product Table |
| Pins | Flash KB | Ram Bytes | EE Bytes | Timer 8/16 Bit | Comparator | CCP/ECCP | Analog or HS PWM | ADC | UART | SPI | I2C |
8 | 1.75 | 64 | - | 1/1 | - | - | - | - | - | - | - | |
8 | 1.75 | 64 | - | 2/1 | 1 | 1/ 2 Ch 10 bit | - | 4ch X 12 bit | - | - | - | |
14 | 3.5 | 128 | - | 1/1 | 2 | 1 | 1 | 8ch X 10 bit | - | - | - | |
20 | 7 | 256 | 256 | 1/0 | 2 | 4ch 10bit | - | 12ch X 10 bit | 1 | 1 | 1 | |
20 | 3.5 | 128 | 256 | 2/1 | 2 | 1 | 2 | 12ch X 10 bit | - | - | - | |
28/40/44 | 14 | 352 | 256 | 2/1 | 2 | 2ch,10bit | - | 5/8ch X 8 bit | 1 | 1 | 1 |
* Internal shunt regulator for high voltage Vdd support ** Has LCD Segment Driver |
Click here to find complete list of PIC12F Product Family Devices |
Click here to find complete list of PIC16F Product Family Devices |
Microcontrollers for Level 3 Integration (Topology Control)
PIC18F Product Family Features:
PIC 24F Product Family Features:
PIC18F and PIC24F Product Table |
Product | Pins | Flash KB | Ram KBytes | EE Bytes | Timer | Comparator | CCP | ADC | UART | MSSP |
64 - 80 | 32 - 128 | 4 | - | 2/3 | 3 | 2/3 | 8 -12ch | 2 | 2 | |
64 - 80 | 8 - 32 | 1 - 2 | - | 1/3 | 2 | 1/0 | 12ch | 2 | 1 | |
28 - 44 | 16 - 64 | 0.5 - 4 | 256-1024 | 1/3 | 2 | 1/1 | 11ch | 1 | 1 | |
28 | 16 - 64 | 4-8 | - | 5 | 2 | 5 | 10ch | 2 | 2-I2C 2-SPI | |
44 | 16 - 64 | - | 5 | 2 | 5 | 13Ch | 2 | 2-I2C 2-SPI |
Click here to find complete list of PIC18F Family Devices |
Click here to find complete list of PIC 24F Family Devices |
Microcontrollers for Level 4 Integration (Digital Control)
16-bit Product Family with Advanced Peripherals for Digital Power Control Implementing advanced software digital control loops for power applications requires a high performance DSP engine along with specialized peripherals. The high performance CPU and rich peripherals of the dsPIC devices enable solutions that do not require much in the way of external support chips. In addition to the space and cost-saving features that are in the dsPIC® DSC solutions, it also has special features enabling advanced power conversion. The DSP engine can perform single cycle MAC with data saturation, zero overhead looping and barrel shifting required to support fast control loop execution. These devices include peripherals specifically designed for power conversion. They include peripherals such as a high-speed PWM, ADC and analog comparators that can be tied together using an internal configurable control fabric that enables them to interact directly with one another resulting in stunning performance in digital power applications. |
dsPIC® 33F SMPS & Digital Power Conversion Devices |
Product | Pins | Flash | Ram | Timer | DMA | Input | Output Compare/ | PS PWM | QEI | ADC | 10 bit DAC o/p | Analog Comparators | UART | SPI | I2C | ECAN |
18 | 6 | 256 | 2 | - | - | 1 | 4 | 6ch, 3 S&H | - | - | 1 | 1 | 1 | |||
28 | 6 | 256 | 2 | - | - | 1 | 4 | 6ch, 3 S&H | - | - | 1 | 1 | 1 | |||
28 | 6 | 1K | 2 | - | 1 | 1 | 4 | 6ch, 3 S&H | 1 | 2 | 1 | 1 | 1 | |||
28 | 16 | 2K | 3 | - | 全部回复(0)
现在还没有回复呢,说说你的想法 立 即 发 帖 |
