BQ3060,求助AFE Init Retry Limit,AFE Init Limit的设置,解惑!!!
AFE Init Retry Limit 翻译为AFE 初始化重置限制。
After a full reset the AFE offset and gain values are read twice and then compared. AFE Init Retry Limit
is the maximum number of times that the initial AFE offset and gain values will be read, if they are not
considered the same, until the [AFE_C] permanent failure occurs.
个人直译为初始的AFE的偏移值和增益值被读取的最大次数,如果二者不相同,直到[AFE_C]永久性故障发生   default value 6
不甚理解
AFE Init Limit翻译为AFE 初始化极限
AFE Init Limit is the difference in A/D counts that two successive readings of AFE offset and gain can be
and still considered the be same value, after a full reset.
个人直译:AFE 初始化极限是在充分复位后两次连续读取AFE偏移值和增益值的差别范围,在这个范围内仍然被认为是相同。
default value  20
对AFE Init Retry Limit的理解困难,求高手指导
全部回复(1)
高手们都不肯帮忙呀!!!
