1.请问电线UL STYLE1589,其PAGE页面无任何要求老化前和老化后的相关测试要求及燃烧测试要求,是UL对此线无任何要求吗?还是有别的要求?
2.因为公司的电话线VW-1测试不能够通过,我可以上面不印VW-1吗?这可以意味着UL的现场检查人员不抽样做VW-1测试了吗?
电线行业的朋友们,几个简单问题请教!多谢了!
全部回复(8)
@whx_sesz
在ULstylepage上如没有要求测试VW-1的项目,则表示VW-1是可选的.并不作强制要求.你可以咨询UL的工程师.
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIALS
Subject 758 Section 1 Page 1589 Issued: April 26, 1973
Revised: Nov. 15, 2000
Style 1589 Insulating Electronic Use Wire.
______________________________________________________________________________
Rating 60 deg. C or 80 deg. C, 30 V.
Conductors No. 50 AWG minimum, not specified.
Insulation Solid or cellular polypropylene, PE, FRPE, XLPE, PFA, FEP,
PTFE, or ETFE. Wall thickness may range from 2 to
100 mils.
*Shield Optional.
Covering Optional - Extruded PVC, polyamide, polyester,
polyethylene, flame retardant polyethylene,
polypropylene or ETFE, approximately 2 mils thick, or
* lacquered braid.
*Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL
Representative
UL (4) Detailed Examination.
Counter-Check
Program
*Marking General.
Use For further processing: As insulated singles in internal or
external jacketed cables for electronic equipment.
100 mils.
*Shield Optional.
* lacquered braid.
to UL
Representative
Counter-Check
Program
*Marking General.
VW-1测试是针对电线的绝缘材料本身,应该跟老化前后没多大关系,附件的有关VW-1测试的要求可参考。
请问一下。我的老板要我申请SJTW 18AWG,16AWG,14AWG(3芯),测试的时间和费用如何,不知这位大哥是否做过?
1141908971.pdf
1141908971.pdf
@yeming12345
VW-1测试是针对电线的绝缘材料本身,应该跟老化前后没多大关系,附件的有关VW-1测试的要求可参考。请问一下。我的老板要我申请SJTW18AWG,16AWG,14AWG(3芯),测试的时间和费用如何,不知这位大哥是否做过?1141908971.pdf
测试时间约需2-3个月,若申请UL62的全部规格,费用约需60000左右,你可以找UL美华苏州公司的许艳小姐咨询一下,她的联系方式:Sheen XuCustomer Service SpecialistUL-CCIC Company Limited, Suzhou BranchTel: +86 (512) 6808 6400 Ext: 66651Fax: +86 (512) 6808 4099 Ext: 66651Email: Sheen.Xu@cn.ul.comWebsite: http://www.UL-CCIC.com
