手头上的几个GJB现在上传,另外因为MIL-STD较多,不好上传,现把LIST放上,需要就传。
GJB
GJB 1407-1992 可靠性增长试验.pdf
GJB 151A-1997 军用设备和分系统电磁发射和敏感度要求.pdf
GJB 152A-1997 军用设备和分系统电磁发射和敏感度测量.pdf
GJB 1909.1-1994 装备可靠性维修性参数选择和指标确定要求 总则.pdf
GJB 2072-1994 维修性试验与评定.pdf
GJB 3243-1998 电子元器件表面安装要求.pdf
GJB 360A-1996 电子及电器元件试验方法.pdf
GJB 546-1988 电子元器件可靠性保证大纲.pdf
GJB 645-1988 军用光学仪器维修性规范.pdf
GJB 813-1990 可靠性模型的建立和可靠性预计.pdf
GJB_Z 299A-1991 电子设备可靠性预计手册.pdf
GJB_Z 299B-1998 电子设备可靠性预计手册.part1.rar
GJB_Z 299B-1998 电子设备可靠性预计手册.part2.rar
GJB_Z 299B-1998 电子设备可靠性预计手册.part3.rar
GJB_Z 299B-1998 电子设备可靠性预计手册.part4.rar
GJB_Z 72-1995 可靠性维修性评审指南.pdf
MIL-STD
MIL-STD-101B COLOR CODE FOR PIPELINES AND FOR COMPRESSED GAS CYLINDERS.pdf
MIL-STD-105E Sampling Procedures and Tables for Inspection by Attributes.pdf
MIL-STD-1235C SINGLE- AND MULTI- LEVEL CONTINUOUS SAMPLING PROCEDURES AND TABLES FOR INSPECTION BY ATTRIBUTES
MIL-STD-1235C SINGLE- AND MULTI- LEVEL CONTINUOUS SAMPLING PROCEDURES AND TABLES FOR INSPECTION BY ATTRIBUTES_ Notice 1.pdf
MIL-STD-129N STANDARD PRACTICE FOR MILITARY MARKING
MIL-STD-129P MILITARY MARKING
MIL-STD-130K IDENTIFICATION MARKING OF U.S. MILITARY PROPERTY
MIL-STD-1330D(SH) PRECISION CLEANING AND TESTING OFSHIPBOARD OXYGEN, HELIUM, HELIUM-OXYGEN,NITROGEN, AND HYDROGEN SYSTEMS
MIL-STD-1344A Test Methods for Electrical Connectors
MIL-STD-1344A(1) Notice 1
MIL-STD-1344A(2) Notice 2
MIL-STD-1344A(3) Notice 3
MIL-STD-1344A(4) Notice 4
MIL-STD-1344A(5) Notice 5
MIL-STD-1472F Human Engineering
MIL-STD-1474D NOISE LIMITS
MIL-STD-1543B Reliability Program Requirements for Space and Launch Vehicles
MIL-STD-1548E INTO-PLANE SERVICING OF FUELS AT COMMERCIAL AIRPORTS
MIL-STD-1553B Introduction
MIL-STD-1553B AIRCRAFT INTERNAL TIME DIVISION COMMAND/RESPONSE MULTIPLEX DATA BUS
MIL-STD-1553B(1) Notice 1
MIL-STD-1553B(2) Notice 2
MIL-STD-1553B(4) Notice 4
MIL-STD-1560A INSERT ARRANGEMENTS FORMIL-C-38999 AND MIL-C-27599 ELECTRICAL,CIRCULAR CONNECTORS
MIL-STD-1576 Electroexplosive Subsystem Safety Requirements and Test Methods for Space Systems
MIL-STD-1576(1) Notice 1
MIL-STD-1591 On-Aircraft, Fault Diagnosis, Sub-Systems, Analysis-Synthesis of
MIL-STD-1622B(SH) CLEANING OF SHIPBOARD COMPRESSEDAIR SYSTEMS
MIL-STD-1629 (SH) PROCEDURES FOR PERFORMINGA FAILURE MODE,EFFECTS AND CRlTlCALliV ANALYSIS
MIL-STD-1629A Procedures for Performing a Failure Mode Effects and Criticality Analysis
MIL-STD-1686C Electrostatic Discharge Control Program for Protection of Electrical and Electronic Parts, Assemblies and Equipment (Excluding Electrically Initiated Explosive Devices)
MIL-STD-1760D AIRCRAFT/STORE ELECTRICALINTERCONNECTION SYSTEM
MIL-STD-1811 (USAF) MASS PROPERTIES CONTROLFORSPACE VEHICLES
MIL-STD-188-141B(1) INTEROPERABILITY AND PERFORMANCE STANDARDS FOR MEDIUM AND HIGH FFREQUENCY RADIO EQUIPMENT,NOTICE 1
MIL-STD-188-196 BI-LEVEL IMAGE COMPRESSIONFOR THENATIONAL IMAGERY TRANSMISSION FORMAT STANDARD
MIL-STD-188-196 (MIL-STD-188-196 COORDINATION DRAFT)5 June 2003
MIL-STD-188-197A ADAPTIVE RECURSIVE INTERPOLATED DIFFERENTIAL PULSE CODE MODULATION(ARIDPCM) COMPRESSION ALGORITHM FOR THENATIONAL IMAGERY TRANSMISSION FORMAT STANDARD,12 October 1994 (415Kb .pdf file)
MIL-STD-188-197A(1) INACTIVATION, Change Notice, 5 June 2003 (6Kb .pdf file)
MIL-STD-188-198A JOINT PHOTOGRAPHIC EXPERTS GROUP (JPEG) IMAGE COMPRESSION FOR THENATIONAL IMAGERY TRANSMISSION FORMAT STANDARD,15 December 1993 (1.082Mb .pdf file)
MIL-STD-188-198A(1) NOTICE 1, 12 October 1994 (236Kb .pdf file)
MIL-STD-188-198A(2) NOTICE 2, 14 March 1997 (97Kb .pdf file)
MIL-STD-188-198A(3) NOTICE 3, 1 March 2001 (122Kb .pdf file)
MIL-STD-188-199 VECTOR QUANTIZATION DECOMPRESSION FOR THE NATIONAL IMAGERY TRANSMISSION FORMAT STANDARD
MIL-STD-188-199(1) VECTOR QUANTIZATION DECOMPRESSION FOR THE NATIONAL IMAGERY TRANSMISSION FORMAT STANDARD NOTICE 1
MIL-STD-188-220 Abstract Introduction 1 MIL-STD 188-220
MIL-STD-1913 NOTICE 1
MIL-STD-1913(AR) DIMENSIONING OF ACCESSORY MOUNTING RAIL FOR SMALL ARMS WEAPONS
MIL-STD-1916 DOD Preferred Methods for Acceptance of Products
MIL-STD-196E JOINT ELECTRONICS TYPE DESIGNATION SYSTEM
MIL-STD-202G Test Method Standard_ Electronic and Electrical Component Parts
MIL-STD-202G NOTICE 1
MIL-STD-2045-44500 Tactical Communications Protocol 2 (TACO2) for the National Imagery Transmission Format Standard, 18 June 1993 (1.5Mb .pdf file)
MIL-STD-2045-44500(1) NOTICE 1, 29 July 1994 (708Kb .pdf file)
MIL-STD-2045-44500(2) NOTICE 2, 27 June 1996 (66Kb .pdf file)
MIL-STD-2045-44500(3) DRAFT NOTICE 3, 5 June 2003 (200 Kb .pdf file)
MIL-STD-2073-1C MILITARY PACKAGING
MIL-STD-2074 Failure Classification for Reliability Testing
MIL-STD-2155 Failure Reporting, Analysis and Corrective Action Systems
MIL-STD-2164 Environmental Stress Screening Process for Electronic Equipment
MIL-STD-2165 Testability Program for Electronic Systems and Equipments
MIL-STD-2173 Reliability Centered Maintenance Requirements for Naval Aircraft, Weapons Systems and Support Equipment
MIL-STD-220B TEST METHOD STANDARDMETHOD OF INSERTION LOSS MEASUREMENT
MIL-STD-2301 Computer Graphics Metafile (CGM) Implementation Standard for the National Imagery Transmission Format Standard, 18 June 1993 (490 Kbyte .pdf file)
MIL-STD-2301(1) NOTICE 1, 12 October 1994 (83 Kbyte .pdf file)
MIL-STD-2301A Computer Graphics Metafile (CGM) Implementation Standard for the National Imagery Transmission Format Standard, 18 June 1993 (490 Kbyte .pdf file)
MIL-STD-2301A Restrictions, 01 October 1998
MIL-STD-2301A Table Corrections, 01 October 1998
MIL-STD-2361(SC) DIGITAL PUBLICATIONS DEVELOPMENT
MIL-STD-2361C DIGITAL PUBLICATIONS DEVELOPMENT
MIL-STD-2401 DEPARTMENT OF DEFENSE WORLD GEODETIC SYSTEM(WGS)
MIL-STD-2414A BAR CODING FOR GEOSPATIAL PRODUCTS
MIL-STD-248D WELDING AND BRAZING PROCEDURE AND PERFORMANCE QUALIFICATION
MIL-STD-2500A National Imagery Transmission Format (Version 2.0) for the National Imagery Transmission Format Standard, 12 October 1994 (983Kb .pdf file)
MIL-STD-2500A(1) Notice 1, 7 February 1997 (101Kb .pdf file)
MIL-STD-2500A(2) Notice 2, 26 September 1997 (94Kb .pdf file)
MIL-STD-2500A(3) Notice 3, 01 October 1998 (191Kb .pdf file)
MIL-STD-2500B NATIONAL IMAGERY TRANSMISSION FORMAT VERSION 2.1 FOR THE NATIONAL IMAGERY TRANSMISSION FORMAT STANDARD,27 Aug 1997 (939Kb .pdf file)
MIL-STD-2500B(1) NOTICE 1, 2 Oct 1998 (851Kb .pdf file)
MIL-STD-2500B(2) NOTICE 2, 28 Jan 2003 (960Kb .pdf file)
MIL-STD-2500C NATIONAL IMAGERY TRANSMISSION FORMAT VERSION 2.1 FOR THE NATIONAL IMAGERY TRANSMISSION FORMAT STANDARD,(Redline, DRAFT Release 1.1), 25 February 2005, (1,046 Kb.pdf)
MIL-STD-2500C SD-1 Coordination Release, 29 September 2005, (969Kb.pdf)
MIL-STD-2500C SD-1 Coordination Letter for Mil-Std-2500C, 26 October 2005, (69Kb.doc)
MIL-STD-271F(SH) REQUIREMENTS FOR NONDESTRUCTIVE TESTING METHODS
MIL-STD-276A IMPREGNATION OF POROUS METAL CASTINGS AND POWDERED METAL COMPONENTS,30 December 1992
MIL-STD-290E PACKAGING OF PETROLEUM AND RELATED PRODUCTS
MIL-STD-3007C STANDARD PRACTICE FOR UNIFIED FACILITIES CRITERIA AND UNIFIED FACILITIES GUIDE SPECIFICATIONS
MIL-STD-331C Fuze and Fuze Components, Environmental and Performance Tests for - Revision C
MIL-STD-334B(TM) DISPLAYED MESSAGESFORAUTOMATIC TEST EQUIPMENT
MIL-STD-410E NONDESTRUCTIVE TESTING PERSONNEL QUALIFICATION AND CERTIFICATION
MIL-STD-414 Sampling Procedures and Tables for Inspection by Variables for Percent Defective
MIL-STD-414(1) Notice 1
MIL-STD-414(2) Notice 2
MIL-STD-45662 CALIBRATION SYSTEMS REQUIREMENTS
MIL-STD-45662A CALIBRATION SYSTEMS REQUIREMENTS
MIL-STD-461E REQUIREMENTS FOR THE CONTROL OF ELECTROMAGNETIC INTERFERENCE CHARACTERISTICS OF SUBSYSTEMS AND EQUIPMENT
MIL-STD-462D MEASUREMENT OF ELECTROMAGNETIC INTERFERENCE CHARACTERISTICS
MIL-STD-469B RADAR ENGINEERING INTERFACE REQUIREMENTS,ELECTROMAGNETIC COMPATIBILITY
MIL-STD-470B MAINTAINABILITY PROGRAM FOR SYSTEMS AND EQUIPMENT
MIL-STD-471A(1) Notice 1
MIL-STD-471A(3) Notice 3
MIL-STD-498 SOFTWARE DEVELOPMENT AND DOCUMENTATION
MIL-STD-498 SOFTWARE DEVELOPMENT AND DOCUMENTATION APPENDIX A
MIL-STD-498 MIL-STD-498 Points of Contact
MIL-STD-600011 DMA SINGLE COLOR OVER PRINT LIMITED REVISION UPDATES(SCO)
MIL-STD-621A SUBGRADE, SUBBASE, AND TEST METHOD FOR PAVEMENT BASE-COURSE MATERIALS
MIL-STD-690C Failure Rate Sampling Plans and Procedures
MIL-STD-690C(1) Notice 1
MIL-STD-690D Failure Rate Sampling Plans and Procedures
MIL-STD-704E AIRCRAFT ELECTRIC POWER CHARACTERISTICS
MIL-STD-704F Revision F Update
MIL-STD-705C GENERATOR SETS, ENGINE DRIVEN METHODS OF TESTS AND INSTRUCTIONS
MIL-STD-721C Definition of Terms for Reliability and Maintainability - Revision C
MIL-STD-750D Semiconductor Devices
MIL-STD-750D(5) Notice 5
MIL-STD-756B Reliability Modeling and Prediction
MIL-STD-781D Reliability Testing for Engineering Development, Qualification and Production
MIL-STD-785B Reliability Program for Systems and Equipment Development and Production
MIL-STD-785B(1) Notice 1
MIL-STD-785B(2) Notice 2
MIL-STD-785B(3) Notice 3
MIL-STD-790 Certification and Qualification Information for Specifications with MIL-STD-790
MIL-STD-790(1) Notice 1
MIL-STD-790F Established Reliability and High Reliability Qualified Products List (QPL) Systems For Electrical, Electronic, and Fiber Optic Parts Specifications
MIL-STD-810D Environmental Test Methods and Engineering Guidelines
MIL-STD-810D(1) Notice 1
MIL-STD-810E ENVIRONMENTAL TEST METHODS AND ENGINEERING GUIDELINES
MIL-STD-810F Environmental Engineering Considerations and Laboratory Tests
MIL-STD-810F(1) Notice 1
MIL-STD-882B SYSTEM SAFETY PROGRAM REQUIREMENTS
MIL-STD-882C System Safety Program Requirements
MIL-STD-882C(1) Notice 1
MIL-STD-882D System Safety
MIL-STD-883 CHANGES TO REVISION E OF MIL-STD-883
MIL-STD-883D TEST METHOD STANDARD MICROCIRCUITS
MIL-STD-883E METHOD 1019.4 IONIZING RADIATION (TOTAL DOSE) TEST PROCEDURE
MIL-STD-883E Test Method Standard Microcircuits
MIL-STD-883E(1) Notice 1
MIL-STD-883F Test Method Standard Microcircuits
MIL-STD-889B DISSIMILAR METALS
MIL-STD-962C DEFENSE STANDARDS AND HANDBOOKS
MIL-STD-962C(1) Motion Imagery Standards Board
还有一些MIL-HDBK/MIL-C/MIL-P之类的东西,不知道该怎么上传了
一些GJB&MIL-STD
全部回复(19)
谢谢您!可以上传下面这些资料吗?
MIL-STD
MIL-STD-1235C Notice 1
如果太费时间的话,就麻烦您帮忙传到liuhu7657@163.com里面去一下!
MIL-STD
@liuhu7657
谢谢您!可以上传下面这些资料吗?MIL-STDMIL-STD-101BCOLORCODEFORPIPELINESANDFORCOMPRESSEDGASCYLINDERSMIL-STD-105E SamplingProceduresandTablesforInspectionbyAttributesMIL-STD-1235C SINGLE-ANDMULTI-LEVELCONTINUOUSSAMPLINGPROCEDURESANDTABLESFORINSPECTIONBYATTRIBUTESMIL-STD-1235C Notice1如果太费时间的话,就麻烦您帮忙传到liuhu7657@163.com里面去一下!
已上传部分,1235C太大了,20多M,上传不是很方便,改天给你吧
@sounnyday
DX有发现几个资料损毁无法开启,从传一下吧GJB2072,GJB3243,GJB_Z299A,GJB360A,GJB_Z72谢谢!!Sounnyday
@wens
MIL-STD-45662A CALIBRATIONSYSTEMSREQUIREMENTS能否上传或者给我发到邮件中:bigwens@sina.com.cn
MIL-STD-45662 CALIBRATION SYSTEMS REQUIREMENTS.pdf
MIL-STD-45662A CALIBRATION SYSTEMS REQUIREMENTS.pdf
