AP3008 / AP3012串联型LED /LCD驱动应用IC介绍
The AP3008 is available in SOT-23-5 package.
Features
· Inherently Matched LED Current
· High Efficiency: 84% Typical
· Drives Up to 4 LEDs from a 3.2V Supply or 6 LEDs from a 5V Supply
· 36V 320mA Rugged Bipolar Switch
· Fast 1.2MHz Switching Frequency
· Requires Only 0.22µF Output Capacitor
· Uses Tiny 1mm Tall Inductors
· Built-in Output Over Voltage Protection
· Under Voltage Lock Out (UVLO)
· Internal Switching Current Limit
Applications
· Digital Cameras
· MP3 Players
· GPS Receivers
· Cellular Phones
· PDAs, Handheld Computers
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1134963506.gif');}" onmousewheel="return imgzoom(this);">
AP3008 规格表:1134963563.pdf
The AP3012 is available in standard SOT-23-5 package.
Features
· High Efficiency up to 81%
· Adjustable Output Voltage Range up to 29V
· Shutdown Current 1µA Typical
· 1.5MHz Switching Frequency
· 36V 500mA Rugged Integrated Bipolar Switch
· Built-in Soft-Start to Reduce Inrush Current During start-up
· On-chip Overvoltage Protection
· Uses Small Output Capacitor
· Uses Low Profile 1mm Tall Inductor
Applications
· LCD/OLED Display Bias Supply
· White LED Driver for LCD Display Backlights
· Cellular Phones
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1134963768.gif');}" onmousewheel="return imgzoom(this);">
AP3012 规格表
1134963737.pdf
全部回复(0)
