最近作一款110VAC输入,12V/4A输出的反激式开关电源的样机,控制芯片采用UC3842.发现其空载可以运行,(额定负载向空载切换可以)但空载却无法开机(输出电压跳动).我的3842Vcc先由输入端提供,待辅助绕组有电压输出后,切断输入端的供电线路,Vcc改由辅助绕组提供.其电路大致如下:
![](http://u.dianyuan.com/bbs/u/36/1135842527.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1135842527.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
在轻载条件下(40mA)电源可以开机(再小就不行了),其Vcc波形如下:
![](http://u.dianyuan.com/bbs/u/36/1135842606.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1135842606.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
其中时间段T1内由输入端提供电压给Vcc电容充电,当Vcc电压达到16V后,3842开始工作,辅助绕组有电压输出,此时在T2时间内,输入端的供电线路被切断,辅助绕组电压开始建立,在T3内,Vcc便完全由辅助绕组提供.
而空载时,观察Vcc的波形如下:
![](http://u.dianyuan.com/bbs/u/36/1135842670.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/36/1135842670.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20');}" onmousewheel="return imgzoom(this);">
其中时间段T2内,虽然输入端供电已被切断,但辅助电压似乎还没有到达3842的Vcc,导致Vcc电压一直跌落到10V以下,从而将3842给关断了,导致Vcc和电源输出出现跳动.
我又仔细观察了一下,发现两种波形在T2内斜率相同,也就是说,空载时,T2时间要长于带载.这究竟是什么原因造成的呢?时间T2的长短到底和哪些因素有关?哪位高手能解释一下!
