Rating 80, 90, 105 deg C, 600 Vac, 750 Vdc, Horizontal flame, Oil Resistant 60 deg C or 80 deg C (optional)
Conductor 30 AWG - 2000 kcmil Solid or Stranded Round.
Insulation PVC
30-9 AWG conductor size 30 mils min average 27 mils minimum at any point
8-7 AWG 45 avg 40 min
6-2 AWG 60 avg 54 min
1-4/0 AWG 80 avg 72 min
250-500 kcmil 95 avg 86 min
550-1000 kcmil 110 avg 99 min
1100-2000 kcmil 125 avg 112 min
Standard Appliance Wiring Material UL 758.
Marking General.
Use Internal Wiring of Appliances; or Internal Wiring of Appliances where exposed to oil at a temperature not exceeding 60 deg. C or 80 deg. C (whichever is applicable). Tags may also indicate the following: 2,500 V peak - for electronic use only.
