请赐教:UL746C中对塑胶外壳厚度要求是多少?
是要申请UL697,但697只有金属外壳厚度要求,它说塑胶外壳厚度请查阅UL746C?
全部回复(7)
I have completed several projects related to UL697.
For UL certification only, the min. plastic thickness are specified on the UL Yellow Card, but if you also apply c-UL certification, please pay attention to the 127mm flame test according to CSA standard.
The flammability, thickness are the most important points.
P.S. which company are you working for?
二楼的兄弟说的对,说到最小厚度,是看此材料在最小厚度下拥有的性能.
一般在黄卡上,或UL网上写明了.
wxwswxws
Appreciate ur kindness
我用的材料是GE940,能给详细介绍就太感谢了?
tks & brds
@wxwswxws
Appreciateurkindness我用的材料是GE940,能给详细介绍就太感谢了?tks&brds
min. thk   Flame Class  RTI
940(f1) 1.1        V-0          80  80  80
        1.5        V-0          130 120 125
        3.0        V-0          130 120 130
1. For V-0 flammability, min. 1.1 is OK, but the RTI is only 80, the suitability is determined by the actual condition.
2. For your reference, if you want to apply c-UL certification for toy grade, the flame class should be 5VA.
liuyanlau
@pwong03492
min.thk  FlameClass  RTI940(f1)1.1        V-0          80  80  80          1.5        V-0          130120125            3.0        V-0          1301201301.ForV-0flammability,min.1.1isOK,buttheRTIisonly80,thesuitabilityisdeterminedbytheactualcondition.2.Foryourreference,ifyouwanttoapplyc-ULcertificationfortoygrade,theflameclassshouldbe5VA.
本人菜鸟,不知RT1详细的意思,请哪位大虾告知.多谢.
@liuyanlau
英文是relative thermal index, 简单地说是材料能够长期在此温度下工作的温度.按标准的定义是此材料在长期老化了一定时间后(如10000小时)其属性下降到最初值的50%的温度.
cham1977
@pwong03492
Hi,
Can you advise some 5VA materials that can pass the flame test?
I tried N300 but still fail (hosuing thickness 2.2mm)! Thanks a lot!
