怎么样正确去焊接铝电解电容
在驱动电源和其他电路的应用中,电解电容的引线受温是有限度的,我在一客户的现场看到,把电解电容的引线焊接来回有几次,当时我们就提出要他们有个正确的焊接方法,现在在这里,希望各位提出一个比较好的解决方案,谢谢!
全部回复(2)
ydkcn8
● 铝电解电容器使用说明 Notes for use of aluminum electronic capacitors
1.在电器回路不清楚或不明确线路之极性时,则建议使用无极性电解电容器。
1.lf circuit polarities are uncertain, Non-polar capacitors are recommended.
2.无极性(或二极性)电解电容器,可使用在极性转换的回路或直流回路上。
2.Non-polar (or Bi-polar) capacitors can be used in polaritiy- changing circuits or DC circuits.
3.单极性电解电容器只能使用在直流电路上,其极性必需标明在适当之位置或在导针/端子之旁边。
3.Polarized capacitors can be used in DC circuits only. Its polarity must be marked on the proper side of wire/terminal.
4.电解电容器应储存于低温及干燥之处所。
4.Capacitors should be stored at a place of cool and dry.
5.电解电容器不可使用在周围温度超过标示之使用温度范围。
5.Capacitors cannot be used in a place of ambient temperature exceeding its marked temperature.
6.电解电容器不适用于超过可容许纹波电流范围之回路之上,假如有需要耐高温纹波电流之电解电容器,请与我们洽商详情
6.Capacitors cannot be used in a circuit where ripple current exceeds its allowed range. Please contact us if you have requirement for high temperature and ripple current capacitors
7.电解电容器经长久储存,如果漏电流超出规格值,使用前应以额定电压重新再老化30~60分钟。
7.lf capacitors have been stored for a long time and its leakage current exceeds the specified value, please recharge for 30 to 60 minutes with rated voltage before using.
8.电解电容器一般品不适用于骤然间之充放电,如需使用在快速充放电的场合,请与我们洽商。
8.Capacitors cannot be used in a circuit charge or discharge, lf use in a circuit of sudden charge is required, please contact us.
9.使用于电解电容器之工作电压,
不得超过额定电压。
9.Application of working voltage to capacitors should not exceed its rated voltage.
10.为了保护电解电容器之内部结构,其导针或端子不容许过分之拉力或承受的拉力,请参考JIS C 5102
10.ln order to protect the internal structure, capacitors cannot be applied with over pull-force. Please refer to JIS C 5102.
11.电烙铁应与电容器塑胶套管保持适当距离,以防止过热造成塑胶套管破裂。
11. Soldering iron should be kept in a suitable distance from vinyl sleeve of capacitor in order to avoid sleeve crack.
12.电解电容器经波峰焊锡之程序,其焊锡槽之温度绝对不容许超过260℃±10℃,时间10秒钟。
12.For peak soldering , the solder temperature should not exceed 260℃±10℃ for 10 seconds.
13.为了保护塑胶套管、印刷标示以及封口材料不被破坏,电解电容器不得以滷化化学药品或类似溶剂,作为电解电容器洗涤之用,如三氯乙烯、二甲苯类或酮类等。
13.In order to protect PVC sleeve, printed marks and sealing material, capacitors can not be cleaned with  halogenated chemicals or similar solvent such as trichlorethylene, Xylene or Acetone, etc.
14.本司规格之电容,品质依照JIS C 5141 标准。
14.Quality of our capacitors is in accordance with JIS C 5141.
15.本公司之信赖性试验方法,JIS C 5102 标准。
15.Reliability test methods for our capacitors are
in accordance with JIS C 5102.
16.雅达康电子科技有限公司公司在生产过程中不使用破坏臭氧层之药品。
16.None of Ozone Depleting Chemicals (ODC) is used in any manufacturing processes of yadacon Company.
@ydkcn8
● 铝电解电容器使用说明 Notes for use of aluminum electronic capacitors1.在电器回路不清楚或不明确线路之极性时,则建议使用无极性电解电容器。1.lf circuit polarities are uncertain, Non-polar capacitors are recommended.2.无极性(或二极性)电解电容器,可使用在极性转换的回路或直流回路上。2.Non-polar (or Bi-polar) capacitors can be used in polaritiy- changing circuits or DC circuits.3.单极性电解电容器只能使用在直流电路上,其极性必需标明在适当之位置或在导针/端子之旁边。3.Polarized capacitors can be used in DC circuits only. Its polarity must be marked on the proper side of wire/terminal. 4.电解电容器应储存于低温及干燥之处所。4.Capacitors should be stored at a place of cool and dry. 5.电解电容器不可使用在周围温度超过标示之使用温度范围。5.Capacitors cannot be used in a place of ambient temperature exceeding its marked temperature. 6.电解电容器不适用于超过可容许纹波电流范围之回路之上,假如有需要耐高温纹波电流之电解电容器,请与我们洽商详情6.Capacitors cannot be used in a circuit where ripple current exceeds its allowed range. Please contact us if you have requirement for high temperature and ripple current capacitors7.电解电容器经长久储存,如果漏电流超出规格值,使用前应以额定电压重新再老化30~60分钟。7.lf capacitors have been stored for a long time and its leakage current exceeds the specified value, please recharge for 30 to 60 minutes with rated voltage before using.8.电解电容器一般品不适用于骤然间之充放电,如需使用在快速充放电的场合,请与我们洽商。8.Capacitors cannot be used in a circuit charge or discharge, lf use in a circuit of sudden charge is required, please contact us.9.使用于电解电容器之工作电压,不得超过额定电压。9.Application of working voltage to capacitors should not exceed its rated voltage.10.为了保护电解电容器之内部结构,其导针或端子不容许过分之拉力或承受的拉力,请参考JIS C 5102。10.ln order to protect the internal structure, capacitors cannot be applied with over pull-force. Please refer to JIS C 5102.11.电烙铁应与电容器塑胶套管保持适当距离,以防止过热造成塑胶套管破裂。11. Soldering iron should be kept in a suitable distance from vinyl sleeve of capacitor in order to avoid sleeve crack.12.电解电容器经波峰焊锡之程序,其焊锡槽之温度绝对不容许超过260℃±10℃,时间10秒钟。12.For peak soldering , the solder temperature should not exceed 260℃±10℃ for 10 seconds.13.为了保护塑胶套管、印刷标示以及封口材料不被破坏,电解电容器不得以滷化化学药品或类似溶剂,作为电解电容器洗涤之用,如三氯乙烯、二甲苯类或酮类等。13.In order to protect PVC sleeve, printed marks and sealing material, capacitors can not be cleaned with  halogenated chemicals or similar solvent such as trichlorethylene, Xylene or Acetone, etc. 14.本司规格之电容,品质依照JIS C 5141 标准。14.Quality of our capacitors is in accordance with JIS C 5141.15.本公司之信赖性试验方法,JIS C 5102 标准。15.Reliability test methods for our capacitors are in accordance with JIS C 5102.16.雅达康电子科技有限公司公司在生产过程中不使用破坏臭氧层之药品。16.None of Ozone Depleting Chemicals (ODC) is used in any manufacturing processes of yadacon Company.
好贴!学习了,很有帮助。
