5-40Vin, 1A , BUCK, LED DRIVER IC : ML6404
大家上午好!
本公司是一家美资的公司--maxllent,主要研发LED driver & 运放类,AFE类产品。
这里给大家介绍一款LED driver ML6404
NS的LM3404是兼容的,并且比LM3404多模拟调光功能,
性价比高,主要应用于室外商业,景观,隧道,码头等照明。
大致参数如下:
ML6404 Features
• High Efficiency: Up to 98%
• Up to 1.5A Output Current
• Integrated 1A MOSFET Switch
5V to 40V Input Voltage Range
PWM & analog dimming
• No External Compensation Required
• Separate PWM Dimming and Low Power Shutdown
• Brightness Control Using DC Voltage
• Thermal Compensation
• Supports All-ceramic Output Capacitors and Capacitor-less Outputs
• Over Temperature Shutdown
• Cycle-by-Cycle Current Limit
• Operating Temperature: -40oC to +125oC
8-Pin SOP Package and SOPP Package
需要datasheet,请留下邮箱,谢谢!
全部回复(0)
