Dual-core Xenon lamp(双泡氙气路灯)
Dual-core Xenon lamp wick is two parallel, each with only a light bulb lighting, as in the 6000-8000 hours each bulb life (for lamps) theory two-hour bulb life add up to 12000-16000, if available 10 hours a day by lighting only once between 3-5 years, light bulb
双泡氙灯路灯2只灯芯并联,每次点灯时只有一只灯泡亮,由于每只灯泡寿在6000-8000小时(用于路灯)理论上二只泡寿命相加等于12000-16000小时,如果按每天10小时点灯可用3-5年之间才换一次灯泡。
全部回复(2)
那就不存在什么热点火了,早期就有做过这样的实验,点火不用保护,都能正常工作。
HID201108
@黑暗侵袭
