热烈祝贺山西互感器公司利用HT1215开发成功5KW高频逆变电源并定型!
1.HT1215的特点
HT1215是泓芯泰业科技(北京)有限公司的国家已授权的发明专利产品,它是世界上首个把消谐波技术集成于一个芯片且被300多个用户试应用,并综合众多用户意见后而定型的单极性逆变芯片产品
其主要特点有:
(1)直流电压利用率高(输出电压幅值与母线电压之比)>0.97;
(2)50Hz/60Hz 热切换。即工作时可随时控制50Hz或60Hz输出;
(3)采用单极性消谐波调制,四个管平均工作(见四个管的调制波形图)
![](http://u.dianyuan.com/upload/t/space/2011/06/10/1307688800-472626-mid.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
50Hz频域
![](http://u.dianyuan.com/upload/t/space/2011/06/10/1307688816-472627-mid.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
50Hz时域
![](http://u.dianyuan.com/upload/t/space/2011/06/10/1307688828-472628-mid.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
60Hz频域
![](http://u.dianyuan.com/upload/t/space/2011/06/10/1307688840-472629-mid.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
60Hz时域
![](http://u.dianyuan.com/upload/t/space/2011/06/10/1307688844-472630-mid.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
第八脚
![](http://u.dianyuan.com/upload/t/space/2011/06/10/1307688927-472631-mid.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
第九脚
![](http://u.dianyuan.com/upload/t/space/2011/06/10/1307688929-472632-mid.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
第七脚
![](http://u.dianyuan.com/upload/t/space/2011/06/10/1307688931-472633-mid.jpg?x-oss-process=image/watermark,g_center,image_YXJ0aWNsZS9wdWJsaWMvd2F0ZXJtYXJrLnBuZz94LW9zcy1wcm9jZXNzPWltYWdlL3Jlc2l6ZSxQXzQwCg,t_20)
第十脚
50Hz时,最大开关管频率18.9K,平均开关频率:9.45K
60Hz时,最大开关管频率19.08K,平均开关频率:9.54K
(5)预置死区时间>0.5us,驱动电路简单
(6)内置空载检测关断功能,1分钟后再检测,直到正常输出;
(7)内置过载检测、延迟关断功能
(8)滤波电感小、可节省主要成本,仅需1mH电感、2~4uF电容
以下特点资料整理中,请关注本帖更新!
2.THD与直流母线电压的关系
设定:V1,V2,......,Vn,......为逆变电源中各次谐波电压的有效值,VB值为直流母线电压值。根据THD(综合谐波失真)的定义有:
<1>
根据直流母线电压利用率m(也称调制指数)的定义(即:基波电压的幅值与直流母线电压值之比)有:
<2>
把<1>式变换如下:
<3>
在单相双极性条之中,<3>式中的
相当于逆变电源中的总归一化能量之和,
不考虑其他损耗时,根据能量守恒有:
<4>
把<4>式和<2>式带入到<3>式有:
<5>
各位看官,看到<5>式的结果,有何高见?
怎样解读?敬请各位看官谈谈看法,楼主不胜感激!楼主还通过用开关角的计算方式求出一定次数谐波的Vn,然后按<1>式求出THD,再与<5>式比较,是相当吻合的!
这里:楼主也给出单相单极性逆变和三相双极性逆变HD的估算公式,
<6><7>
<5> <6><7>式对我们设计电感非常重要,望朋友们记下,并发表看法或指教!请您继续关注!
3.THD与滤波电感的设计
3.1关于THD公式<5><6><7>的解读
以前,我们讨论逆变电源的滤波时,无论是LC还是LCL空载时,滤波的衰减系数均为1/(1-W2LC),该公式只能求出已确定的载波频率和假定的LC积之后的衰减系数。为什么确定该衰减系数的大小,并没有理论做为支撑,有了公式<5><6><7>,我们就有课理论支持!例如:
设输出的交流电压是220V,测得母线电压为380V,此时的直流电压利用率为m=1.414*220V/380=0.8186 利用公式<5>求得单相双极性调制时THD=1.4;或用<6>式求得单极性的THD=0.7如果要满足THD≤5%,LC滤波的衰减系数就必须满足,双极性:≥1.4、0.05=28 单极性:≥0.7/0.05=14
如要求THD≤1%,
衰减系数为:双极性:≥1.4/0.01=140 单极性:≥0.7/0.01=70
