谁家有这样的电源
Power supply for illumination applications
、交流输入
输入电压:85Vac - 265Vac 50/60Hz.
输入过压保护
功率因素>0,8 for output power 0,3w to full power (PFC is mandatory)
 No ground cable allowed.
、直流输出
输出电压: 10Vdc±10%
最大纹波电压:0,5V
最大输出功率:6W (600mA)
最小输出功率:0,3W (30mA) à PF >0,8(非常重要)
允许永久短路
效率:>75% at full output power
>60% alt minimum output power. If this requirement is very difficult, it possible to reduce to >40%.
、电气绝缘
o AC to DC insulation strength: 3000V 50Hz 1 min.
o Insulation resistance: >4MΩ at 500Vdc
爬电距离 > 5mm
o No capacitors (Y1, Y2, etc) allowed between AC and DC
- MTBF: >150Khrs@40ºC
适用标准
o UNE-EN 55015: 2007 + A1:2008 + A2:2009
o UNE-EN 61000-3-2: 2006 + A1:2009 + A2:2009 (type C for illumination)
o UNE-EN 61547: 1997 + A1:2001
§ UNE-EN 61000-4-2: 2009
§ UNE-EN 61000-4-3: 2007 + A1:2008 + A2:2009
§ UNE-EN 61000-4-4: 2005 + A1:2010 + Corr.: 2010
§ UNE-EN 61000-4-5: 2007 + Corr.: 2010
§ UNE-EN 61000-4-6: 2009
§ UNE-EN 61000-4-8: 2010
§ UNE-EN 61000-4-11: 2005
- Connections to main board using metallic poles. The positions of metallic poles Hill be where required.
尺寸大小:50mm x 40mm x 15mm(h). 高度最高不得超过18mm.
It´s very important de power factor, I need higher than 0,8 at 0,3w power to full power (6W). The oder important think is the standard. I need to comply the standard, specially the harmonics standard UNE-EN 61000-3-2 class C, below 25W.
Send me the quote of the power supplies in quantities of: 2K, and 50K 10K.
全部回复(1)
please get in touch with me via
roman.xiao@gmail.com
13764303579
