東陽科技集團主推ATMEL(愛特梅爾),ST-ERICSSON 品牌全系列的晶片應用!憑藉優勢的現貨庫存,持續穩定供貨,為廣大客戶提供進口全新原裝正品,並贏得行業內外的信賴和好評。產品廣泛應用於儀錶儀器,安防,門禁,通訊網絡…USB 芯片接口;另經營NXP(PHILIPS) ,INFINEON, ST,IR ,ATMEL等知名品牌半导体 。
我司一直堅守客戶至上,互惠互利的經營理念,堅持誠實守信的商業原則,竭誠為客戶提供多元服務,並期待與您真誠合作,共謀發展!
強力推薦,優勢庫存:
ATMEL
AVR系列
ATMEGA8L-8AU; ATMEGA48V-10AU;
ATMEGA88V-10MU ; ATMEGA169PV-8AU
ATTINY13A-SU ; ATTINY26-16SU; ATTINY48-AU,ATMEGA88PA-MU
ATMEGA644P-A15AZ; ATMEGA128-16AN; ATMEGA164P-A15AZ;
ATMEGA128-16AU; AT90CAN128-15AZ; ATMEGA324P-A15AZ;
ATMEGA168P-20AU; ATMEGA324P-20AU; AT90CAN128-15AZ;
ATMEGA328P-AU; ATMEGA168-15AZ; ATMEGA88-15AZ
串列EEPROM系列
AT24C01/01A/02/04/08/16/32/64/128/256/512/1024
ST-ERICSSON
USB Commercial:
PDIUSBD12PW ISP1161A1BDTM ISP1161A1BMUM
*NXP(PHILIPS)半導體系列照明驅動晶片
UBA2014T(P): 600 V driver IC for HF fluorescent lamps 螢光燈可調光電子鎮流器
UBA2021T(P): Half-bridge power IC for CFL lamps 節能燈驅動IC
UBA2024P/T : Half-bridge power IC for CFL lamps 內置MOS節能燈驅動IC
UBA2028T :600V dimmable power IC for Compact Fluorescent Lamps內置MOS調光IC
UBA2030T : Full bridge driver IC for HID全橋驅動
UBA2032T(TS): Full bridge driver IC for HID全橋驅動
UBA2033TS : Full bridge driver IC for HID全橋驅動
UBA2035TS : HF Full-bridge control IC for HID lighting 商用全橋驅動
UBA2036TS : Full-bridge control IC for HID automotive lighting 高級車用全橋驅動
UBA2037T(TS) : Full-bridge control IC for HID automotive lighting 全橋驅動
UBA2070T(P) : 600 V CCFL ballast driver IC for CCFL backlighting LCD 背光驅動
UBA2071T(TS) : Full bridge control IC for. CCFL backlighting LCD 背光驅動
UBA2072T(TS) : Full bridge control IC for. CCFL backlighting LCD 背光驅動!
SSL2101:SMPS IC for dimmable LED lighting LED可調光開關模式電源控制晶片
SSL2102:Mains LED driver IC for dimmable LED lighting LED調光驅動晶片
*NXP(PHILIPS)半導體系列快恢復二極體
BYC8-600 : Rectifier diode ultrafast, 超快恢復19ns,8A/600V TO220
BYC8X-600 : Rectifier diode ultrafast, 超快恢復19ns,8A/600V TO220F
BYC10X-600 : Rectifier diode ultrafast, 超快恢復19ns,10A/600V TO220F
BYV29X-600 : Rectifier diode ultrafast, 超快恢復55ns,9A/600V TO220F
BYT79-600: Rectifier diode ultrafast, 超快恢復60ns,16A/600V TO220
BYV34-500:Rectifier diode ultrafast, 超快恢復 60ns,20A/500V TO220
BYQ28E-200:Rectifier diode ultrafast, 超快恢復 25ns,10A/200V TO220
BYQ28X-200:Rectifier diode ultrafast, 超快恢復 25ns,10A/200V TO220F
BYW29E-200: Rectifier diode ultrafast, 超快恢復 25ns,8A/200V TO220
BYQ30E-200:Rectifier diode ultrafast, 超快恢復 25ns,15A/200V TO220
BYV72EW-200:Rectifier diode ultrafast, 超快恢復 28ns,30A/200V TO247
*NXP(PHILIPS)半導體MOSFET:
PSMN010-55D : 75A 55V 10.5Mohm 125W TO252 , 電源MOSFET
PSMN015-100B :75A 100V 15Mohm 300W D2PAK(TO263) ,電源 MOSFET
PSMN015-100P :75A 100V 15Mohm 300W TO220 , 電源MOSFET
PSMN015-110P :75A 110V 15Mohm 300W TO220 , 電源MOSFET
PSMN009-100P :75A 100V 9Mohm 300W TO220 ,電源 MOSFET
PHP45NQ10T : 47A 100V 25Mohm 150W TO220 ,電源MOSFET
*NXP(PHILIPS)其他主推產品:
TDA1308T:Class AB stereo headphone driver 耳機專用功放晶片 SOP8
UDA1330ATS:Low-cost stereo filter DAC多媒體音頻數位/類比轉換器 SSOP16
UDA1341TS:Low-cost stereo filter DAC多媒體音頻數位/類比轉換器 SSOP28
PDIUSBD12D:USB interface device with parallel bus USB介面晶片 SOP28
PDIUSBD12PW:USB interface device with parallel bus USB介面晶片 SSOP28
TDA8920CTH: IC CLASS-D POWER AMP;2X100W /D類功放晶片,2X110W HSOP24
*INFINEON半導體COOLMOS:
SPD03N60C3: COOLMOS 3.2A 600V 1.4ohm 38W DPAK(TO252)
SPP03N60C3: COOLMOS 3.2A 600V 1.4ohm 38W TO220
SPD04N60C3:COOLMOS 4.5A 600V 0.95ohm 50W DPAK(TO252)
SPP04N80C3: COOLMOS 4A 800V 1.3ohm 63W TO220
SPP06N80C3:COOLMOS 6A 800V 0.9ohm 83W TO220
SPA06N80C3: COOLMOS 6A 800V 0.9ohm 39W TO220F
SPD07N60C3:COOLMOS 7.3A 600V 0.6ohm 83W DPAK(TO252)
