请教高手,一关于GB8898 标准的8.16和15.2条款运用和解释
我公司现有一款20'液晶电视被商检抽查到指定实验室做测试,
现在实验室告知我们的产品的电源适配器(普通电源电脑或显示器用的适配器)不符合标准的8.16条:
  设计成专门要由制造厂商规定的电源设备来供电的设备,其结构应保证通用电源设备不加修改就不可能替换该专用设备.
和标准的15.2中:
  在具有非危险带电输出电压的一类设备中,输出电路不应与保护地导体连接.
请教一下高手们 这两条怎么解释啊,我们的适配器是否需要专门修改结构保证不能通用? 还有15.2的那句话怎么理解
全部回复(1)
The clause 8.16 means there are must used a specific DC plug in the AC/DC adapter, avoid misuse other AC/DC adapter in the apparatus. according to the OSM EE(chm)3/03, this clause don't apply to yours product.
The clause 15.2, pls pay more attention to the third paragraph(this paragraph was deleted in the latest Amend .1), maby i think the lab failed yours product by using this paragraph. For this case, pls check that the secondary circuit of AC/DC adapter was connect to earth or not?
