各位高手,请问谁有以下测试项目的规范或企标,有的话烦请给我分享一下不胜感激;谢谢!或邮件给我也可以907094029@qq.com
1 Static Electrical Performance Test(静态性能测试)
1.1 Regulation, Ripple & Efficiency Measurement(电压电流调整率﹐纹波﹐效率测试)
1.2 Start Up Input Voltage Test(起机输入电压测试)
1.3 Break Regulation Input Voltage Test(输入电压临界点测试)
1.4 Output V-I Characteristics Curve Test(输出电压电流特性曲线测试)
1.5 Audible Noise Check(可听噪音测试)
2 Transient Electrical Performance Test(瞬态性能测试)
2.1 Inrush Current Test(浪涌电流测试)
2.2 Start Up & Turn On Delay Test(起机延时测试)
2.3 Shut Down & Hold Up Time Test(关机延时测试)
2.4 Dynamic Load Response Test(动态负载响应测试)
3 Protection Circuit Test(保护电路测试)
3.1 Over Current Protection Test(过流保护测试)
3.2 Short Circuited Protection Test(短路电路保护测试)
3.3 Over Voltage Protection Test(过压保护测试)
3.4 Over Temperature Protection Test(过温保护测试)
4 Power Line Disturbance Test(电源干扰测试)
4.1 Missing Cycle Test(掉电测试)
4.2 Power Line Noise Test(交流电源电气噪声测试 EFT)
4.3 Lightning Test(雷击测试)
4.4 Restart after Shut Down Test(关机后重新开机测试)
4.5 Input Under Voltage Test(输入电压不足测试)
4.6 Power On Under Inductive AC Input Test(电感性的交流输入下开机)
5 Environmental Test(环境测试)
5.1 Low Temperature Operating Test(低温操作测试)
5.2 High Temperature High Humidity Operating Test(高温高湿操作测试)
5.3 High / Low Temperature Cycle Storage Test(高低温循环测试)
5.4 High Temperature High Humidity Storage Test(高温高湿存储测试)
5.5 Vibration Test(振动测试)
5.6 Drop Test(跌落测试)
6 Waveform Measurement of Critical Components(主要元件的波形测试)
7 Reliability Test(可靠性测试)
7.1 Static Component Stress Analysis – Derating(静态元件应力分析-使用率测试)
7.2 Power Transformer Saturation Check(功率火牛饱和测试)
7.2.1Waveform Measurement of Critical Components(主要元件的波形测试)
7.2.1.1 Static Overload Condition(静态过载条件)
7.2.1.2 Transient Conditions(瞬态条件)
7.2.2 Maximum Flux Density Calculation(最大磁通密度计算Bmax)
7.2.2.1 Static Overload Condition(静态过载条件)
7.2.2.2 Transient Conditions(瞬态条件)
7.3 E-Cap Lifetime Check(吕电容寿命测试)
7.4 Temperature Rise Measurement (温升测试)
7.5 Power ON-OFF Test(开关机测试)
7.6 MTBF Calculation( 平均无故障时间计算/ Mean Time Between Failure Calculation)
8 Safety Test(安规测试)
8.1 Abnormal Operating Test – Open / Short(巽常操作测试-开路/短路)
8.2 No Ventilation Test(不透风测试/密封测试)
8.3 Extra Low Input Voltage Test(特低输入电压测试)
8.4 Extra High Input Voltage Test(特高电压测试)
8.5 Over Load Test(过载测试)
8.6 Visual Check on Potential Safety Problem(可见的潜在安全问题检查)
8.7 Hi-Pot Test(高压测试)
8.8 Insulation Resistance Test(绝缘电阻测试)
8.9 Leakage Current Test(漏电流测试)
8.10 Flammability Grades of Plastic Parts and PCB(电路底版的可燃性级数可燃性检查)
8.11 Fuse Marking(保险丝检查)
8.12 Creepage and Clearance(空间及爬电距离)
8.13 Y-Cap Check(Y-电容检查)
8.14 Severe Drop Test(严格的跌落测试(对于AC适配器))
8.15 Severe Vibration Test(严格的震动测试 (对于AC适配器))
8.16 On/Off Test at High Input Voltage(高压输入的开关机测试)
9 EMC Test(ElectroMagnetic Compatibility 电磁兼容姓测试)
9.1 Immunity to Electro Static Discharge Test(电子静态放电测试)
9.2 EMI Check(电磁干扰测试)
10 Mechanical Check
10.1 Dimension Check
10.2 Cable Check
10.3 Label Check
10.4 Marking Check
10.5 Fastener Check
