TI有TL3842B,然后还有个UC3842,结合ON还有3842A所以问了这么个问题。主要想知道兼容性方面有何要注意的,因为我是准备以TL3842B作为设计原型,但是由于ON有中文数据手册,所以作为参考的
有朋友说是启动电流的问题,但实际证明也并非完全所有产品都有差别,另外想问,若是启动电流差异,设计方面是有何注意点呢?
UC3842A特性
Rating Symbol Value Unit
Total Power Supply and Zener Current (ICC + IZ) 30 mA
Output Current, Source or Sink (Note 1) IO 1.0 A
Output Energy (Capacitive Load per Cycle) W 5.0 µJ
Current Sense and Voltage Feedback Inputs Vin – 0.3 to + 5.5 V
Error Amp Output Sink Current IO 10 mA
Power Dissipation and Thermal Characteristics
D Suffix, Plastic Package
Maximum Power Dissipation @ T = 25°C P 862 mW
A D
Thermal Resistance, Junction–to–Air RθJA 145 °C/W
N Suffix, Plastic Package
Maximum Power Dissipation @ T = 25°C P 1.25 W
A D
Thermal Resistance, Junction–to–Air RθJA 100 °C/W
Operating Junction Temperature TJ + 150 °C
Operating Ambient Temperature TA °C
UC3842A, UC3843A 0 to + 70
UC2842A, UC2843A – 25 to + 85
UC3842B特性
Symbol Parameter Value Unit
Vi Supply Voltage (low impedance source) 30 V
Vi Supply Voltage (Ii < 30mA) Self Limiting
IO Output Current ±1 A
EO Output Energy (capacitive load) 5 µJ
Analog Inputs (pins 2, 3) – 0.3 to 5.5 V
Error Amplifier Output Sink Current 10 mA
Ptot Power Dissipation at Tamb ≤ 25 °C (Minidip) 1.25 W
Ptot Power Dissipation at Tamb ≤ 25 °C (SO8) 800 mW
Tstg Storage Temperature Range – 65 to 150 °C
TJ Junction Operating Temperature – 40 to 150 °C
TL Lead Temperature (soldering 10s) 300 °C
我看到TI有TL3842B,然后还有个UC3842,结合ON还有3842A所以问了这么个问题。主要想知道兼容性方面有何要注意的,因为我是准备以TL3842B作为设计原型,但是由于ON有中文数据手册,所以作为参考的。
