上电就保护,什么原因?
我用3842做了一个反激式电源,输入电压32V,多路输出+15V,软启动电阻5.1K,电容47u,采样电阻0.33殴.现象是,上电没有输出,调小反馈电阻就会有输出了,然后再把反馈调大,电源可以正常工作.这是什么原因?大侠们请指教!
上电就保护,什么原因?
全部回复(36)
@董万华
是简易稳压:加反馈绕组!!
还是把图贴上来吧!
诺亚方舟说的假反馈怎么解?大家给看看我得这个电源
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/0/1062159966.jpg');}" onmousewheel="return imgzoom(this);">
![](http://u.dianyuan.com/bbs/u/0/1062159966.jpg?x-oss-process=image/format,webp)
@hkbuaa
还是把图贴上来吧!诺亚方舟说的假反馈怎么解?大家给看看我得这个电源[图片]500){this.resized=true;this.width=500;this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}"onclick="if(!this.resized){returntrue;}else{window.open('http://u.dianyuan.com/bbs/u/0/1062159966.jpg');}"onmousewheel="returnimgzoom(this);">
Soft start
From the schematic, the problem should be cause by the overshoot at turn on, add a soft start circuit can solve the problem,but strongly recommend to change the feedback loop to the secondary side,you can save at least two linear regulator and save more cost.
