另一台“加拿大”通信开关电源产品!
![](http://u.dianyuan.com/bbs/u/0/1062119973.jpg?x-oss-process=image/format,webp)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/0/1062119973.jpg');}" onmousewheel="return imgzoom(this);">
RSM 48/50 and RSM 24/100 Rectifier
![](http://u.dianyuan.com/bbs/u/0/1062120059.jpg?x-oss-process=image/format,webp)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/0/1062120059.jpg');}" onmousewheel="return imgzoom(this);">
ItemRSM 48/50 ModuleRSM 24/100 ModuleNotes
Input Voltage 184 to 264VAC at 47 to 63Hz non-UPF models
176 to 264VAC at 47 to 63Hz UPF models
Output Voltage 42 to 60VDC 21 to 30VDC
Output Current 55A Max. 105A Max.
Efficiency >90% >88% 40% to 100% Load
Regulation Less than 1% 50 to 100% Load step
0% slope
VoiceBand Noise Less than 22dBrnc
WideBand Noise Less than 10mVrms up to 10MHz
WideBand Noise Less than 150mVp-p up to 100MHz
EMI FCC Class A
TIF (Current) Less than 250 at 100% load non-UPF models
Less than 60 at 100% load UPF models
SoftStart 33% per second
Protection:
Output Current Limit
Input & Output Circuit Breakers
Input Transient
Input Undervoltage
Input Inrush Current Limiting
Output Overvoltage Shutdown
Module Indicators/Display:
Power On
Module Fail
Module Status Indicator (OK, minor alarm, processor reset)
Scrolling alphanumeric display (2 lines with 16 characters on each line)
Cabinet Alarms: (programmable Form A or B contacts)
Individual Module Fail
Group AC Fail
General Alarm
Controls:
Up Adjustment/Scroll Key
Down Adjustment/Scroll Key
Select-Float/Equalize Key
View Adjust-Up and Select
Remote Controls:
Equalize
Shutdown
Remote Control Access via Serial Communications Interface
Cooling: Natural Convection - Front to Back
Operating Temperature:
0 to 50degC (Standard)
-40 to 65degC (Optional)
Mounting: 19\" or 23\" Center or Flush rackmount. Consult factory for Wallmount options
Dimensions: 133mm H x 432mm W x 381mm D (10.5\"H x 17\"W x 15\"D)
Weight:
19\" Cabinet - 9 Kg (20 lbs)
23\" Cabinet - 11 Kg (24 lbs)
Power Module - 8 Kg (17 lbs)
