【问】TI公司有专门针对ESD和雷击保护方面的设计方案吗?
在我们日常生活中,你的电脑被雷劈过吗?你的电视、手机家电什么的,在打雷下雨的时候你敢正常使用吗?TI公司有专门针对ESD和雷击保护方面的设计方案吗?
全部回复(11)
zhc7302
学习
javike
LV.12
@zhc7302
学习
有!
The TPD4E101 is a four channel ESD protection device in an ultra small package. It is the industry’s smallest 4-ch ESD protection device.
 A larger pitch helps save on PCB manufacturing costs. The device provides IEC61000-4-2 compliance up to 15kV contact discharge.
 It has an ESD clamp circuit with back-to-back diodes for bipolar/bidirectional signal support.
The low line capacitance is suitable for a wide range of applications supporting data rate up to 700Mbps.
Typical application areas in portable applications are:
  • Audio lines (Microphone, Earphone and Speakerphone)
  • SD interface
  • SIM interface
  • Keypad or other buttons
特性
  • Provides System Level ESD Protection for Low-voltage IO Interface
  • IEC 61000-4-2 Level 4
    • ±15kV (Air discharge)
    • ±15kV (Contact discharge)
  • IO Capacitance < 5pF
  • Ultra low Leakage Current
  • Ultra Low Clamping Voltage
  • Industrial Temperature Range: –40°C to 125°C
  • Space Saving µQFN package
器件用途
  • Cell Phones
  • eBook
  • Portable Media Players
  • Digital Camera
  • Tablet PC
  • Set Top Box
@javike
有!TheTPD4E101isafourchannelESDprotectiondeviceinanultrasmallpackage.Itistheindustry’ssmallest4-chESDprotectiondevice. AlargerpitchhelpssaveonPCBmanufacturingcosts.ThedeviceprovidesIEC61000-4-2complianceupto15kVcontactdischarge. IthasanESDclampcircuitwithback-to-backdiodesforbipolar/bidirectionalsignalsupport.Thelowlinecapacitanceissuitableforawiderangeofapplicationssupportingdatarateupto700Mbps.Typicalapplicationareasinportableapplicationsare:Audiolines(Microphone,EarphoneandSpeakerphone)SDinterfaceSIMinterfaceKeypadorotherbuttons特性ProvidesSystemLevelESDProtectionforLow-voltageIOInterfaceIEC61000-4-2Level4±15kV(Airdischarge)±15kV(Contactdischarge)IOCapacitance<5pFUltralowLeakageCurrentUltraLowClampingVoltageIndustrialTemperatureRange:–40°Cto125°CSpaceSavingµQFNpackage器件用途CellPhoneseBookPortableMediaPlayersDigitalCameraTabletPCSetTopBox
ESD即静电释放,它对于精密半导体芯片会造成各种损伤,例如穿透元器件内部薄的绝缘层;损毁MOSFET和CMOS元件的栅极;CMOS器件中的触发器锁死;造成反向偏置和正向偏置的PN结短路;融化有源器件内部的焊接线或铝线。
在电脑行业,ESD更是频繁出现的无形杀手,主要表现在:
1 雷击或其他静电放电导致网卡损坏
2 芯片组烧毁,如早几年某主板大厂由于USB接口的ESD问题引起大量南桥烧坏
3 IO接口问题导致主板上的元件损坏,如三极管烧毁
4 系统出错,重启,硬盘数据丢失等在主板设计时加入有效的ESD防护措施,可最大程度上防治上述各项损害的发生,从而提高主板品质,加长工作寿命。通常主板元器件在遭受ESD后可通俗分为三种状态:健康,死亡,受伤。 健康的,该元件有适当的ESD防护处理,可正常运行几年时间。死亡的,该元件没有ESD防护,而遭受严重的ESD损害,不能正常运行。受伤的,该元件遭受部分损坏,含有潜在的缺陷。虽然短时间内不易发觉,但是在使用过程中出现过早实效。电脑遭受ESD的途径有两种:
1、人体接触时引起(如:用户在操作开机、复位、插拔USB等设备时)
2.、雷击(如:通过网卡)顶星科技秉承“让我们的客户永远快乐”为宗旨,在主板设计的时候加入了许多防护ESD的设计,让用户在使用电脑的过程当中,防御了ESD的干扰。当然我们在使用电脑的时候也要操作得当,让ESD无处藏身。下面顶星教教你,在您使用电脑的时候应该注意的地方:
第一,电脑机壳需要可靠接地;
第二,北方地区在秋冬季节应使用加湿器,保持室内空气的一定湿度,防止静电在设备、家具和身体上大量积累;
第三,在运输和储存过程中要将电脑整机或零部件置于静电屏蔽袋或导电搬运箱内进行运输防止集成电路芯片被静电击穿。
第四,使用或维护过程中触及电脑内任何电路时,规范的做法是戴上防静电腕套。对广大的普通用户而言,可以先碰一下电脑机箱金属机壳以释放身体上的静电(前提是电路确实已经接地,否则达不到释放静电的作用)。如果无法确认电路是否接地,那么也可以采用碰触自来水管的方法释放静电。
第五,.平时插拔USB或IEEE 1394设备时,应该按照第4点提出的方法预先释放身体上的静电,减少因静电而损坏设备和配件的几率。
与此同时,顶星的主板在各个易受ESD干扰的部位都上有ESD防护装置,只要用户在使用过程成中操作得当,那么相信ESD就不会出现,干扰用户的正常使用电脑。
aczg01987
这个一定有的
防雷方面学习啦
zvszcs
LV.12
这要看在那部分防雷咯,高压输入端,TI一个没有,低压有一点点产品少的可伶,不是TI的主攻方向
高压防雷:压敏电阻,安规电容,放电管,TVS
低压:压敏电阻,TVS,等等
@daxia4540827
ESD即静电释放,它对于精密半导体芯片会造成各种损伤,例如穿透元器件内部薄的绝缘层;损毁MOSFET和CMOS元件的栅极;CMOS器件中的触发器锁死;造成反向偏置和正向偏置的PN结短路;融化有源器件内部的焊接线或铝线。在电脑行业,ESD更是频繁出现的无形杀手,主要表现在:1雷击或其他静电放电导致网卡损坏2芯片组烧毁,如早几年某主板大厂由于USB接口的ESD问题引起大量南桥烧坏3IO接口问题导致主板上的元件损坏,如三极管烧毁4系统出错,重启,硬盘数据丢失等在主板设计时加入有效的ESD防护措施,可最大程度上防治上述各项损害的发生,从而提高主板品质,加长工作寿命。通常主板元器件在遭受ESD后可通俗分为三种状态:健康,死亡,受伤。健康的,该元件有适当的ESD防护处理,可正常运行几年时间。死亡的,该元件没有ESD防护,而遭受严重的ESD损害,不能正常运行。受伤的,该元件遭受部分损坏,含有潜在的缺陷。虽然短时间内不易发觉,但是在使用过程中出现过早实效。电脑遭受ESD的途径有两种:1、人体接触时引起(如:用户在操作开机、复位、插拔USB等设备时)2.、雷击(如:通过网卡)顶星科技秉承“让我们的客户永远快乐”为宗旨,在主板设计的时候加入了许多防护ESD的设计,让用户在使用电脑的过程当中,防御了ESD的干扰。当然我们在使用电脑的时候也要操作得当,让ESD无处藏身。下面顶星教教你,在您使用电脑的时候应该注意的地方:第一,电脑机壳需要可靠接地;第二,北方地区在秋冬季节应使用加湿器,保持室内空气的一定湿度,防止静电在设备、家具和身体上大量积累;第三,在运输和储存过程中要将电脑整机或零部件置于静电屏蔽袋或导电搬运箱内进行运输防止集成电路芯片被静电击穿。第四,使用或维护过程中触及电脑内任何电路时,规范的做法是戴上防静电腕套。对广大的普通用户而言,可以先碰一下电脑机箱金属机壳以释放身体上的静电(前提是电路确实已经接地,否则达不到释放静电的作用)。如果无法确认电路是否接地,那么也可以采用碰触自来水管的方法释放静电。第五,.平时插拔USB或IEEE1394设备时,应该按照第4点提出的方法预先释放身体上的静电,减少因静电而损坏设备和配件的几率。与此同时,顶星的主板在各个易受ESD干扰的部位都上有ESD防护装置,只要用户在使用过程成中操作得当,那么相信ESD就不会出现,干扰用户的正常使用电脑。
You的
@26308497
You的
有~~
http://www.ti.com.cn/product/cn/tpd4e101#feature~
TPD4E101
(ACTIVE) 4 通道双向低电容 ESD 保护设备
说明
The TPD4E101 is a four channel ESD protection device in an ultra small package. It is the industry’s smallest 4-ch ESD protection device. A larger pitch helps save on PCB manufacturing costs. The device provides IEC61000-4-2 compliance up to 15kV contact discharge. It has an ESD clamp circuit with back-to-back diodes for bipolar/bidirectional signal support. The low line capacitance is suitable for a wide range of applications supporting data rate up to 700Mbps.Typical application areas in portable applications are:
  • SD interface
  • SIM interface
jiame2006
@javike
学习了
yangyixian
@zvszcs
这要看在那部分防雷咯,高压输入端,TI一个没有,低压有一点点产品少的可伶,不是TI的主攻方向高压防雷:压敏电阻,安规电容,放电管,TVS低压:压敏电阻,TVS,等等
学习了
gaos233
@zvszcs
你好,我想问一下你所说的高压防雷是电压范围是多少?低压又是多少呢?
dhtr54354
@daxia4540827
