APT MOSFET 模块拓朴
不同于IGBT,MOSFET由于自身特性所限,很少在大功率场合担当重任.况且大功率的MOSFET制作相当困难成本昂贵惊人,所以MOSFET模块在通用市场较为少见.
在少数场合,系统同时对功率和频率都要求很高,此时IGBT模块不能胜任,这才是MOSFET模块发挥作用的时候.
APT提供多种拓朴的MOSFET模块,电压从100V到1200V;电流最大高达640A.
1.ASYMMETRICAL BRIDGE
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152352986.gif');}" onmousewheel="return imgzoom(this);">
全部回复(18)
oude
2.boost chopper
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152353089.gif');}" onmousewheel="return imgzoom(this);">
oude
3.BOOST CHOPPER WITH SIC DIODES
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152353161.gif');}" onmousewheel="return imgzoom(this);">
oude
4.buck chopper
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152353224.gif');}" onmousewheel="return imgzoom(this);">
oude
5.dual boost chopper
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152353324.gif');}" onmousewheel="return imgzoom(this);">
oude
6.dual buck chopper
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152353385.gif');}" onmousewheel="return imgzoom(this);">
oude
7.DUAL COMMON SOURCE
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152353502.gif');}" onmousewheel="return imgzoom(this);">
oude
8.full bridge
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152353613.gif');}" onmousewheel="return imgzoom(this);">
oude
9.full bridge+SERIES AND PARALLEL DIODES
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152353754.gif');}" onmousewheel="return imgzoom(this);">
oude
10.FULL BRIDGE+SERIES AND SIC PARALLEL DIODES
(此拓朴有mos和coolmos两种模块)
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152353886.gif');}" onmousewheel="return imgzoom(this);">
oude
11.PHASE LEG
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152497187.gif');}" onmousewheel="return imgzoom(this);">
oude
12.PHASE LEG+SERIES AND PARALLEL DIODES
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152497261.gif');}" onmousewheel="return imgzoom(this);">
oude
13.PHASE LEG+SERIES AND SIC PARALLEL DIODES
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152497325.gif');}" onmousewheel="return imgzoom(this);">
oude
14.PHASE LEG+SERIES DIODES
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152497462.gif');}" onmousewheel="return imgzoom(this);">
oude
15.SINGLE SWITCH
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152497514.gif');}" onmousewheel="return imgzoom(this);">
oude
16.SINGLE SWITCH+SERIES AND PARALLEL DIODES
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152497592.gif');}" onmousewheel="return imgzoom(this);">
oude
17.SINGLE SWITCH+SERIES DIODE
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152497660.gif');}" onmousewheel="return imgzoom(this);">
oude
18.TRIPLE DUAL COMMON SOURCE
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152497738.gif');}" onmousewheel="return imgzoom(this);">
oude
19.TRIPLE PHASE LEG
500) {this.resized=true; this.width=500; this.alt='这是一张缩略图,点击可放大。\n按住CTRL,滚动鼠标滚轮可自由缩放';this.style.cursor='hand'}" onclick="if(!this.resized) {return true;} else {window.open('http://u.dianyuan.com/bbs/u/43/1152497825.gif');}" onmousewheel="return imgzoom(this);">
