高手请进!!!!!!!
我这里有份关于日本菱形PSE认证的清单,全英文现在请高手帮忙翻译成中文下,谢谢先
PSE目录清单
PSE目录清单
[Rubber Insulated Cables and Cords]
1、Rubber insulated cables
2、Cables (having a conductor nominal crosssectional area of 22 mm2 or less)
3、Single-core rubber cords
4、Twisted rubber cords
5、Textile braided rubber cords
6、Round braided rubber cords
7、Other rubber cords
8、Sheathed flexible cords
9、Rubber sheathed flexible cables
10、PVC sheathed flexible cables[Synthetic Resin Insulated Cables and Cords]
11、Plastic insulated cables
12、Cables (having a conductor nominal cross-sectional area of 22 mm2 or less)
13、Single-core PVC cords
14、Single-core polyethylene cords (newly added item)15、Twisted PVC insulated cords
16、Textile braided PVC cords
17、Round braided PVC cords
18、Other PVC cords
19、Other polyethylene cords (newly added item)
20、Sheathed flexible cords
21、Tinsel cords
22、PVC sheathed flexible cables
●Fuses
23、Thermal links
24、Link fuses
25、Cartridge fuses
26、Other enclosed fuses
●Wiring Devices
27、Tumbler switches
28、Switches in flexible cord
29、Time switches
30、Rotary switches
31、Pushbutton switches32、Pull switches
33、Pendant switches
34、Streetlamp switches
35、Photoelectric automatic switches
36、Other switches
37、Box switches
38、Float switches
39、Pressure switches
40、Sewing machine controllers
41、Molded case circuit breakers
42、Residual current operated circuit breakers
43、Cutout
44、Attachment plugs
45、Socket-outlets
46、Multiple socket-outlets (with cord or pins for power supply connections)
47、Cord connector bodies
48、Flatiron plugs
49、Appliance connectors
50、Adaptors
51、Cord reels
52、Other plug couplers
53、Lamp receptacles (Fixed lampholders)
54、Separable plug bodies
55、Other screw couplers
56、Fluorescent lampholders
57、Fluorescent starter holders
58、Split sockets (Lampholders with socketoutlets and/or lampholders)
59、Keyless sockets (Keyless lampholders)
60、Waterproof sockets (Waterproof lampholders)
61、Key sockets (Key-type lampholders)
62、Pull sockets (Pull-type lampholders)
63、Pushbutton sockets (Pushbutton-type lampholders)64、Other sockets (Other lampholders)
65、Screw-in rosettes
66、Hookup rosettes
67、Other rosettes
68、Joint boxes
●Current Limiters
69、Meter rate current limiters
70、Flat rate current limiters
●Transformers, Ballasts
71、Transformers for toys
72、Other household appliance transformers
73、Electronic appliance transformers
74、Ballasts for fluorescent lamps
75、Ballasts for mercury vapor lamps and ballasts for other high pressure discharge lamps
76、Ballasts for ozonizer
●Electric Heating Appliances
77、Electric heated toilet seats
78、Electric hot cupboard
79、Electric pipe freeze prevention heaters
80、Glass dew-prevention heaters
81、Electric heaters for freeze and condensation prevention
82、Electric storage water heaters
83、Electric inhalators
84、Household heating therapeutic appliances
85、Electric steam baths
86、Electric heaters for steam baths
87、Electric sauna baths
88、Electric heaters for sauna baths
89、Aquarium heaters
90、Heating appliances for garden plants
91、Electric heated toys
●Electric Motor-operated or Magnetically Driven Appliances
92、Electric pumps
93、Electric well pumps
94、Refrigerating showcases
95、Freezing showcases
96、Electric ice cream freezers
97、Electric food waste disposers
98、Electric massagers
99、Automatically washing and drying toilets
100、Vending machines
101、Electric bubble generators for bathtubs
102、Electric bubble generators for aquariums
103、Other electric bubble generators
104、Electric motor-operated toys
105、Electric vehicles
106、Other electric motor-operated or electromagnetically driven amusement appliances
●Electronic Appliances
107、High-frequency depilators
●Other AC Electric Appliances
108、Magnetic therapeutic appliances
109、Electric insect killers
110、Electric therapeutic bath controllers
111、DC power supply units
●Portable Engine Generators
112、Portable engine generators
全部回复(0)
