关于 斯里兰卡 的国标是否可以用IEC标准?
如题,请教各位达人.
全部回复(6)
@yplvf
斯里兰卡的认证,没有人做过吗?
Sri Lanka Standards Institution (SLSI)
National Standards Body & Member Body of ISO in Sri Lanka
PRODUCT TESTS
1 13 A Switched Socket Outlets SLS 734
2 13 A Plug SLS 734
3 Switches SLS 1000
4 5/15A Switched Socket Outlet SLS 948 Parts I & II
5 Unswitched Socket Outlets SLS 948 Part I
6 5/15 A Plug SLS 948
7 Ceiling fan regulator SLS 814 Part I
8 Electric kettle SLS 630
9 Immersion water heater SLS 691
10 Hot plates SLS 646
11 Telecommunication cable SLS 986
12 PVC insulated cable SLS 733
13 PVC Flexible cords SLS 1143
14 Aluminium conductor SLS 750
15 Lampholders SLS 138
16 Auto cables SLS 412
17 Ceiling rose SLS 320
18 Ballast ( for energy labeling) SLS 1200
19 RCCB SLS 1022
20 Electric lamps
25 W
40 W
60 W
75 W
100 W SLS 984
21 Batteries
R20 (39 Oum)
R20(3.9 Oum)
R6(300 Oum)
R6 (10 Oum) SLS 319
PRODUCT TESTS
2 13 A Plug SLS 734
3 Switches SLS 1000
19 RCCB SLS 1022
20 Electric lamps
25 W
40 W
60 W
75 W
100 W SLS 984
21 Batteries
R20 (39 Oum)
R20(3.9 Oum)
R6(300 Oum)
R6 (10 Oum) SLS 319
@yplvf
斯里兰卡的认证,没有人做过吗?
In the formulation of National Standard, the policy of the Sri Lanka Standards Institution is to be in line with the International Standards and practices as far as practicable. To this effect International Standards are adopted, as Sri Lanka Standards, wherever feasible.
接受IEC标准
接受IEC标准
@ginger.wei
IntheformulationofNationalStandard,thepolicyoftheSriLankaStandardsInstitutionistobeinlinewiththeInternationalStandardsandpracticesasfaraspracticable.TothiseffectInternationalStandardsareadopted,asSriLankaStandards,whereverfeasible.接受IEC标准
谢谢!
由于今天才看到,所以现在才回复您!
那么应该也是可以用CB来转是吗?还有没有相关的偏差测试需要呢?
由于今天才看到,所以现在才回复您!
