請教墨西哥電壓及耐壓要求
各位安規同仁,你們好!我想請教一個問題:墨西哥電壓(120V OR 127V)及耐壓要求(1500V OR 3000V),請大哥大姐幫忙回復,謝謝!
全部回复(11)
For Mexico NOM mark, it is 127Vac, Hi-Pot (Electric Strenth Test)can follow related IEC standards, such as IEC 60950-1 if your adapter is for ITE use. Pri to Ground use AC 3000V/1 min, Pri to Sec use AC1500V/1 min.
@cerpass-karl
ForMexicoNOMmark,itis127Vac,Hi-Pot(ElectricStrenthTest)canfollowrelatedIECstandards,suchasIEC60950-1ifyouradapterisforITEuse.PritoGrounduseAC3000V/1min,PritoSecuseAC1500V/1min.
謝謝您!但是我有聽講nom-001標準與iec60950-1標準不一樣,不知此情況是否正確.
@angelpeng2005
Hi Angel, Mexico just join CB member since this year. Basically NOM-001-SCFI-1993 is following IEC standards requirements without any problem.
@cerpass-karl
HiAngel,MexicojustjoinCBmembersincethisyear.BasicallyNOM-001-SCFI-1993isfollowingIECstandardsrequirementswithoutanyproblem.
了解,墨西哥是CB成員國.我司送樣的樣品是用60950去預測的,只是後來有個工程師跟我講與IEC標準不一樣.感覺奇怪.謝謝您的回復...
@cerpass-karl
Pri to Gound use AC3000V/1min, Pri to Sec use AC1500V/1min??????????
It should be Pri to Gound use AC1500V/1min, Pri to Sec use AC3000V/1min.
@safetytest
PritoGounduseAC3000V/1min,PritoSecuseAC1500V/1min??????????ItshouldbePritoGounduseAC1500V/1min,PritoSecuseAC3000V/1min.
You are correct, sorry for my typing error!
@safetytest
Tks!!!
@angelpeng2005
Tks!!!
i/p: 120V OR 127V, Pri. to Ground是Basic insulation, Hi-Po 1000Vac/1min, Pri. to Sec. 2000Vac, 若Transformer初次级之间工作电压有过184Vac, 则为3000Vac,此时应断开地线测.
若工作电压大于354V, 则需查IEC60950-1,Tabel5B, part2确定.
@safetypower
i/p:120VOR127V,Pri.toGround是Basicinsulation,Hi-Po1000Vac/1min,Pri.toSec.2000Vac,若Transformer初次级之间工作电压有过184Vac,则为3000Vac,此时应断开地线测.若工作电压大于354V,则需查IEC60950-1,Tabel5B,part2确定.
哇!怎麼答案這麼多,我都不知道哪一种是對的了.
safetypower
@angelpeng2005
大虾,看Standard: IEC60950-1,Tabel5B, part2为准,
@safetypower
大虾,看Standard:IEC60950-1,Tabel5B,part2为准,
哦,謝謝!
