那位大虾用过ICAP/4的帮帮我!
我昨天刚从 Intusoft的网站上下了个ICAP/4下来.高兴之余马上用它来仿真个电路,还以为以后对电路的仿真不用愁了呢,但想不到的是仿真的时候出来个这样的提示:
              Demo Limitation
   -The Demo has a 20 Parts Simulation limit. If you place more than 20 parts on the schematic or place a subcircuit model made up of more than 20 components, the Demo will stop with a "too complex" message when you try to simulate your circuit.
  -Reduced model library included.
Note: No Demo limit placed on adding your own SPICE3 compatible models.
  -Scope5 Demo will not allow you to use a text file of data points as a source.
-Scope5 Demo will not allow you to read in touchstone files and plot smithcharts.
   怎么会有这样的局限的呢,是不是我下的这个只能给人看的呀?请大虾们有无谁试过这样情况的呀?
全部回复(0)
