FCC警告
那位大俠知道美國FCC最新警告語句嗎?
謝了!
全部回复(5)
ds1983
严厉打击伊拉克产品进入我国境内!
cerpass
@ds1983
严厉打击伊拉克产品进入我国境内!
晕为什么要打击呀
mikesu
2006 年最新的 47 CFR Part 15 subpart B 並沒有更動警語.
Class B, 常見 ITE 者需有以下.
FCC : 47 CFR
15.19 Labelling requirements.
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation.
FCC LOGO, MODEL NO, TRADE NAME.
15.21   Information to user.
The users manual or instruction manual for an intentional or unintentional radiator shall caution the user that changes or modifications not expressly approved by the party responsible for compliance could void the user's authority to operate the equipment.
15.105   Information to the user.
(b) For a Class B digital device or peripheral, the instructions furnished the user shall include the following or similar statement, placed in a prominent location in the text of the manual:
Note: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
—Reorient or relocate the receiving antenna.
—Increase the separation between the equipment and receiver.
—Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
—Consult the dealer or an experienced radio/TV technician for help.
直接找大廠的使用手冊. 會比較快.
@ds1983
严厉打击伊拉克产品进入我国境内!
DS1983兄,支持!!哈哈
huang2747
@mikesu
2006年最新的47CFRPart15subpartB並沒有更動警語.ClassB,常見ITE者需有以下.FCC:47CFR15.19Labellingrequirements.Thisdevicecomplieswithpart15oftheFCCRules.Operationissubjecttothefollowingtwoconditions:(1)Thisdevicemaynotcauseharmfulinterference,and(2)thisdevicemustacceptanyinterferencereceived,includinginterferencethatmaycauseundesiredoperation.FCCLOGO,MODELNO,TRADENAME.15.21  Informationtouser.Theusersmanualorinstructionmanualforanintentionalorunintentionalradiatorshallcautiontheuserthatchangesormodificationsnotexpresslyapprovedbythepartyresponsibleforcompliancecouldvoidtheuser'sauthoritytooperatetheequipment.15.105  Informationtotheuser.(b)ForaClassBdigitaldeviceorperipheral,theinstructionsfurnishedtheusershallincludethefollowingorsimilarstatement,placedinaprominentlocationinthetextofthemanual:Note:ThisequipmenthasbeentestedandfoundtocomplywiththelimitsforaClassBdigitaldevice,pursuanttopart15oftheFCCRules.Theselimitsaredesignedtoprovidereasonableprotectionagainstharmfulinterferenceinaresidentialinstallation.Thisequipmentgenerates,usesandcanradiateradiofrequencyenergyand,ifnotinstalledandusedinaccordancewiththeinstructions,maycauseharmfulinterferencetoradiocommunications.However,thereisnoguaranteethatinterferencewillnotoccurinaparticularinstallation.Ifthisequipmentdoescauseharmfulinterferencetoradioortelevisionreception,whichcanbedeterminedbyturningtheequipmentoffandon,theuserisencouragedtotrytocorrecttheinterferencebyoneormoreofthefollowingmeasures:—Reorientorrelocatethereceivingantenna.—Increasetheseparationbetweentheequipmentandreceiver.—Connecttheequipmentintoanoutletonacircuitdifferentfromthattowhichthereceiverisconnected.—Consultthedealeroranexperiencedradio/TVtechnicianforhelp.直接找大廠的使用手冊.會比較快.
謝了.
