电磁炉的泄漏电流
我在检测电磁炉的泄漏电流时,发现电磁炉上的不锈钢锅体的泄漏电流达到3.6mA,是否可以判定这个电磁炉的泄漏电流不合格
全部回复(2)
IEC60335-1 clause 13.2有如下规定,
– for stationary class I heating appliances 0,75 mA or 0,75 mA per kW rated power input of the appliance with a maximum of 5 mA, whichever is higher.
一般电磁炉应该是驻立式1类电热器具,按照以上规定,要看你的功率,最大可以达到5mA,不知道电磁炉的part 2 特殊标准里有没有其他漏电流的规定,要查了才知道,没做过电磁炉,所以意见仅供参考啦.
@ivansunfeijian
IEC60335-1clause13.2有如下规定,–forstationaryclassIheatingappliances0,75mAor0,75mAperkWratedpowerinputoftheappliancewithamaximumof5mA,whicheverishigher.一般电磁炉应该是驻立式1类电热器具,按照以上规定,要看你的功率,最大可以达到5mA,不知道电磁炉的part2特殊标准里有没有其他漏电流的规定,要查了才知道,没做过电磁炉,所以意见仅供参考啦.
IEC60335-2-9 clause 13.2如下规定:
-If there is earthed metal between live parts and the surface of glass-ceramic or similar material of hotplates, the leakage current is measured between live parts and each vessel in turn connected to the earthed metal. It shall not exceed 0,75 mA. If there is no earthed metal, the leakage current, measured between live parts and each of the vessels in turn, shall not exceed 0,25 mA.
-电磁炉看作是便携式器具,
-不能超过0.25mA啊
你的是什么电磁炉啊锅有这么大的漏电流,第一次听.
