请问:哪位大哥有各种铁氧体磁芯的详细资料?
急需各种磁芯的资料,请各位帮忙,感谢!!!
全部回复(12)
Series Categories Details
E Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC33, PC40, PC44, PC50, HS10, HS52, HS72 PDF:2731KB
EAK-G Power Supplies AC Input Single Output, General-purpose 100V Input PDF:426KB
EC Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC33, PC40, PC44, PC50, HS10, HS52, HS72 PDF:2731KB
EC Ferrites Cores for Transformers / Choke Coils / Filters For High Power Materials: PC40, PE22 PDF:304KB
EC Ferrites Cores for Transformers / Choke Coils / Filters For High Power Materials: PC40, PE22 PDF:247KB
ECW Power Supplies AC Input Multi Output, General-purpose 85-265V Wide Input PDF:79KB
ECX Power Supplies AC Input Multi Output, General-purpose 100/200V Wide Input PDF:398KB
EE Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC33, PC40, PC44, PC50, HS10, HS52, HS72 PDF:2731KB
EE Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC40, PC44, PC50, HS10, HS52, HS72 PDF:1460KB
EE Ferrites Cores for Transformers / Choke Coils / Filters For High Power Materials: PC40, PE22 PDF:304KB
EE Ferrites Cores for Transformers / Choke Coils / Filters For High Power Materials: PC40, PE22 PDF:247KB
EER Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC33, PC40, PC44, PC50, HS10, HS52, HS72 PDF:2731KB
EER Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC40, PC44, PC50, HS10, HS52, HS72 PDF:1460KB
EF Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC33, PC40, PC44, PC50, HS10, HS52, HS72 PDF:2731KB
EFS Sensors Surface Potential Sensors Feed-back Type - PDF:182KB
EI Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC33, PC40, PC44, PC50, HS10, HS52, HS72 PDF:2731KB
EI Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC40, PC44, PC50, HS10, HS52, HS72 PDF:1460KB
EI Ferrites Cores for Transformers / Choke Coils / Filters For High Power Materials: PC40, PE22 PDF:304KB
EI Ferrites Cores for Transformers / Choke Coils / Filters For High Power Materials: PC40, PE22 PDF:247KB
EIC Ferrites Cores for Transformers / Choke Coils / Filters For High Power Materials: PC40, PE22 PDF:304KB
EIC Ferrites Cores for Transformers / Choke Coils / Filters For High Power Materials: PC40, PE22 PDF:247KB
EL0305 Inductors(Coils) Radial Lead For Signal Line 0.22 to 470uH PDF:44KB
EL0405 Inductors(Coils) Radial Lead For Signal Line 0.22 to 1,000uH PDF:50KB
EL0606 Inductors(Coils) Radial Lead For Signal Line 0.22 to 2,200uH PDF:52KB
EL0607 Inductors(Coils) Radial Lead For Signal Line 10 to 15,000uH PDF:51KB
EL0909 Inductors(Coils) Radial Lead For Signal Line 100 to 56,000uH PDF:48KB
ELC0607 Inductors(Coils) Radial Lead For Power Line 1 to 470uH PDF:50KB
ELF0505 Inductors(Coils) Radial Lead For Signal Line(Magnetic Shielded) 0.22 to 1,200uH PDF:52KB
ELF0607 Inductors(Coils) Radial Lead For Signal Line(Magnetic Shielded) 0.22 to 2,700uH PDF:52KB
ELF0708 Inductors(Coils) Radial Lead For Signal Line(Magnetic Shielded) 10 to 33,000uH PDF:56KB
ELF1010 Inductors(Coils) Radial Lead For Signal Line(Magnetic Shielded) 100 to 100,000uH PDF:57KB
EP Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC33, PC40, PC44, PC50, HS10, HS52, HS72 PDF:2731KB
EP Ferrites Cores for Transformers / Choke Coils / Filters For Transmitting Transformers / Filters Materials: H5A, H5C2, H5C3, H5C4, H5C5, PC40, PC44, PC50 PDF:2063KB
EPC Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC33, PC40, PC44, PC50, HS10, HS52, HS72 PDF:2731KB
EPC Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC40, PC44, PC50, HS10, HS52, HS72 PDF:1460KB
ET Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC33, PC40, PC44, PC50, HS10, HS52, HS72 PDF:2731KB
ETD Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC33, PC40, PC44, PC50, HS10, HS52, HS72 PDF:2731KB
ETD Ferrites Cores for Transformers / Choke Coils / Filters For Main Transformers of Power Supplies / Line Filters / Smoothing Chokes Materials: PC40, PC44, PC50, HS10, HS52, HS72 PDF:1460KB
@造变压器的
SeriesCategoriesDetailsE Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC33,PC40,PC44,PC50,HS10,HS52,HS72 PDF:2731KB EAK-G PowerSupplies ACInput SingleOutput,General-purpose 100VInput PDF:426KB EC Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC33,PC40,PC44,PC50,HS10,HS52,HS72 PDF:2731KB EC Ferrites CoresforTransformers/ChokeCoils/Filters ForHighPower Materials:PC40,PE22 PDF:304KB EC Ferrites CoresforTransformers/ChokeCoils/Filters ForHighPower Materials:PC40,PE22 PDF:247KB ECW PowerSupplies ACInput MultiOutput,General-purpose 85-265VWideInput PDF:79KB ECX PowerSupplies ACInput MultiOutput,General-purpose 100/200VWideInput PDF:398KB EE Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC33,PC40,PC44,PC50,HS10,HS52,HS72 PDF:2731KB EE Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC40,PC44,PC50,HS10,HS52,HS72 PDF:1460KB EE Ferrites CoresforTransformers/ChokeCoils/Filters ForHighPower Materials:PC40,PE22 PDF:304KB EE Ferrites CoresforTransformers/ChokeCoils/Filters ForHighPower Materials:PC40,PE22 PDF:247KB EER Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC33,PC40,PC44,PC50,HS10,HS52,HS72 PDF:2731KB EER Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC40,PC44,PC50,HS10,HS52,HS72 PDF:1460KB EF Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC33,PC40,PC44,PC50,HS10,HS52,HS72 PDF:2731KB EFS Sensors SurfacePotentialSensors Feed-backType - PDF:182KB EI Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC33,PC40,PC44,PC50,HS10,HS52,HS72 PDF:2731KB EI Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC40,PC44,PC50,HS10,HS52,HS72 PDF:1460KB EI Ferrites CoresforTransformers/ChokeCoils/Filters ForHighPower Materials:PC40,PE22 PDF:304KB EI Ferrites CoresforTransformers/ChokeCoils/Filters ForHighPower Materials:PC40,PE22 PDF:247KB EIC Ferrites CoresforTransformers/ChokeCoils/Filters ForHighPower Materials:PC40,PE22 PDF:304KB SeriesCategoriesDetailsEIC Ferrites CoresforTransformers/ChokeCoils/Filters ForHighPower Materials:PC40,PE22 PDF:247KB EL0305 Inductors(Coils) RadialLead ForSignalLine 0.22to470uH PDF:44KB EL0405 Inductors(Coils) RadialLead ForSignalLine 0.22to1,000uH PDF:50KB EL0606 Inductors(Coils) RadialLead ForSignalLine 0.22to2,200uH PDF:52KB EL0607 Inductors(Coils) RadialLead ForSignalLine 10to15,000uH PDF:51KB EL0909 Inductors(Coils) RadialLead ForSignalLine 100to56,000uH PDF:48KB ELC0607 Inductors(Coils) RadialLead ForPowerLine 1to470uH PDF:50KB ELF0505 Inductors(Coils) RadialLead ForSignalLine(MagneticShielded) 0.22to1,200uH PDF:52KB ELF0607 Inductors(Coils) RadialLead ForSignalLine(MagneticShielded) 0.22to2,700uH PDF:52KB ELF0708 Inductors(Coils) RadialLead ForSignalLine(MagneticShielded) 10to33,000uH PDF:56KB ELF1010 Inductors(Coils) RadialLead ForSignalLine(MagneticShielded) 100to100,000uH PDF:57KB EP Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC33,PC40,PC44,PC50,HS10,HS52,HS72 PDF:2731KB EP Ferrites CoresforTransformers/ChokeCoils/Filters ForTransmittingTransformers/Filters Materials:H5A,H5C2,H5C3,H5C4,H5C5,PC40,PC44,PC50 PDF:2063KB EPC Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC33,PC40,PC44,PC50,HS10,HS52,HS72 PDF:2731KB EPC Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC40,PC44,PC50,HS10,HS52,HS72 PDF:1460KB ET Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC33,PC40,PC44,PC50,HS10,HS52,HS72 PDF:2731KB ETD Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC33,PC40,PC44,PC50,HS10,HS52,HS72 PDF:2731KB ETD Ferrites CoresforTransformers/ChokeCoils/Filters ForMainTransformersofPowerSupplies/LineFilters/SmoothingChokes Materials:PC40,PC44,PC50,HS10,HS52,HS72 PDF:1460KB
具体的给我说,我提供给你.qqhcy@tom.com
