who can give me a hand ?
It will be impossible for me to thermal test the unit accuratly, In order to perform thorough temperature test, The J-Type thermal couple is required on top of each major active components so i can read the temperature during test.
怎么翻译? 谢谢!
全部回复(3)
austen
要精确地完成温度测试是有困难的,为了顺利完成温度测试,需要将J型热偶置于主要器件的上面,以致能在测试过程中读出温度值
ahhajane
@austen
You are great, Thank you, i really appreciated.
andyliu
@ahhajane
Youaregreat,Thankyou,ireallyappreciated.
HOW are you!
【有奖互动】能量新势力:开启探索PI新能源之旅
电源网-天边
LLC电源谐振电容大小波是什么原因
zengzh
沈夜
设计GAN器件逆变器出现的一个非常离奇的问题
dy-vuifQK9d
mos管切换电路
dy-5VGUDDs1
