电源中变压器高压测试通不过,DX们快来帮一把!!
客户的话:
Because the failure of HI-POT test for Australia DVD228 model, we would like you to discuss with the SMPS vendor for the improvement.
The testing condition for this Hi-Pot test is 3,750 V.  Gibson has evaluated that the transformer must be changed in order to withstand up to 3,750 V.
各位DX我在设计时电源是用3000VAC 测试1分钟,没见问题.3750V这是什么测试规格呀!那我的TRANSFORMER该怎么改呀?TKS!
全部回复(4)
EFD-25线架 成品外包铜带 1098893143.pdf
黄炳辉
你的电源是销往欧洲国家的,所以变压器要经过安规认证,有的P-S的HI-POT要做到1800VAC或3750VAC,我打不开你的文件不然可以帮你参考一下,你的漏电流是用多少.
bijingxin
@5156
EFD-25线架成品外包铜带1098893143.pdf
你的爬电距离我觉得不够,4.5mm比较好一点!你先试一下好吗?
@黄炳辉
谢谢两位.好几天没来这儿啦.我拿到客户寄回的样品测试发现,原来是变压器厂家在生产时将铁弗龙管漏装,在打3000VAC时可以通过,加到3750VAC时出现电弧.装上就好了!
