电源测试系统ATC1500-DRX
ATC1500-DRX适用于电源厂生产线测试使用。
双机机柜型测试,测试速度快,同时可迅速形成测试报表,有效的提高了工厂的品质控制能力。
介 绍
适用:150W以下单路输出之充电器,电源适配器,LED驱动电源!
主要功能特点:
1.可以测试150W以内任何单组输出电源
2.图形界面基于Windows XP环境
3.测试程序编辑功能
4.测试项目选择功能(输入/输出/空载/短路
5.欠压/稳压/过载/纹波/效率等功能)
6.统计测试报告(Excel电子档)
7.自动生成CPK等品质报表
8.配置灵活
9.性价比高,适合大中小企业。
10.测试速度快
11.测试不良结果实时打印功能
测试项目:
启动测试(Start-up)
欠压测试(UVLO)
待机测试(Idle)
恒压区测试(Standard CV)
恒流区测试(Standard CC)
短路测试(Short Circuit)
过压测试(Over Voltage)
过流测试(Over Current)
线调整(Line Regulation)
负载调整(Load Regulation)
关机测试(Power Down)
支持性测试(Support Function)
Test Name
Parameter and Range测试项目与量程
Accuracy
START UP 启动测试
Inrush current: 0 – 83Apk
Startup time: 0 to 32767msec.
Output voltage overshoot: 0 – 60Vpk
±1% (reading + range)
±1ms
UVLO欠压测试
Functional test only, Pass/Fail
N/A
IDLE待机测试
Standby input power: 0 – 5/25/250/1250W
Standby input current: 0 – 0.1/0.5/5/25Apk
Input voltage: 30 – 280V*Note 2
±0.1% (reading + range)
STANDARD CV
(Constant Current and Constant Resistance load) 恒流
CC Mode: 0 – 3/15 A
CR Mode: 0.1 – 50Ohm
Input Voltage: 30 – 300Vrms *Note 1
Input Current: 0 – 0.1/0.5/5/25Apk
Input Power: 0 – 5/25/250/1250W
Power Factor 0 – 1.0
Output Voltage 0 – 15/60Vdc
Output Current 0 – 3/15Adc
Efficiency: 0 – 100%
Ripple/Noise 200kHz: 0 – 500mV
Ripple/Noise 20MHz: 0 – 500mV
±0.15% (setting + range)
±0.3% (setting + range) *Note 2
±0.2% (reading + range)
±0.05% (reading + range)
±0.25% (reading + range)
±2% (reading + 5mV)
±2% (reading + 5mV)
STANDARD CC
(Constant Voltage and Constant Resistance load)恒压
CV Mode: 0 – 15/60V
Input voltage: 30 – 300Vrms *Note 1
Output Current 0 – 15Adc
±0.3% (setting + range) *Note 3
SHORT CIRCUIT
短路测试
Input voltage: 30 – 300 Vrms *Note 1
Input Current: 0 – 5/25Apk
Input Power: 0 – 250/1250W
Output Average Current: 0 – 15Adc
±0.2% (reading + range) *Note 4
OVER CURRENT
过流
Current trip point: 0 – 3/15Adc
Trip point voltage: 0 – 15/60Vdc
Wait Time >= 10msec.
Wait Time < 10msec.
Voltage Before Trip Point: 0 – 15/60Vdc
Current Before Trip Point: 0 – 3/15Adc
OVER VOLTAGE
过压测试
OV trip point: 0 – 60V
LINE REGULATION
线性调整率
Voltage regulation: 0 – 100%
LOAD REGULATION
负载负整率
AVERAGE EFFICIENCY
平均效率
I-V CURVE PLOT
I-V曲线
CC Mode: 0 – 3/15 A
CC Mode Output Voltage 0 – 15/60Vdc
CC Mode Output Current 0 – 3/15Adc
CV Mode: 0 – 15/60V
CV Mode Output Voltage 0 – 15/60Vdc
CV Mode  Output Current 0 – 15Adc
全部回复(0)
