求助:测试标准翻译(高手请进)
大家好,下面是应急灯的测试标准.高手能否翻译一下,多谢
1.   The luminance of the legend,directional indicator,graphical symbols,and backgrond shall be meatrued in units of foot-lamberts(cd/m2)from circular areas not smaller than 0.030 inch(0.8mm)diameter and not larger than the area under test will permit,maintaining a minimum distance of 0.015 inch (0.4mm)between the perimeter of circular target area and the surrounding edges of the letters,directional indicators,borders,and the sign frame.Typical meaturement points for certain sign designs are shown in figure 41.1-41.6.All measruement on the background of the panel face or edgelit sign shall be within 1 inch(25.4mm)of the outer edge of any letters,directional indicater,or graphical symbols.For all sign designs,the visually bright and dimmest locations on any luminance element shall be included in the the measruements.For measurement of the combined luminance of letters and borders,a maximum 0.050-inch(1.27mm) diameter circuit target area is to be concerned upon the the junction of the letter and border.A spacing equal to at least the radins of the target area is to be maintained between the perimeter of the target area and adjacent contrasting border lines.Measruements are to be made on the candidate sign operating under each condition sprcified in 41.1.6 in a test room having no illumination other than that provided by the candidate sign.The luminance values obtained on the letters,on the background,and on the borders(if applicable)are to be separately averaged.
2. For exit sign designs not represented by Figures 41.1-41.6,and for graphical symbols,no less than two measurements shall be taken for each continuous luminous element exceeding 1 inch(25.4mm)in major dimension,at intervals not exceeding 2inches(50.8mm)linear distance between measurements.The visually brightest and dimmest locations on any luminous element shall be included in the measurements.The visually brightest and dimmest locations on any luminous element shall be included in the measurements.The contrast ratio shall be calculated(using the formula of 41.3.2)between all adjacent luminous elements that require contrst for that element to be visible.
全部回复(2)
hylz
我来试试吧
hylz
1.传说的亮度,方向的指示器,图解式的符号和 backgrond 将在单位的脚中是 meatrued-来自圆形的区域的朗伯 (cd/m 2) 不是比 0.030 寸 (0.8 毫米) 直径小而且不是比区域大在测试之下将会允许,维持圆形目标区域的周长和信的周围边缘、方向的指示器,边缘和告示框架之间的 0.015 寸 (0.4 毫米) 的最小距离.对于特定的告示设计的典型 meaturement 点被显示在那视觉上明亮和在任何的亮度元素上的 dimmest 位置将被包含在 measruements 之中.因为信的组合亮度和边缘的测量,一个最大的 0.050 寸 (1.27 毫米) 直径线路目标区域是被在信的联接和边缘之上关心.一个间隔对至少目标区域的 radins 等于是在目标区域的周长和毗连的对比边缘线之间被维护,Measruements 是在 41.1.6 在由候选人告示提供超过那另外地没有照明的一个测试房间中在每情况 sprcified 之下操作的候选人告示上被做.在背景上,亮度价值在信上获得,和在边缘 (如果可适用) 上是分开地被平均.
2.因为出口告示设计不表现图 41.1-41.6, 和为图解式的符号 , 没有少于二个测量了将为每个连续的发光元素主要的尺寸的非常的 1 寸 (25.4 毫米) 被采取,在间隔不在测量之间的非常 2 寸 (50.8 毫米) 线性距离,在任何的发光元素上的最视觉上明亮和 dimmest 位置将被包含在测量之中.在任何的发光元素上的最视觉上明亮和 dimmest 位置将被包含在测量之中.差别比将在为那一种元素需要 contrst 的所有的毗连发光的元素之间被计算 (使用 41.3.2 公式) 是看得见的.
出入不会太大,请问高手出自何方?以后有机会的话多多交流一下,lx561@163.com
