SIMetix中怎么导入TI的芯片spice模型?
我从TI的官网上下了个LM5021的PSPICE模型。打开之后发现LIB文件下面包含了三个SUBCKT。导入到SIMetrix里的时候,就有三个symbol。
.SUBCKT LM5021_1 COMP VIN VCC OUT CS RT SS
Gvcc1 VCC3 0 VALUE { {exp((V(VCC3)-36)/0.05)} }
Gpwm1 0 SS VALUE { if( V(hiccup)<=2.5 & V(DriverOff)<=2.5 , 22u,0)
Gpwm2 0 SS VALUE { if( V(hiccup)<=2.5 & V(COMP)>4.7& V(SS)>4.5
+ ,-32u,0) }
Gpwm3 0 SS VALUE { if( V(hiccup)>2.5 ,-15u,0) }
Evcc4 VCC7 0 VALUE { IF(V(VCC)>7,5,0) }
Ehic1 HICCUPRESET 0 VALUE { if(V(DriverOff) > 2.5 | V(SS)<=0.3,5,0) }
Ehic2 HICCUPTRIGGER 0 VALUE { if(V(COMP)>4.5 & V(SS)<= 4.7 &
+ V(Driveroff)<=2.5 & V(MaxDuty)>2.5,5,0) }
Ehic4 HIC3 0 VALUE { if(V(COMP_1p25)<=0.125 & V(Driveroff)<=2.5,5,0)
Evcc6 VCC5 0 VALUE { IF(V(VIN)>20,5,0) }
Evcc5 VCC8 0 VALUE { IF(V(VCC)<=5.8,5,0) }
Evcc2 VDD 0 VALUE { IF(V(VCCUV_B)>2.5,5.2,0) }
Evcc1 VCC1 VCC VALUE { IF(V(VCCEN)>2.5,MIN((8.5-V(VCC))*200,5),0) }
Evcc7 VCC6 0 VALUE { IF(V(VIN)<=7.25,5,0) }
Evcc3 VCC4 0 VALUE { IF(V(VDD)>4.5,2,0) }
Eleb1 LEB2 0 VALUE { if(V(CLK)>2.5 ,5,0) }
Eosc1 CLK1 0 VALUE { if(V(MAXDUTY)<=2.5,5,0) }
Eramp2 RAMP4 0 VALUE { if(V(LEB)>2.5 ,5,0) }
Eramp3 RAMP7 0 VALUE { if(V(LEB)>2.5 | V(DriverOFF)>2.5,5,0) }
Epwm4 PWM6 0 VALUE { if(V(MAXDUTY)>2.5 & V(DriverOFF)<=2.5 & V(Q)
+ >2.5 & V(hiccup)<=2.5,5,0) }
Epwm6 PWM3 0 SS 0 1
Epwm3 RESET 0 VALUE { if(V(CSint)>V(COMPint) | V(CSint)>0.5 |
+ V(LatchedSkipCycle)>2.5,5,0) }
Epwm5 PWM8 PWM7 VALUE { if(V(PWM)>2.5 & V(DriverOFF)<=2.5, 7.5, -7.5)
Epwm1 COMP_1P25 0 PWM1 0 1
Epwm2 SSLOW 0 VALUE { if( V(SS)<=0.2 & V(DriverOff)<=2.5,5,0) }
Ehic3 HIC2 0 VALUE { if(V(COMP_1p25)>0.130,5,0) }
XUvcc1 VCC5 VCC6 VCCEN_B VCCEN RSFF
XUvcc2 VCC7 VCC8 DRIVEROFF VCCUV_B RSFF
XUpwm1 SSLOW DRIVEROFF SSDISCHARGE SSDISCHARGEB RSFF
XUhic3 SKIPCYCLE CLK LATCHEDSKIPCYCLE LATCHDSKIPCYCLEB TFF
XUhic1 HICCUPRESET HIC1 HICCUP HICCUPB RSFF
XUhic2 HIC2 HIC3 SKIPCYCLE SKIPCYCLEB RSFF
XUpwm2 RESET CLK Q QZ RSFF
Vpwm1 COMP PWM1 1.25
VRT VCC4 RT 0
V5V V5V 0 5.2
Mpwm1 VCC PWM9 PWM7 PWM7 NMOSdriverH
+ M=1
Mpwm2 0 PWM10 PWM7 PWM7 PMOSdriverL
+ M=1
Mvcc1 VIN VCC2 VCC VCC NMOS1mAVCC
+ M=15
Tleb1 LEB 0 LEB2 0 Z0=1 TD=90n
Dpwm1 COMP PWM11 Dnom
Cosc1 CLK 0 2p IC=0
Cosc2 MAXDUTY 0 2p IC=0
Cramp1 VSLOPE 0 10p IC=0
Cramp7 RAMP3 0 10p IC=0
Cramp2 RAMP9 0 10p IC=0
Cramp3 CSINT 0 10p IC=0
Cramp5 CS 0 10p IC=0
Cramp6 RAMP6 0 10p IC=5
Cpwm2 PWM5 0 10p IC=5
Cpwm3 PWM 0 10p IC=0
Cpwm1 COMPINT 0 5p IC=0
Chic1 HIC1 0 10p IC=5
Cosc3 OSC1 0 2p IC=0
Rvinloss1 0 VIN 833k TC=0,0
Rvccloss1 0 VCC 3.4k TC=0,0
Rvinzener1 VCC3 VIN 40k TC=0,0
Rvcc1 VCC2 VCC1 1 TC=0,0
Rleb1 LEB 0 1
Rosc1 CLK CLK1 500
Rosc2 MAXDUTY MAXDUTY1 500
Rramp6 CS 0 45k
Rramp2 RAMP9 RAMP10 500
Rramp1 VSLOPE RAMP8 500
Rramp9 RAMP3 RAMP4 500
Rramp3 RAMP2 CSINT 10
Rramp4 CSINT CS 1800
Rramp7 RAMP5 CS 36
Rramp8 RAMP7 RAMP6 500 TC=0,0
Rpwm1 COMPINT COMP_1P25 10k
Rpwm5 SSDISCHARGE PWM5 500 TC=0,0
Rpwm10 COMP VDD 5k
Rpwm3 PWM3 PWM11 1
Rpwm7 PWM8 PWM9 1
Rpwm4 SS PWM4 60
Rpwm2 0 COMPINT 5k
Rpwm9 PWM7 OUT 1
Rpwm8 PWM8 PWM10 1
Rpwm6 PWM PWM6 500
Rhic1 HICCUPTRIGGER HIC1 1 TC=0,0
Rosc3 OSC1 OSC2 500
Spwm1 PWM4 0 PWM5 0 S5K
Sramp3 RAMP5 0 RAMP6 0 S5K
Sramp2 RAMP2 CS RAMP3 0 S5K
Sramp1 RAMP8 0 RAMP9 0 S5K
Sclamp1 COMP V5V COMP V5V SWCLAMP
Sclamp2 SS V5V SS V5V SWCLAMP
Sclamp3 0 COMP 0 COMP SWCLAMP
Sclamp4 0 SS 0 SS SWCLAMP
Rgiga1 PWM5 0 1G
Rgiga2 RAMP6 0 1G
Rgiga3 RAMP3 0 1G
Rgiga4 RAMP9 0 1G
Rgiga5 COMP V5V 1G
Rgiga6 SS V5V 1G
Rgiga7 0 COMP 1G
Rgiga8 0 SS 1G
*21-1
Gramp1 0 CSINT VALUE { V(VSLOPE)*50E-6 }
Gramp2 0 VSLOPE VALUE { I(VRT)*0.03315 }
Eramp1 RAMP10 0 VALUE { if(V(MAXDUTY)<2.5 ,5,0) }
Eosc2 MAXDUTY1 0 VALUE { if(V(OSC1)>-0.92,5,0) }
Eosc3 OSC2 0 VALUE { if(V(VDD)>4.5,sin(2.082E10*i(VRT)*TIME),0) }
*21-2
*Gramp1 0 CSINT VALUE { V(VSLOPE)*50E-9 }
*Gramp2 0 VSLOPE VALUE { I(VRT)*0.03315/2 }
*Eramp1 RAMP10 0 VALUE { 5 }
*Eosc2 MAXDUTY1 0 VALUE { if(V(OSC1)>-0,5,0) }
*Eosc3 OSC2 0 VALUE { if(V(VDD)>4.5,sin(1.041E10*i(VRT)*TIME),0) }
*saturated@5Vgate
.MODEL NMOS100nA NMOS( LEVEL=3 KP=0.125E-7 RG=500 CGSO=4E-12 VTO=1)
.MODEL NMOS1uA NMOS( LEVEL=3 KP=0.125E-6 RG=500 CGSO=4E-12 VTO=1)
.MODEL NMOS10uA NMOS( LEVEL=3 KP=0.125E-5 RG=500 CGSO=4E-12 VTO=1)
.MODEL NMOS100uA NMOS( LEVEL=3 KP=0.125E-4 RG=500 CGSO=4E-12 VTO=1)
.MODEL NMOS1mA NMOS( LEVEL=3 KP=0.125E-3 RG=500 CGSO=4E-12 VTO=1)
.MODEL NMOS10mA NMOS( LEVEL=3 KP=0.125E-2 RG=500 CGSO=4E-12 VTO=1)
.MODEL NMOS100mA NMOS( LEVEL=3 KP=0.125E-1 RG=500 CGSO=4E-12 VTO=1)
.MODEL NMOS1A NMOS( LEVEL=3 KP=0.125 RG=500 CGSO=4E-12 VTO=1)
*300Ohm VCC regulator
.MODEL NMOS1mAVCC NMOS( LEVEL=3 KP=0.125E-3 RG=500 CGSO=4E-12 VTO=1 RD=300)
*12Ohm, 0.3A@half of 7.5Vcc
.MODEL NMOSdriverH NMOS( LEVEL=3 KP=0.0284 RG=500 CGSO=4E-12 VTO=1 RD=12)
*3Ohm, 0.7A@half of 7.5Vcc
.MODEL PMOSdriverL PMOS( LEVEL=3 KP=0.0662 RG=500 CGSO=4E-12 VTO=-1 RD=3)
.MODEL SWnom VSWITCH RON=0.001 ROFF=1MEG VON=2.5V VOFF=1V
.MODEL Dnom D IS=160n RS=35m N=1.1 BV=100 IBV=2m CJO=2p VJ=0.7 M=0.33 TT=1n
+EG=0.69 XTI=2
.MODEL SWtest VSWITCH RON=0.0001 ROFF=1MEG VON=1 VOFF=0.1
.MODEL S5K VSWITCH RON=1m ROFF=10MEG VON=2 VOFF=1V
.MODEL SWCLAMP VSWITCH RON=0.001 ROFF=100E6 VON=10m VOFF=0
.ENDS LM5021_1
.SUBCKT RSFF R S Q NQ
* Level Trigger
RFR R R1 500
RFS S S1 500
CFR R1 0 10p
CFS S1 0 10p
GQH 0 Q VALUE { IF(V(S1)>2.5 & V(R1)<=2.5, IF(V(Q)<=4,1,5-V(Q)), 0) }
GQL Q 0 VALUE { IF(V(R1)>2.5, IF(V(Q)>=1,1,V(Q)), 0) }
GNQH 0 NQ VALUE { IF(V(S1)<=2.5 & V(R1)>2.5, IF(V(NQ)<=4,1,5-V(NQ)), 0) }
GNQL NQ 0 VALUE { IF(V(S1)>2.5, IF(V(NQ)>=1,1,V(NQ)), 0) }
RQ Q 0 1G
RNQ NQ 0 1G
CQ NQ 0 4n IC=0
CNQ Q 0 4n IC=0
.ENDS RSFF
.SUBCKT TFF D C Q NQ
* Level Trigger Clock High Active
RFC C C1 500
RFD D D1 500
CFC C1 0 10p
CFD D1 0 10p
GQH 0 Q VALUE { IF(V(D1)>2.5 & V(C1)>2.5, IF(V(Q)<=4,1,5-V(Q)), 0) }
GQL Q 0 VALUE { IF(V(D1)<=2.5 & V(C1)>2.5, IF(V(Q)>=1,1,V(Q)), 0) }
GNQH 0 NQ VALUE { IF(V(D1)<=2.5 & V(C1)>2.5, IF(V(NQ)<=4,1,5-V(NQ)), 0) }
GNQL NQ 0 VALUE { IF(V(D1)>2.5 & V(C1)>2.5, IF(V(NQ)>=1,1,V(NQ)), 0) }
RQ Q 0 1G
RNQ NQ 0 1G
CQ NQ 0 4n IC=0
CNQ Q 0 4n IC=0
.ENDS TFF
这样的模型能用么?
