MP4029将会与2014年推出,它适应于小功率(5-10W)、隔离、高功率因素(带PFC)的、设计空间受限(如GU10 MR16等等小板)的驱动电源。
The MP4029 is a primary-side-controlled offlineLED lighting driver with an integrated 650V MOSFET. It can achieve high power factor andaccurate LED current for isolated single-power-stage lighting applications in a single SOIC8-7Bpackage. The proprietary real-current controlmethod can control the secondary-side LED current using primary-side information. It can significantly simplify LED lighting system design by eliminating the secondary-side feedback components and the opto-coupler.The MP4029 integrates power factor correctionand works in boundary conduction mode to reduce the MOSFET switching losses.The adaptiveTransformer-Size-Reduction operation mode can achieve a smaller transformer AP value which can lead a smaller transformer size.MP4029’s multiple protection function greatlyenhances the system reliability and safety. TheMP4029 features over-voltage protection, short-circuit protection, primary side over currentprotection,brownoutprotection,overtemperature protection, cycle-by-cycle currentlimit, VCC under voltage lockout, and auto-restartfunction.
没来得及翻译,大致总结一下:
1、原边反馈式,省去光耦、次级反馈。
2、集成650V MOSFET.
3、集成PFC,能够做高功率因素。
4、临界条件模式,减少开关管损耗.
5、减小变压器规格以及COST.
6、具备完善的保护功能。
•Real current control without secondary-feedback circuit
•AdaptiveTransformer-Size-ReductionOperation Mode
•Internal MOSFET with 650V High VoltageRating
•Good line and load regulation
•High power factor≥0.9 over universal inputvoltage
•Boundary conduction mode for improvedefficiency
•Brown-Out Protection
•Over-Voltage Protection
•Short-circuit protection
•Primary side over current protection
•Over-temperature protection
•Input UVLO
•Cycle-by-cycle current limit
•Available in an SOIC8-7B package
