General DescriptionThe XL4016 is a 180 KHz fixed frequencyPWM buck (step-down) DC/DC converter,capable of driving a 8A load with highefficiency, low ripple and excellent line andload regulation. Requiring a minimumnumber of external components, the regulatoris simple to use and include internalfrequency compensation and afixed-frequency oscillator.The PWM control circuit is able to adjust theduty ratio linearly from 0 to 100%. An overcurrent protection function is built inside.When short protection function happens, theoperation frequency will be reduced from180KHz to 48KHz. An internal compensationblock is built in to minimize externalcomponent count.
Features
Wide 8V to 40V Input Voltage Range
Output Adjustable from 1.25V to 36V
Maximum Duty Cycle 100%n Minimum Drop Out 0.3V
Fixed 180KHz Switching Frequency
8A Constant Output Current Capability
Internal Optimize Power MOSFET
High efficiency up to 96%
Excellent line and load regulation
Built in thermal shutdown function
Built in current limit function
Built in output short protection function
Built in input over voltage protection
Available in TO220-5L package
Applications
LCD Monitor and LCD TV
Portable instrument power supply
Telecom / Networking Equipment
还有PCB资料以及BOM表未一一上传。请谅解。
如有需要,请咨询
13686815452 李先生
QQ:1480599669
