  • 论坛首页
  • 产品/供求资讯
  • KT6001-自动识别USB快充模式IC,自动检测苹果还是三星手机或平板,兼容性超高,应用于移动电源、车充、旅充等
 4.0V ~ 6.0V Single Supply Operation
 Smart USB Charger Identification Circuit
 Support Apple iPad 2.4A Applications
 Support Samsung Galaxy Note 2.0AApplications
 Support BC1.2 & YD/T 1591 Battery ChargingSpecifications
 8kV High ESD Protection on DP/DM
 -20OC ~ +105OC Operating Ambient Temperature
 TSOT23-5L Package
 RoHS Compliant and Halogen-Free
KT6001-智能识别USB快充模式.pdf
陆先生
深圳怡雅恩电子科技有限公司
0755-23225811
13502804516
深圳市龙岗区平湖华南城华利嘉电子广场3E027
全部回复(1)
luzh07
供应AMC7169---LED保护管LED开路保护IC,兼容安森美NUD4700,SMD602,Littel fulse PLED6
The AMC7169 is a two terminal LED protector with low dropout voltage rated for 500mA bypass current. Low operation current at monitoring mode and high bypass current capability at triggered mode. Build-in reverse diode for bypass reversed supply voltage.The AMC7169 is designed for parallel connection with power LED. It bypasses LED driving current when LED at open circuit condition. It also bypasses LED driving current at reverse connected driving current to LED.
5V Protection Trigger Voltage500mA Bypass Current Capability1V Bypass Dropout Voltage500mA Reverse Current Capability8KV HBM ESD Protection2-Lead 2mm x 2mm FBP Package
iML_AMC7169_Datasheet_Ver_F_doc.pdf
陆先生
深圳怡雅恩电子科技有限公司
0755-23225811
13502804516
