该产品以Chroma 8000 ATS为基础的客制化系统,针对电动车车载充电器及DC-DC转换器的待测物特性撘配整合式接线面板及专属测试项目,包含基本电气特性及通讯协定测试项目,以大幅缩短测试时间。
并且此系统针对电动/混合动力汽车的车载充电器与DC/DC转换器的输入/输出特性、效率与保护项目测试。
支持一下测试:
优化后的标准测试项目(On-Board Charger):
可符合QC/T 895-2011法规标准Charger Pre-setup (初始设定)
Charger Input/Output Test (输入输出测试)Charger Line Regulation Test(输入效应测试)Charger Load Regulation Test(负载效应测试)Charger Hold On Adjust Test(在线调整测试)Charger Fin Ramp Shut Down Test(输入频率极限测试)Charger Fin Ramp Start Up Test(开机频率极限测试)DSO Setup For 4 Channels(数位式示波器设定/4 Channels)Charger Cursor Measure Time(光标量测时间)Charger Load Setup(负载设定)Charger Over Load Protection Test(过载保护测试)Charger OVP (CC Mode) Test(负载定电流模式下过电压测试)Charger OVP (CV Mode) Test(负载定电压模式下过电压测试)Charger Peak Current Test(峰值电流测试)Charger Ripple & Noise Test(涟波及杂讯测试)Charger Short Circuit Protection Test(输出短路保护测试)Charger Static Test(静态测试)Charger Vin Ramp Shut Down Test(输入电压极限测试)Charger Vin Start Up Test(开机输入电压极限测试)Charger Waveform Measure Test(波形量测)Charger Waveform Measure Turn On Test(开机波形量测)Charger Waveform Measure Turn Off Test(关机波形量测)Enable Turn On/Off ChargerCAN Bus Reading Charger
优化后的标准测试项目(DC-DC Converter):
可符合GB/T 24347-2009法规测试DD-System Pre-setup(系统初始设定)
DC-DC Input/Output Test(输入输出及效率测试)DC-DC Line Regulation Test(输入效应测试)DC-DC Load Regulation Test(负载效应测试)DC-DC Hold On Adjust Test(在线调整测试)DSO Setup For 4 Channels(数位式示波器设定/4 Channels)DC-DC Cursor Measure Time(光标量测时间)DC-DC Over Load Protection Test(过载保护测试)DC-DC Over Voltage Protection Test(过电压保护测试)DC-DC Peak Current Test(峰值电流测试)DC-DC Ripple & Noise Test(涟波及杂讯测试)DC-DC Short Circuit Protection Test(短路保护测试)DC-DC Total Regulation Test(总效应测试)DC-DC Vin Ramp Shut Down Test(输入电压极限测试)DC-DC Vin Ramp Start Up Test(开机输入电压极限测试)DC-DC Waveform Measure Test波形量测)DC-DC Waveform Measure Turn On Test(开机波形量测)DC-DC Waveform Measure Turn Off Test(关机波形量测)Total Efficiency Test(总效率量测)Enable Turn On/Off DC-DCCAN Bus Reading Charger
CAN Bus Pre-Setup(初始讯息设定)
