求DSP28335产生SPWM波形程序
想做一个用DSP28335控制开关管的逆变电源,求采用28335产生SPWM波形的程序。
全部回复(6)
wpcily
没有
chaos2008
直接找TI的例程
樱空释
请问你最后找到了28335 产生SPWM 的程序了吗?
小低调
#include "DSP2833x_Device.h"     // DSP2833x Headerfile Include File#include "DSP2833x_Examples.h"   // DSP2833x Examples Include File
double sin_180[]={0.000000,0.034899,0.069756,0.104528,0.139173,0.173648,0.207911,0.241921,0.275637,0.309016,                  0.342020,0.374606,0.406736,0.438371,0.469471,0.500000,0.529919,0.559192,0.587785,0.615661,                  0.642787,0.669130,0.694658,0.719339,0.743144,0.766044,0.788010,0.809016,0.829037,0.848048,                  0.866025,0.882947,0.898794,0.913545,0.927183,0.939692,0.951056,0.961261,0.970295,0.978147,                  0.984807,0.990268,0.994521,0.997564,0.999390,1.000000,0.999390,0.997564,0.994521,0.990268,                  0.984807,0.978147,0.970295,0.961261,0.951056,0.939692,0.927183,0.913545,0.898794,0.882947,                  0.866025,0.848048,0.829037,0.809016,0.788010,0.766044,0.743144,0.719339,0.694658,0.669130,                  0.642787,0.615661,0.587785,0.559919,0.529919,0.500000,0.469471,0.438371,0.406736,0.374606,                  0.342020,0.309016,0.275637,0.241921,0.207911,0.173648,0.139173,0.104528,0.069756,0.034899,                  0.000000,-0.034899,-0.069756,-0.104528,-0.139173,-0.173648,-0.207911,-0.241921,-0.275637,-0.309016,                 -0.342020,-0.374606,-0.406736,-0.438371,-0.469471,-0.500000,-0.529919,-0.559192,-0.587785,-0.615661,                 -0.642787,-0.669130,-0.694658,-0.719339,-0.743144,-0.766044,-0.788010,-0.809016,-0.829037,-0.848048,                 -0.866025,-0.882947,-0.898794,-0.913545,-0.927183,-0.939692,-0.951056,-0.961261,-0.970295,-0.978147,                 -0.984807,-0.990268,-0.994521,-0.997564,-0.999390,-1.000000,-0.999390,-0.997564,-0.994521,-0.990268,                 -0.984807,-0.978147,-0.970295,-0.961261,-0.951056,-0.939692,-0.927183,-0.913545,-0.898794,-0.882947,                 -0.866025,-0.848048,-0.829037,-0.809016,-0.788010,-0.766044,-0.743144,-0.719339,-0.694658,-0.669130,                 -0.642787,-0.615661,-0.587785,-0.559919,-0.529919,-0.500000,-0.469471,-0.438371,-0.406736,-0.374606,                 -0.342020,-0.309016,-0.275637,-0.241921,-0.207911,-0.173648,-0.139173,-0.104528,-0.069756,-0.034899, };typedef struct{   volatile struct EPWM_REGS *EPwmRegHandle;   Uint16 EPwm_CMPA_Direction;   Uint16 EPwm_CMPB_Direction;   Uint16 EPwmTimerIntCount;   Uint16 EPwmMaxCMPA;   Uint16 EPwmMinCMPA;   Uint16 EPwmMaxCMPB;   Uint16 EPwmMinCMPB;}EPWM_INFO;// Global variables used in this exampleEPWM_INFO epwm1_info;EPWM_INFO epwm2_info;EPWM_INFO epwm3_info;// Configure the period for each timer#define EPWM1_TIMER_TBPRD  1024 // Period register   0~2^16/*#define EPWM1_MAX_CMPA     8000#define EPWM1_MIN_CMPA       500#define EPWM1_MAX_CMPB     8000#define EPWM1_MIN_CMPB       500#define EPWM2_TIMER_TBPRD  2000  // Period register#define EPWM2_MAX_CMPA     1950#define EPWM2_MIN_CMPA       50#define EPWM2_MAX_CMPB     1950#define EPWM2_MIN_CMPB       50#define EPWM3_TIMER_TBPRD  2000  // Period register#define EPWM3_MAX_CMPA     1950#define EPWM3_MIN_CMPA       50#define EPWM3_MAX_CMPB     1950#define EPWM3_MIN_CMPB       50*/#define EPWM_CMP_UP   1#define EPWM_CMP_DOWN 0void  InitEPWM1(void);interrupt void epwm1_isr(void);interrupt void epwm2_isr(void);interrupt void epwm3_isr(void);void update_compare(EPWM_INFO*);void main(void){ InitSysCtrl();        //系统时钟初始化 InitXintf16Gpio();    //外设端口初始化   16位数据线 20位地址线      DINT;      InitPieCtrl();       //PIE 控制寄存器初始化      IER = 0x0000;        //关中断      IFR = 0x0000;        //清除中断标志      InitPieVectTable();  //初始化pie映射向量表      EALLOW;  // This is needed to write to EALLOW protected registers      PieVectTable.EPWM1_INT = &epwm1_isr;//      PieVectTable.EPWM2_INT = &epwm2_isr;//      PieVectTable.EPWM3_INT = &epwm3_isr;      EDIS;    // This is needed to disable write to EALLOW protected registers      EALLOW;      SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;      EDIS;      InitEPWM1();      EALLOW;      SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;      EDIS;   // Step 5. User specific code, enable interrupts:   // Enable CPU INT3 which is connected to EPWM1-3 INT:      IER |= M_INT3;   // Enable EPWM INTn in the PIE: Group 3 interrupt 1-3      PieCtrlRegs.PIEIER3.bit.INTx1 = 1;      PieCtrlRegs.PIEIER3.bit.INTx2 = 1;      PieCtrlRegs.PIEIER3.bit.INTx3 = 1;   // Enable global Interrupts and higher priority real-time debug events:      EINT;   // Enable Global interrupt INTM      ERTM;   // Enable Global realtime interrupt DBGM      for(;;)      {          asm("          NOP");      }}interrupt void epwm1_isr(void){   // Update the CMPA and CMPB values   update_compare(&epwm1_info);   // Clear INT flag for this timer   EPwm1Regs.ETCLR.bit.INT = 1;   // Acknowledge this interrupt to receive more interrupts from group 3   PieCtrlRegs.PIEACK.all = PIEACK_GROUP3;}interrupt void epwm2_isr(void){   // Update the CMPA and CMPB values   update_compare(&epwm2_info);   // Clear INT flag for this timer   EPwm2Regs.ETCLR.bit.INT = 1;   // Acknowledge this interrupt to receive more interrupts from group 3   PieCtrlRegs.PIEACK.all = PIEACK_GROUP3;}interrupt void epwm3_isr(void){   // Update the CMPA and CMPB values   update_compare(&epwm3_info);   // Clear INT flag for this timer   EPwm3Regs.ETCLR.bit.INT = 1;   // Acknowledge this interrupt to receive more interrupts from group 3   PieCtrlRegs.PIEACK.all = PIEACK_GROUP3;}   void  InitEPWM1(void){InitEPwm1Gpio();     // Setup TBCLK     EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // 时基计数器计数模式     EPwm1Regs.TBPRD = EPWM1_TIMER_TBPRD;       // 计数次数      T=TB*TBPRD     EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;    // Disable phase loading     EPwm1Regs.TBPHS.half.TBPHS = 0x0000;       // Phase is 0     EPwm1Regs.TBCTR = 0x0000;                  // Clear counter     EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV4;   // TB=1/SYSCLKOUT*[CLKDIV]*[HSPCLKDIV]     EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV2;     // Setup shadow register load on ZERO     EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;     EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;     EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;     EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;     // Set Compare values    EPwm1Regs.CMPA.half.CMPA = 10;    // Set compare A value //    EPwm1Regs.CMPB = 1500;              // Set Compare B value     EPwm1Regs.AQCTLA.bit.ZRO = AQ_SET;            // Set PWM1A on Zero     EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR;          // Clear PWM1A on event A, up count     EPwm1Regs.AQCTLB.bit.ZRO = AQ_SET;            // Set PWM1B on Zero     EPwm1Regs.AQCTLB.bit.CBU = AQ_CLEAR;          // Clear PWM1B on event B, up countEPwm1Regs.DBCTL.all=0xb;          // EPWMxB is invertedEPwm1Regs.DBRED=70;             //CHANNEL EPWMA   0~1023 (死区时间>momsfet上升时间+驱动上升时间+分布电容)EPwm1Regs.DBFED=50;                //CHANNEL EPWMB   0~1023EPwm1Regs.TZSEL.all=0;EPwm1Regs.TZCTL.all=0;EPwm1Regs.TZEINT.all=0;EPwm1Regs.TZFLG.all=0;EPwm1Regs.TZCLR.all=0;EPwm1Regs.TZFRC.all=0;// Interrupt where we will change the Compare ValuesEPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO;     // Select INT on Zero event   EPwm1Regs.ETSEL.bit.INTEN = 1;                // Enable INT   EPwm1Regs.ETPS.bit.INTPRD = ET_2ND;           // Generate INT on 2rd event   epwm1_info.EPwm_CMPA_Direction = EPWM_CMP_UP; // Start by increasing CMPA & CMPB   epwm1_info.EPwm_CMPB_Direction = EPWM_CMP_UP;   epwm1_info.EPwmTimerIntCount = 0;             // Zero the interrupt counter   epwm1_info.EPwmRegHandle = &EPwm1Regs;        // Set the pointer to the ePWM module/*    epwm1_info.EPwmMaxCMPA = EPWM1_MAX_CMPA;      // Setup min/max CMPA/CMPB values   epwm1_info.EPwmMinCMPA = EPWM1_MIN_CMPA;   epwm1_info.EPwmMaxCMPB = EPWM1_MAX_CMPB;   epwm1_info.EPwmMinCMPB = EPWM1_MIN_CMPB;*/}   void update_compare(EPWM_INFO *epwm_info)   {     unsigned int temp;      // Every 10'th interrupt, change the CMPA/CMPB values      if(epwm_info->EPwmTimerIntCount < 179)      {     epwm_info->EPwmTimerIntCount++;      }      else      {     epwm_info->EPwmTimerIntCount = 0;      }      temp=(EPWM1_TIMER_TBPRD)*(0.85*(sin_180[epwm_info->EPwmTimerIntCount]+sin_180[epwm_info->EPwmTimerIntCount+1])*0.25+0.5);//      if(temp>=0.95*EPWM1_TIMER_TBPRD)//      temp=0.98*EPWM1_TIMER_TBPRD; //     else //         if(temp<=0.05*EPWM1_TIMER_TBPRD) //    temp=0.02*EPWM1_TIMER_TBPRD;      EPwm1Regs.CMPA.half.CMPA = temp;      return;   }
小低调
@小低调
#include"DSP2833x_Device.h"  //DSP2833xHeaderfileIncludeFile#include"DSP2833x_Examples.h" //DSP2833xExamplesIncludeFiledoublesin_180[]={0.000000,0.034899,0.069756,0.104528,0.139173,0.173648,0.207911,0.241921,0.275637,0.309016,         0.342020,0.374606,0.406736,0.438371,0.469471,0.500000,0.529919,0.559192,0.587785,0.615661,         0.642787,0.669130,0.694658,0.719339,0.743144,0.766044,0.788010,0.809016,0.829037,0.848048,         0.866025,0.882947,0.898794,0.913545,0.927183,0.939692,0.951056,0.961261,0.970295,0.978147,         0.984807,0.990268,0.994521,0.997564,0.999390,1.000000,0.999390,0.997564,0.994521,0.990268,         0.984807,0.978147,0.970295,0.961261,0.951056,0.939692,0.927183,0.913545,0.898794,0.882947,         0.866025,0.848048,0.829037,0.809016,0.788010,0.766044,0.743144,0.719339,0.694658,0.669130,         0.642787,0.615661,0.587785,0.559919,0.529919,0.500000,0.469471,0.438371,0.406736,0.374606,         0.342020,0.309016,0.275637,0.241921,0.207911,0.173648,0.139173,0.104528,0.069756,0.034899,         0.000000,-0.034899,-0.069756,-0.104528,-0.139173,-0.173648,-0.207911,-0.241921,-0.275637,-0.309016,         -0.342020,-0.374606,-0.406736,-0.438371,-0.469471,-0.500000,-0.529919,-0.559192,-0.587785,-0.615661,         -0.642787,-0.669130,-0.694658,-0.719339,-0.743144,-0.766044,-0.788010,-0.809016,-0.829037,-0.848048,         -0.866025,-0.882947,-0.898794,-0.913545,-0.927183,-0.939692,-0.951056,-0.961261,-0.970295,-0.978147,         -0.984807,-0.990268,-0.994521,-0.997564,-0.999390,-1.000000,-0.999390,-0.997564,-0.994521,-0.990268,         -0.984807,-0.978147,-0.970295,-0.961261,-0.951056,-0.939692,-0.927183,-0.913545,-0.898794,-0.882947,         -0.866025,-0.848048,-0.829037,-0.809016,-0.788010,-0.766044,-0.743144,-0.719339,-0.694658,-0.669130,         -0.642787,-0.615661,-0.587785,-0.559919,-0.529919,-0.500000,-0.469471,-0.438371,-0.406736,-0.374606,         -0.342020,-0.309016,-0.275637,-0.241921,-0.207911,-0.173648,-0.139173,-0.104528,-0.069756,-0.034899, };typedefstruct{  volatilestructEPWM_REGS*EPwmRegHandle;  Uint16EPwm_CMPA_Direction;  Uint16EPwm_CMPB_Direction;  Uint16EPwmTimerIntCount;  Uint16EPwmMaxCMPA;  Uint16EPwmMinCMPA;  Uint16EPwmMaxCMPB;  Uint16EPwmMinCMPB;}EPWM_INFO;//GlobalvariablesusedinthisexampleEPWM_INFOepwm1_info;EPWM_INFOepwm2_info;EPWM_INFOepwm3_info;//Configuretheperiodforeachtimer#defineEPWM1_TIMER_TBPRD 1024//Periodregister 0~2^16/*#defineEPWM1_MAX_CMPA  8000#defineEPWM1_MIN_CMPA   500#defineEPWM1_MAX_CMPB  8000#defineEPWM1_MIN_CMPB   500#defineEPWM2_TIMER_TBPRD 2000 //Periodregister#defineEPWM2_MAX_CMPA  1950#defineEPWM2_MIN_CMPA   50#defineEPWM2_MAX_CMPB  1950#defineEPWM2_MIN_CMPB   50#defineEPWM3_TIMER_TBPRD 2000 //Periodregister#defineEPWM3_MAX_CMPA  1950#defineEPWM3_MIN_CMPA   50#defineEPWM3_MAX_CMPB  1950#defineEPWM3_MIN_CMPB   50*/#defineEPWM_CMP_UP 1#defineEPWM_CMP_DOWN0void InitEPWM1(void);interruptvoidepwm1_isr(void);interruptvoidepwm2_isr(void);interruptvoidepwm3_isr(void);voidupdate_compare(EPWM_INFO*);voidmain(void){ InitSysCtrl();    //系统时钟初始化 InitXintf16Gpio();  //外设端口初始化 16位数据线20位地址线   DINT;   InitPieCtrl();   //PIE控制寄存器初始化   IER=0x0000;    //关中断   IFR=0x0000;    //清除中断标志   InitPieVectTable(); //初始化pie映射向量表   EALLOW; //ThisisneededtowritetoEALLOWprotectedregisters   PieVectTable.EPWM1_INT=&epwm1_isr;//   PieVectTable.EPWM2_INT=&epwm2_isr;//   PieVectTable.EPWM3_INT=&epwm3_isr;   EDIS;  //ThisisneededtodisablewritetoEALLOWprotectedregisters   EALLOW;   SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC=0;   EDIS;   InitEPWM1();   EALLOW;   SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC=1;   EDIS;  //Step5.Userspecificcode,enableinterrupts:  //EnableCPUINT3whichisconnectedtoEPWM1-3INT:   IER|=M_INT3;  //EnableEPWMINTninthePIE:Group3interrupt1-3   PieCtrlRegs.PIEIER3.bit.INTx1=1;   PieCtrlRegs.PIEIER3.bit.INTx2=1;   PieCtrlRegs.PIEIER3.bit.INTx3=1;  //EnableglobalInterruptsandhigherpriorityreal-timedebugevents:   EINT; //EnableGlobalinterruptINTM   ERTM; //EnableGlobalrealtimeinterruptDBGM   for(;;)   {     asm("     NOP");   }}interruptvoidepwm1_isr(void){  //UpdatetheCMPAandCMPBvalues  update_compare(&epwm1_info);  //ClearINTflagforthistimer  EPwm1Regs.ETCLR.bit.INT=1;  //Acknowledgethisinterrupttoreceivemoreinterruptsfromgroup3  PieCtrlRegs.PIEACK.all=PIEACK_GROUP3;}interruptvoidepwm2_isr(void){  //UpdatetheCMPAandCMPBvalues  update_compare(&epwm2_info);  //ClearINTflagforthistimer  EPwm2Regs.ETCLR.bit.INT=1;  //Acknowledgethisinterrupttoreceivemoreinterruptsfromgroup3  PieCtrlRegs.PIEACK.all=PIEACK_GROUP3;}interruptvoidepwm3_isr(void){  //UpdatetheCMPAandCMPBvalues  update_compare(&epwm3_info);  //ClearINTflagforthistimer  EPwm3Regs.ETCLR.bit.INT=1;  //Acknowledgethisinterrupttoreceivemoreinterruptsfromgroup3  PieCtrlRegs.PIEACK.all=PIEACK_GROUP3;}  void InitEPWM1(void){InitEPwm1Gpio();   //SetupTBCLK   EPwm1Regs.TBCTL.bit.CTRMODE=TB_COUNT_UP;//时基计数器计数模式   EPwm1Regs.TBPRD=EPWM1_TIMER_TBPRD;   //计数次数   T=TB*TBPRD   EPwm1Regs.TBCTL.bit.PHSEN=TB_DISABLE;  //Disablephaseloading   EPwm1Regs.TBPHS.half.TBPHS=0x0000;   //Phaseis0   EPwm1Regs.TBCTR=0x0000;         //Clearcounter   EPwm1Regs.TBCTL.bit.HSPCLKDIV=TB_DIV4; //TB=1/SYSCLKOUT*[CLKDIV]*[HSPCLKDIV]   EPwm1Regs.TBCTL.bit.CLKDIV=TB_DIV2;   //SetupshadowregisterloadonZERO   EPwm1Regs.CMPCTL.bit.SHDWAMODE=CC_SHADOW;   EPwm1Regs.CMPCTL.bit.SHDWBMODE=CC_SHADOW;   EPwm1Regs.CMPCTL.bit.LOADAMODE=CC_CTR_ZERO;   EPwm1Regs.CMPCTL.bit.LOADBMODE=CC_CTR_ZERO;   //SetComparevalues  EPwm1Regs.CMPA.half.CMPA=10;  //SetcompareAvalue //  EPwm1Regs.CMPB=1500;       //SetCompareBvalue   EPwm1Regs.AQCTLA.bit.ZRO=AQ_SET;      //SetPWM1AonZero   EPwm1Regs.AQCTLA.bit.CAU=AQ_CLEAR;     //ClearPWM1AoneventA,upcount   EPwm1Regs.AQCTLB.bit.ZRO=AQ_SET;      //SetPWM1BonZero   EPwm1Regs.AQCTLB.bit.CBU=AQ_CLEAR;     //ClearPWM1BoneventB,upcountEPwm1Regs.DBCTL.all=0xb;     //EPWMxBisinvertedEPwm1Regs.DBRED=70;      //CHANNELEPWMA 0~1023(死区时间>momsfet上升时间+驱动上升时间+分布电容)EPwm1Regs.DBFED=50;        //CHANNELEPWMB 0~1023EPwm1Regs.TZSEL.all=0;EPwm1Regs.TZCTL.all=0;EPwm1Regs.TZEINT.all=0;EPwm1Regs.TZFLG.all=0;EPwm1Regs.TZCLR.all=0;EPwm1Regs.TZFRC.all=0;//InterruptwherewewillchangetheCompareValuesEPwm1Regs.ETSEL.bit.INTSEL=ET_CTR_ZERO;  //SelectINTonZeroevent  EPwm1Regs.ETSEL.bit.INTEN=1;        //EnableINT  EPwm1Regs.ETPS.bit.INTPRD=ET_2ND;     //GenerateINTon2rdevent  epwm1_info.EPwm_CMPA_Direction=EPWM_CMP_UP;//StartbyincreasingCMPA&CMPB  epwm1_info.EPwm_CMPB_Direction=EPWM_CMP_UP;  epwm1_info.EPwmTimerIntCount=0;      //Zerotheinterruptcounter  epwm1_info.EPwmRegHandle=&EPwm1Regs;    //SetthepointertotheePWMmodule/*  epwm1_info.EPwmMaxCMPA=EPWM1_MAX_CMPA;   //Setupmin/maxCMPA/CMPBvalues  epwm1_info.EPwmMinCMPA=EPWM1_MIN_CMPA;  epwm1_info.EPwmMaxCMPB=EPWM1_MAX_CMPB;  epwm1_info.EPwmMinCMPB=EPWM1_MIN_CMPB;*/}  voidupdate_compare(EPWM_INFO*epwm_info)  {   unsignedinttemp;   //Every10'thinterrupt,changetheCMPA/CMPBvalues   if(epwm_info->EPwmTimerIntCount<179)   {   epwm_info->EPwmTimerIntCount++;   }   else   {   epwm_info->EPwmTimerIntCount=0;   }   temp=(EPWM1_TIMER_TBPRD)*(0.85*(sin_180[epwm_info->EPwmTimerIntCount]+sin_180[epwm_info->EPwmTimerIntCount+1])*0.25+0.5);//   if(temp>=0.95*EPWM1_TIMER_TBPRD)//   temp=0.98*EPWM1_TIMER_TBPRD; //  else //    if(temp
看着比较复杂 其实就是180个占空比 循环给   哦对 要确定自己的开关频率 来通过开关几次给下一个就行了 再就是自然采样法、标准采样法要看看
茫然闲
@小低调
看着比较复杂其实就是180个占空比循环给 哦对要确定自己的开关频率来通过开关几次给下一个就行了再就是自然采样法、标准采样法要看看
sin_180[]里面的点怎么算的?
